Question about ViewSonic VA1912wb Monitor
Monitor flickers unless brightness is at 100%
Starting a few days ago, I noticed that my monitor was flickering when dark colors were displayed. I reseated the HDMI and power cables, but the only solution I found was to increase the brightness of the monitor to 100%. This is very hard on the eyes (I'm used to about 70%). Does anyone have other suggestions? The monitor was purchased in 2005, but I wouldn't expect it to fail already.
  • Cyberbitz Apr 12, 2009
    I have an Internet Cafe and 6x Viewsonic VA1912wb purchased new in 2006.
    2 of them now have the same problem, flickering unless the brightness is turned up full.
    Very dissapointing.
  • m4you31 Nov 15, 2009
    Hi any one have a idea to solve my pc problem its always showing brightness 100 % its makeing irritating to me please reply back if u have a idea my mail id m4you31@gmail.com
Try monitor menu select Memory Recall and press that, should clear right up
Posted on Jul 08, 2011
I also had flickering (except at full brightness) even after changing the capacitors. Finally treated the various connectors with silicone oil, and all was fixed.
Posted on Jun 22, 2015
I just finished repairing 2 of these monitors. There are 4 capacitors (CapXon brand, cheap) on the backlight power supply board that are going bad and are probably bulging and leaking already. This monitor isn't terribly hard to get apart, and somebody with basic soldering skills can do the repair in a few hours for around $5 in parts from DigiKey.
I used replacement capacitors from DigiKey (Panasonic FM brand/model). I replaced ALL capacitors on the power supply board because it is clear the ViewSonic uses bottom barrel parts.
If you don't repair the problem, at some point in the future the monitors won't power up at all unless you power cycle for 20 minutes, then eventually, not at all.
Posted on Nov 06, 2009
Afraid that doesn't solve the problem; I recently got this problem as well - flickering occurs when dark colors are present. Sometimes I don't get the flickering at all after start up, other times such as now I do.
I've also found that changing the refresh rate depends greatly on what resolution you are running. only 1024x768 can achieve a higher refresh rate. Anything higher than that resolution and it seems, at least for this monitor, you can only operate at 60 Hertz
Posted on Aug 22, 2009
    Problem Solver:
  • 17 Answers
Go to your Windows display settings and hit the Advance button and try changing the refresh rate on the monitor.
See if that helps.
Posted on Mar 08, 2009
Occasional odd coloring and backlight flickering
Please check it monitor color adjust button. If ok then you check it monitor cable if change possible then change it or power cable also proper connect. If not solved contact Good Monitor technician.
Thanks.
Feb 17, 2014 | Apple Cinema Display 23" HD Monitor
Erratic display
So your Gateway is brand new or a refurb?
Aug 02, 2008 | Computers & Internet
My moniter screen go's dark with a bright horizontal white line in center ..it flickers
the driver board is bad in the monitor. Has it been in a place that is super hot like in a car? If the verticle driver chip disconnects from the matrix driver array, it will all squish into a single line in the middle of the screen like you are describing.. might try opening and blowing where the driver board connects to the LCD matrix (bunch of connectors on a plastic flat cable/bus connecting to the end of the LCD panel.. heating them could allow them to reconnect.. Its worth a try, right? It has worked for me about 60% time.
Feb 03, 2014 | Envision Computers & Internet
IH252 inc monitor bottom half darker than top.
Thin screen LCD monitor brightness controls operate several fluorescent lamps called "backlights" that are positioned behind the LCD display. Typically, they're located around the edges of the screen - sometimes just at the top and bottom, and other times at the left and right edges and others still at all 4 edges.
Fluorescent "backlight" lamp, inverter & connection wiring.
The lamps are miniature versions of those sold in stores. They require a support circuitry called an inverter that convert & boosts the level of DC to AC voltage performing the functions of a ballast in a traditional fluorescent fixture.
The reason a part of your screen remains dark is because one or more of the components in the picture above has failed and will not allow the lamp to shine. Replacement lamps and inverters aren't expensive - but requires patience and the ability to disassemble / assemble the monitor (which is usually harder to do than it appears) and solder. They are available various lengths and color temperatures (you must get a lamp that is identical or it will be noticed). If this is a new monitor - you ought to return it for replacement. If used, consider the cost of purchasing a replacement (new or used) vs. repair.
I hope this helps & good luck!
Jul 29, 2013 | Computers & Internet
A few months ago my LG Flatron L1900R monitor started flickering when I boot up my computer. It has become worse, to the point where it now flickers constantly.
From the information desribed, this means that your CRT monitor is going dead. Unfortuntly, there is no way to stop the flickering unless the monitor was replaced. I hope this has helped
Jul 05, 2011 | LG 700M 17" CRT Monitor
Screen slightly flickers
Probably the inverter board of your monitor has been exhausted. The inverter is the part that enables the monitor to glow, making a little fluorescent gas lamp insithe the LCD bright strong enough to illuminate all the panel. When this circuit has some disfunction the lamp could oscilate, ficker and finally die making the panel dark and you couldn read what's on the screen.
The inverter has a lifetime, and the lamp too, check the lamp lifetime of your monitor and the inverter too.
But this could only be performed to a qualified person, due the high probability of electric shock if you try to make yoursel the repair.
Good luck
May 23, 2009 | Sceptre X5G-Komodo IV 15" Flat Panel LCD...
X2gen monitor flicker, unstabe display
The monitor costs about 100 bucks. The company is bankrupt. Chuck it and buy another.
Jun 26, 2008 | X2Gen MG15VT 15" LCD Monitor
Erratic display
it sounds like a blown cap.. you can replace it if you know how to soder
Jun 11, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway Flat Screen FPD1830
Well, this problem is going to only get worse. You can probably send it back to the manufacturer if you still have a warantee, but if you can't just buy a new monitor.
Nov 13, 2007 | Samsung SyncMaster 204B 20.1" LCD Monitor
ViewSonic VA1912wb Monitor Logo
1,099 people viewed this question
Top ViewSonic Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
