Question about TruTech PLV16190 Television
I am unable to set the tv to channel 3 so my satellite will work. I can't program it to channel 3 with the remote, and I am unable to channel up or down to channel 3. How can I get there? Satellite is installed and was working....somehow the channel got changed. It has ATV and CATV modes, and will channel to just a few different numbers. Channel 3 is not one of them. Satellite company can't help until I get the tv back on channel 3!! Help! This is a TruTech TV/DVD T2000D Model
  • TruTech Master
  • 19,396 Answers
Ensure that the satellite cable is well plugged. Try doing again auto program scan on tv to re-program channels, and see if it takes the sat channel.
Posted on Mar 08, 2009
  • Ginko
    Ginko Mar 08, 2009
    Try the following:
    Check the cables first, ensure cable from box to tv is OK.
    Unplug TV and sat box power cord to reset both.
    Plug back TV and start it with sat still unplugged (or cable out if there is no box) and try browsing channel three , if you do not have channel three, then the TV tuner may be faulty.
    Restart teh sat box, and try going to channel three, if it is skipping channel three , and this was working with sat off, then the sat box or the connection cable to tv cable are bad.
    Try doing auto scan again to catch up the signal from sat box on channel three.
I have a 27 inch symphonic crt tv. i have a bell satellite reciever hooked up to it with the renote programmed for the tv. i accidentally hit the mute button and now there is a 2 on each corner of the tv...
hi there, plugging and unplugging won't work that way. Pls try This:
1. look for the Program menu of your bell satellite unit
2. under menu you will see the settings there and try to reconfigure it or reset the current program.
3. scan for available channels and save it. i hope this will help you a little. Thank You.
Feb 07, 2011 | Televison & Video
Satellite connection to tv doesnt recognize
At least you know the set does work. I'm also assuming your satellite receiver is working and that all your cables are good.
There are two ways to hook up to the TV: RF (antenna) and the A/V jacks. Maybe the seller was using the RF input (the threaded round connector where you screw on a cable connection, then choose channels with the set's tuner), and you're trying to connect using the A/V jacks (the red, white and yellow RCA jacks). If that's the case you need to switch the TV to those inputs. You may need the original remote to do that if the TV doesn't have a front panel TV/AV button.
The other possibility is you're connecting the satellite receiver to the RF connector and the TV isn't on the right channel (usually channel 3 or 4). If you're using the RF input, have the TV autoprogram and it should find the channel. Most sets can do that from the front panel menu button.
Hope this helps. Thanks for sing Fixya!
Feb 19, 2010 | Quasar SP-3235 32" TV
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
How do I install a channel to receive satellite programmes? My model is LE19R8
If you have a satellite and it is connected with coaxial cable put the set to channell 3 or 4. If the satellite is connected with RCA cableput the set on that source the cable are connected to. No need to program the set. Use the cable remote to change the channels just use the tv remote to turn the set on and off and for volume.
Aug 19, 2008 | Televison & Video
Harmony 880 Logitech tv remote - won't change channels on direct tv
you may need to reprogram your remote, or, if you have your profile setup on the harmony website, reload from there
May 11, 2008 | Logitech Harmony 880 LCD Remote Control
Hitachi 27
If the sat feed is on channel 3, and the TV is tuned in and still does not get the feed, check the feed wire to be okay. If all is okay, there is a possiblity that the tuner module in the set has failed.
Jerry G.
Apr 29, 2008 | Hitachi 27CX01B 27" TV
AIWA VX-T1420 Setting Channels
No it should not light up. If you can not go into menu and add channels manually or auto program. Then you will have to get a remote to work. You could order original remotecontrols.com.
Sep 23, 2007 | GE 13TVR60 Combo
Unable to channel to channel 3
If you take a working remote, point it at the TV and hit "3", then "ENTER", does the set go to channel 3?
Sep 04, 2007 | Sony FD Trinitron WEGA KD-27FS170 TV
Toshiba 36a41 television
You should be able to use your remote control to do this.Your channel 73 is more than likely UHF 73 so you need to put your tv in the antenna setting rather than cable setting. Once you do this just input 73 with your remote. Hope this helps! Stargazer
Jan 21, 2007 | Sony KV-36XBR250 TV
TruTech PLV16190 Television Logo
132 people viewed this question
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
