Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Carrier Weathermaker SXI Model 58SX8100LG Code 12
When I wake up in the morning the furnace is out and Code 12 is flashing which is blower calibration lockout. I turn off the power which resets the computer and the unit restarts and runs fine but the Code 12 reappears and it goes out again.
The unit is 19 years old.
What do you suggest?
  • ky302z28 Mar 11, 2009
    Only had time to check out the door swicth and the door seems to fit good and tight and the swicth looks to be o.k.Today there was a code 44 flashing any ideals? Thanks
    Guru:
  • 462 Answers
Code 12 I believe is power up after power off and a call for heat from the the thermostat. If you have a weak door switch that may be vibrating and going on and off it would cause this as would any thing that causes the power to drop low or out then reapply its self. try holding the door switch in while watching the board and after 2 or 3 minutes the furnace should go on to lite and the blower cycle off. If it stays in this mode try turning the thermostat off (heat - OFF -cool) and then push in the door switch nothing should happen except the lite on the board come on and stay on. If it does this than have someone turn the thermostat to heat and see if it starts or put the door on and set the heat and see if *** goes through the normal cycle of heating. If however it goes right back into the blower mode and shows the 12 code your problem is still with you. So next remove the wire on the "W" terminal on the board. Retry power to the door switch and now nothing should be on except the red lite. If it tries to start the 12 code and blower up again Im pretty sure you have a bad ignition/blower control board.
Posted on Mar 09, 2009
  • Farley Redfield
    Farley Redfield Mar 10, 2009
    Did this clear up your problem?
  • Farley Redfield
    Farley Redfield Mar 14, 2009
    Look inside the door for a legend of the codes. I don't remember what a 44 is but seems Ive seen it before.
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Tip
Carrier Weathermaker 9200 Gas Furnace Error Code 31
A month or so ago, I woke up to discover that I had no heat in my house. I went to the furnace to do a diagnostic check, removed the service door and quickly discovered that there was no flame (visible through the glass peep-hole).
I followed the manufacturer's shut-off procedure, which can be found in the manual, here: http://legalectric.org/f/2011/03/carrier-9200-weathermaker-uhe-om58-67.pdf. When I turned the furnace back on, I saw that the igniter did not glow (should be visible through the same peep-hole - should look like a red-hot, 2-prong tuning fork) and that the red LED error code indicator (visible through the lower peep-hole) was blinking 3 short flashes and 1 long flash (error code 31).
Now what I SHOULD HAVE done was check the pressure switch first (see service manual pg. 3, component #16). By removing the rubber lines that connect tot the pressure switch, one end at a time and both at the pressure switch and the bottom of the igniter box, you may notice some debris in the lines or the male adapters on the pressure switch or igniter box. If you do, clear out the debris with a paper clip (don't insert the paper clip into the body of the pressure switch, though). After checking all connections for debris, disconnect the hose that connects to the top of the pressure switch at the "T" between the pressure switch and the igniter box and blow/suck air in and out of the pressure switch (lightly). If you hear a small click when you pass air in and out, that's the pressure switch functioning. If you hear crackling or you can't blow in/out easily, you probably have a bad pressure switch.
if you are able to make the pressure switch click, connect all lines and start up the furnace per the mfg recommendations. If the furnace kicks on, it was probably a blockage in the pressure switch lines (likely if you found gunk in the lines or male adaptors on the pressure switch), but it may still be a faulty pressure switch (my problem... when I blew in and out to the pressure switch, I could hear the silicone diaphragm cracking). I got mine going, albeit temporarily, by removing the pressure switch and passing air in and out (blowing pretty hard) with my lips on the bottom hose adapter until I could hear the diaphragm crackle free and it became easier to make it click on and off. That only bought me a few days, though. After that, I bought a replacement pressure switch at a plumbing supply place and replaced the old one. If you found gunk in the lines, I would suggest you have your furnace serviced and let the tech know what you found and where.
If neither procedure fixes the problem, it may be the igniter. For some odd reason, this issue started for me about a month ago and I replaced the igniter (YouTube video instructions are easy to find), which fixed the problem. If even that doesn't work, call a local tech, shut the gas off and wait around in some thick blankets! I hope this helped!
on Jan 08, 2015 | Heating & Cooling
Code 24 on carrier weathermaker 8000ts
Turn power off to unit. Open air handler and take a picture of the low voltage (tstat) wires and where they are landed. Remove all thermostat wires from control board. Then replace the 5 amp fuse that is likely on the board. Fuse likely looks like one for a car (blade style). Put a jumper (small piece of wire) from the R terminal to the G terminal and turn power back on to unit. This should bring on the indoor blower. Let me know how that goes!!
May 12, 2017 | Heating & Cooling
Weathermaker 8000 58TUA doesn't work
The switch could be defective but more likely the furnace blower is failing.
Dec 17, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
I have a carrier 58RAV050-12 and my furnace won't turn on. It was working earlier today but it just stopped. Any suggestions as to why?
Check the pilot lt. If its out shutdown your furnace and call a repairman. If the pilot light is on, the flame sensor might have gone out. It's a long silver sensor that sits in the pilot light flame and senses when the flame is present. If it isn't working the furnace will automatically shut down.
Nov 04, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Carrier 8000 weathermaker 92000 btu
If it works with blower door off sounds like it's not getting enough return. What's the statics? Try an adjustable limit, I think they go to 210. Good Luck!!
Jun 13, 2017 | Carrier Heating & Cooling
Furnace runs but won't ignite.
Error code 12 is blower on after power up. Meaning: after you turn on power to the furnace for aprox. 60-90 seconds the blower will run. The blower should then shut down and the furnace should go through the start up process, providing that the thermostat is set for and calling for heat. If the furnace fails to start after blower shut down there should be a new fault/error code. However if the blower continues to run longer then 90 seconds and continues with the same fault code more then likely the circuit board is bad. Please let me know if this was helpful and give me a rating. Good luck.
Feb 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
I have a Carrier Weathermaker SXi. Furnance will not turn on. I shut power off and waited ten minutes and tried to restart. Codes flashing are 12, 31, 32, 33, 41, 42. Can this be started in emergency mode?
Emergency heat is made for this kind of situation.So yes you can.
now for the codes.
code 12= Blower on after power up
code 31=High heat pressure switch or relay didn't close or reopened
code 32=Low heat pressure switch or relay didn't close or reopened
code 33=limit circuit fault(Flame rollout switch is open)
code 41=board fault
code 42=control lockout
Please rate this solution
Jan 17, 2009 | Heating & Cooling
Carrier 58MVP; Blower on, no heat. Themosta at 75, temp at 69 and furnace still does not come on. Fault code 12
A code 12 is "Blower on after power-up" Try resetting the furnace with either the Emergency switch or circuit breaker. If it continues, you may need a new control board.
Nov 28, 2008 | Carrier Heating & Cooling
Carrier Weathermaker SX model 58SX060-CC Blower runs all the time
Remove all power from the furnace, it is likely the brain in the furnace is need of being reset, from the battery replacement, why did you change the battery, was there an indicator telling you to change it?
Many times just removing all the power to the furnace will do the trick with a reset, if not let me know and we will go from there, but it sounds like the main brain is confused or bad, more likely confused, so try the power removed first.
Than let me know wbwill@sbcglobal.net
Oct 22, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
1,224 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
