Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Unit ED2FTGXKQ04, side-by-side fridge not cooling
Unit ED2FTGXKQ04, side-by-side refriferator not cooling or freezing. Removed all frozen items and powered unit down overnight. Not cooling or freezing at re-start. Pulled away from wall. No warm or hotspots. No unusual noises. Check front grill to ensure coils were clean and clear. Still no cold or freezing air.
  • romanscoop67 Mar 08, 2009
    I don't know how to check for that. We found a dead rodent behind the rear lower cover and there is a layer of caked dust bunny behind the first row of coils in the front. How can I check the freon level?
Whirlpoolfridge model 6WMV47NS two-door fridge. Freezer part on top reached minus 18 deg C, but fridge part below works between 5 and 8 deg C. How do I set fridge part colder? Thermostat is set at the coldest already. Please reply to lesley@arcticool.co.nz
Posted on May 30, 2011
Hello my is leroy, have u check the freon levels for the unit.
Posted on Mar 08, 2009
Water dispenser line frozen, items freezing in fridge side. Freezer constantly running/blowing
Your freezer is what actually cools the refrigerator. The cool air enters from that spot on the top left of the freezer. Make sure that isn't blocked. It's sounds like the thermostat that controls the air flow from the freezer to the refrigerator isn't working or the air flow control device is stuck.
Either way if you can, unload and unplug the unit. This will do to things. First it will reset the circuits that control everything and secondly if the air flow control is frozen thawing out the refrigerator and freezer may free it up.
Feb 04, 2014 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Some items in fridge frozen
What is the model number of your unit?
Nov 04, 2012 | Kenmore Side by Side Refrigerator
Whirlpool side by side does not stay cool or frozen.
You need to check the overload relay on the compressor and make sure that the coils near the compressor are clean of debris and duct.
Mar 30, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator is not cooling/freezing & control panel is flashing
I WOULD UNPLUG UNIT FROM OUTLET AND WAIT ABOUT 5 MIN. THEN PLUG BACK IN. IF WORKS YOU RESET THE BOARD IF DOESNT WORK THENYOU MAY NEED BOARD REPLACED. HOPE THIS WORKS
Sep 23, 2009 | KitchenAid Superba Architect KSCS25INSS...
Frozen items in refrigerator
In side by sides if the fridge side not working correctly it means that the air vent from the freezing unit has stuck in the closed position which causes the fridge to not be any where near as cool as it should be and if it is too cold then the vent is stuck in the open position. The vent is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up, which can be caused by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. Best call a service engineer asap.
Aug 29, 2009 | Amana Refrigerators
Freezer is only cold not freezing, fridge is cool not cold
You will need to remove the rear panel in the back of the freezer compartment. If Frozen over defrost with a hair dryer. At the bottom you will see a defrost heater WR51X10101 Defrost Heater it has glass around the element inside and will be easy to spot if burned out. Let me know what you find, Sea Breeze
Aug 27, 2009 | GE Profile PSW26P Stainless Steel Side by...
Fridge not cooling, freezer not cold enough, ice maker not workin
is there alot of frost in the rear panel of the freezer if not the compressor is not start or getting hot because fan that cools it has failed is the part between the side/side door extremely hot if so check the cooling fan for the compressor
Aug 19, 2009 | Maytag MZD2766GES Side by Side...
Fridge not cooling...freezer works fine.?
Have you checked the damper at the top left hand side, could be frozen - take it off thaw it out and replace. The freezing could have damaged the unit though.
Jul 19, 2009 | KitchenAid (KSRD22FKST) Side by Side...
GE Profile not keeping items cold or frozen
Does'nt sound like your compressor.sounds like you may have frost build up,and the tubes may be partially blocked.Try defrosting the whole unit.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 21, 2009 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
342 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
