Question about KitchenAid Refrigerators
Kitchen Aid Refrigerator Model KBRA 20 ERSS
I have a Kitchen Aid fridge, model number KBRA 20ERSS, installed new water filter, waited 24 hours and it started dispensing water. Then the next day it stopped working and wouldn't dispense water.
This is the first time it has ever happened.
The unit has a freezer at the bottom.
thanks for anyone that can help!
dididsaythat
  • 291 Answers
SOURCE: GE SIDE X SIDE Dispenser problem
Sound like maybe a dispenser board short... you could try taking of the top hidge cap on the freezer side unplug the power to the board there for 30 minustes or so plug back in and see if it can reset to default and try that before u have to change board
Posted on Aug 21, 2007
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Posted on Feb 18, 2008
  • 1314 Answers
SOURCE: kitchen aid refrigerator model KSRS22Q
it should be on the bottom where the kick plate is and will be a round piece that you turn and remove
Posted on Mar 03, 2008
SOURCE: Kitchen Aid Superba refrigerator
the black panel that runds down the side of the refrigerator between the freezer and food storage area is very hot. also the small light in the freeezer is blinking even though i have it turned off
Posted on Aug 07, 2008
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
My fridge keeps freezing everything what is the best temp to have it set at. It is an aurora model RB411M3
I recommend moving the thermostat to the exact center position, unplug, then plug in the refrigerator. Wait 24 hours for the fridge thermostat to reset and to thaw automatically. Then, I recommend a fridge thermometer, available at most grocers or kitchen supply stores. If you can't find one, use a digital thermometer with a probe. Place the thermometer hanging from the center of the center shelf. Keep the refrigerator temperature at or below 40° F (4° C). The freezer temperature should be 0° F (-18° C). Allow 24 hours for any thermostat changes.
Apr 08, 2017 | Refrigerators
Where is the water filter on my refridgerator?
I don't think your fridge has a water filter, but if you want you can install one. Just replace the old waterline by a new one with the size a new filter fits to. The filters can be put in between, without any tools, other than to cut the little pipe and a few strong hands. (yes perhaps a pare of tweezers)
Jun 16, 2014 | Refrigerators
Kenmore side-by-side not dispensing ice or water, the ice maker has been replaced, no water going into the tray. I cannot locate the water filter, does this model have one?
Don't know what is the model number of your fridge. 1.Need check electric water valve under the fridge. If that fridge made by GE (Kenmore just a Sears brand name and they use several others manufacturers for refrigeration), usually it's a frozen plastic water supply line inside freezer door. You could unplug fridge for 24 hours (you have to put food from freezer to other freezer).
Jun 29, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
How do you change filter in Kitchen Aid superba refridgerator
The superba series is a dishwasher type. the model number would be really helpfull. either way if you go to kitchenaid.com and click on product type then on refrigerator it shows all models and when you click on your model it takes you to its page and on the bottom of the page is the installation guide and every manual for your fridge. its all in PDF format and really easy to use. if you still need help please email me at phoenixnixinks@yahoo.com with the model number and i will be more than happy to help you farther.
good luck
Jan 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
No water or ice from older kenmore side by side
You must pull fridge out the water valve is in the bottom back. Sounds like the valve is stuck open. You can Google your model# to find appliance parts to order new valve.
Nov 14, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
Side by side refrigerator
The ice maker is not producing ice or not enough ice
production.
OR
The water dispenser will not operate properly
 Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.”
 Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
Supply Requirements.”
 Kink in the home water source line? Straighten the water
source line.
 New installation? Flush and fill the water system.
 Water filter installed on the refrigerator? The filter may be
 Is a reverse osmosis water filtration system connected to
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Jan 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
211 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
