Question about Bosch HBN 9722 GB Electric Double Oven
What are the housing dimensions for the Bosch HBN9750GB/06 oven. Need to know if it will fit!
I need to replace my 1987 approx. Chef wall oven Balmain fan forced and grill. Does anyone know the cut out dimensions. I want to buy anew oven that will fit the existing opening. Thanks
when you buy the ovens replacement
instructions are given in the paper work how to adjust the cavity to suit
there will have to be an air gap on back and sides of the new oven
you should call an electrician to wire in the new oven
to check , even replace the 1987 wiring and connections
if needed to meet the 2016 house wiring standards
you will need
tape measure
pencils
a square
straight edge
reversible hand drill and bits
two levels .... for inside the cavity to level oven
approx a 15 inch .one 6 inch
a hand saw or circular saw
, i found a jigsaw helpful
self tapping screws different lengths
as per the oven fitting requirements
you can use any paint to finish the job
white board or MDF board is ok
some extras strips of timber to level the new oven
maybe required
if imperial was used for the cavity of the old oven
metric might be for the new oven
some DIY about wall oven installs are found on youtube
Oct 14, 2016 | Ovens
Bosch oven HBN 1312.0
Please double check the model number on the unit. On the Bosch site, I found a number of models with that started HBN1312* . However the model number had another digit after the 2 and the zero was followed by a letter and a slash before additional numbers.
The model HBN131220B/01 is an all electric oven. The external dimensions for the wall oven are 595mmx595mmx515mm. I'm not sure about the internal capacity for the unit. Some documentation (including the user's manual) are available from the Bosch support site: http://portal.bsh-partner.com/portal%28bD1lbiZjPTA2MA==%29/PORTALFRAME.HTM . Enter HBN1312 in the search box to find the documents.
I hope this helps.
Nov 24, 2013 | Ovens
HBN13B2613
Built in ovens fit into a unit and are not free standing so no it doesn't have legs
May 22, 2012 | Bosch Ovens
Need to replace my oven selector switch on my bosch oven HBN13M55OB/03
My apologies - I submitted this last night but upon checking for any reply from you, I noticed it had not been posted on the page. I now have to write the entire message again!
Obtaining the part is easy, however fitting it is going to be somewhat more difficult as it's a double oven - meaning it's both higher and heavier. Access for replacing the switch and removing the front panel is from the top so the oven will need to be pulled out from the cabinet or removed. However, the double glass doors make the oven rather front-heavy so it's inclined to topple forward!
This is an expensive appliance and I recommend getting this job done professionally. Should you decide to do the job yourself, you do so at your own risk and you should follow all of the saftey instuctions carefully.
The best - and usually cheapest - place to get any genuine Bosch part is directly from Bosch. They normally deliver in 2-3 working days. The Bosch part number you need is 602732:
http://www.bosch-eshop.com/eshop/bosch/gb/prodlg.htm?Maktx=602732&eshoptype=A&autoselected= £19.63 inc. postage
Click on "Add to Basket" and then "Finish and pay >"
Fitting instructions:
I prefer to do this job with the oven fully removed from the housing but it's probably hardwired to the switch/breaker and needs two people to lift it out. Not removing it also means you have to work at a much greater height, so I recommend complete removal, if possible. The job can be done with the oven only half pulled forward from the cabinet, but the front of the oven needs to be fully supported after pulling it forward or the weight of the doors can (and will) cause it to topple forward.
1. Power off at the breaker/main switch. If you are going to completely remove the oven, you will need to power off at the main fuse box and then remove the oven power cable from the switch.
. Remove the screws which secure the oven to cabinet - these are at the sides and are only visible with the doors open
. Pull the oven control knob off of the fascia panel.
. Remove the oven completely or pull it forward half-way (see above)
5
. Remove the front half of the top panel of the oven. I think it just unclips on these, but there may be a couple of screws to remove at the side first. You will now have access to the switch area.
6
. Make a detailed note of how all the wires are attached to the main oven switch. It's a good idea to take a digital photo for reference. Some of the wires are the same colours so make sure you don't get them mixed up. Also, some of the terminals on the switch are double, so it's best to draw a diagram and give all the terminals numbers and record which wire goes to each one.
7
. Detach all,the wires from the oven selector switch. There is another white "box" attached to the back of the switch, but you don't need to disconnect the wires from this. This box is the thermostat which is attached to the temperature probe in the oven with a long wire.
8
. Remove the screws securing the selector switch to the oven and detach the switch. Make note of how all the parts - switch / bracket / support, etc - fit together. Another digital photo may be useful here.
9
. Unscrew and pull the thermostat out from the back of the selector switch. You should now be able to remove the switch from the oven.
10
. Assemble the new selector switch with the bracket, support, thermostat, etc and secure it to the oven.
11
. Refit everything else in reverse order of the above.
This may be a little bit more complicated than you were expecting. If you don't feel confident to do the work yourself, then please seek professional help. If you do decide to DIY and you let me know when you are planning to do it, I can try to be online to assist you if you get stuck anywhere.
Merry Christmas!
BElectric
Dec 18, 2010 | Bosch Ovens
Bosch range outter glass shattered
You just need the glass, get part number from Bosch website (UK) and source locally.
To fit just dismantle the door.
Aug 29, 2009 | Ovens
Retractable function selector knob stuck
facia panel most probably need removed, not to bad a job, but oven need to come out... go to bosch, web site...search parts finder with your model , and you will see an exploded diagram, this may help yet you get an idea on how it comes apart.. failing that call an engineer...
Jul 02, 2007 | Bosch HBN 560570B / 560550B Electric...
Bosch HBN 9722 GB Electric Double Oven Logo
87 people viewed this question
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
