Question about Moen 7065 Vestige Single-Handle Kitchen Faucet with Side Spray Chrome...
Moen one handle kitchen faucet very low water stream
If you take the faucet head off the pressure is to the faucet is good. We cleaned the screen. My boyfriend took the faucet head apart and is not sure he but it back together correctly. This faucet has a cartridge. We are thinking of replacing the cartridge.
  • Anonymous Mar 26, 2009
    Help! The handle just fell off our Moen Vestige faucet 7065. It is a single handle faucet. We can't get the handle back on or get it off to replace it. Can anyone help?
    Problem Solver:
  • 15 Answers
If the pressure is good with the head off then you can probably get a new head for it u shouldn't have to change the cartrige. it sounds like the head is clogged so plastic pieces in the head to help save water "water savers" it is hard to clean them i would try changing the head u should be able to find on for a moen, u buy for looks u buy it for life. take the old head with u when u go to buy a new one so they can match it up to the right one.if you can't find it and a lowes or home deptm try a plumbing supply house
Posted on Apr 19, 2009
Old moen vestiage kitchen faucet with current low water pressure. how do we fix?
First check aerator at end of spout unscrew and clean or replace,if that dosen't work turn off water and take cartridge out of handle assembly and check for any foreign matter, clean out reinstall,take care to remember position cartridge came out.
Jun 10, 2011 | Moen 7065 Vestige Single-Handle Kitchen...
I have a brand new moen muirfield high arc faucet with low pressure at spout but good pressure at side spray what can i do to get better pressure at spout
clevine336-
The design of a hand sprayer is meant to provide a higher pressure spray (the smaller outlet size means greater velocity in the water coming out of the sprayer head). That said, there could be something constricting the water flow in your faucet. If you unscrew the aerator on the end of the faucet do you get better pressure? Is the screen in the aerator clogged with sediment or mineral deposits? If this is the case you may have water requiring periodic cleaning of the aerator.
Hope this helps.
Regards,
DIYpro
May 01, 2011 | Moen Muirfield Kitchen Faucet with Side...
I have a ca87629csl two handle kitchen faucet with a side spray and I have extremely low water pressure coming out the faucet even with the screen taken out. I think or know that debris in the line has...
If the faucet is plugged AND the sprayer also seems to be plugged, the problem is probably in the diverter valve that controls the water going to the faucet and sprayer, see URL link below. Need to find a way to clear the valve, most likely by removing the faucet neck and cleaning and the reassembling. Prior to doing that I would remove the hose connection and try blowing back through the faucet to see if you can get something out of it.
http://www.moen.com/shared/pdf/ca87621pt.pdf
Please contact me if this does not work. More things you can do, but they are pretty drastic.
Paul
Sep 18, 2010 | Moen 7905 Castleby Two-Handle Kitchen...
I have a Moen single lever faucet. There is low water pressure coming from the faucet, Can anything inside the faucet be replaced to increase the water pressure? Thanks Bob Fruhling
I have had the cartridge replaced in my moen single handle faucet with sprayer in the end and now it turns off by itself. Any suggestions on the problem
Aug 15, 2010 | Moen 7437 Chateau Single Hole Kitchen...
Moen L3175 faucet with low water pressure
IS THIS A SHOWER ONLY? IF SO ,I WOULD REMOVE THE SHOWER HEAD FIRST THEN TURN YOUR WATER ON.THE HEAD JUST MIGHT NEED TO BE CLEANED AFTER 11 YEARS.
May 10, 2010 | Moen L3175 Chrome Legend Single Handle...
My moen vestage faucet is dropping water pressure. It worked fine when it was installed but the water volume out of the faucet has dropped to less than half of what it was.
Have you removed aerator ,screen etc., from end of tap, to see how flow is with it off. If good, or same as other taps when taken off of them, then you've got debris in aerator, and screen.
Jan 03, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
Low hot water pressure in kitchen faucet
I have moen kitchen faucet # 7560 and water pressure very low. What should I do? We check water flow in pipe it is ok. I changed cartridge as well as pipe nothing help. Please let me know. thanks
Oct 14, 2009 | Moen & Replacement Cartridge
My Moen kitchen faucet stopped working suddenly in that only a thin stream of water would flow at most when I turned on the hot water handle or the cold water handle to the maximum positions. I replaced...
wow... I wish you hadn't gone thru the expense of replacing the faucet... it's perfectly good... your problem was the aerator, it unscrews at the tip of the water spout and had collected too much sediment which eventually blocked water flow. Often happens quickly after your water is shut off at the main valve. Aerators cost about 50 cents...
Aug 30, 2009 | Moen Chateau Loop-Handle Kitchen Faucet...
Moen 7065 Vestige Single-Handle Kitchen Faucet with Side Spray Chrome... Logo
488 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
