Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
Beater bar belt needs replacedon a dyson DC14 animal
I cannot figure out how to replace a broken beater bar belt on a dyson DC14 animal. can anyone help me out here?
  • Anonymous Mar 20, 2014
    The beater bar portion of the DC17 will not work.
  • 134 Answers
Remove the glide plate at the bottom of rhe machine. Remove brush and broken belt. Fit new belt and re install brush. Fit glide plate, job done.
Its in the instruction book
Posted on Mar 08, 2009
  • ivoidwaranty Nov 15, 2013
    You cannot simply remove the brush roll and belt as the belt is attached to the clutch assembly.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 62 Answers
If your Dyson is more than 3 years old and the drive belt is still attached to your brush roll, The most likely cause is a stretched belt slipping on the clutch. your brush roll encounters friction on the carpet and if there is not sufficient tension in the drive belts, you have 2 of them, then they will slip and you cannot pick up debri as the vacuum was designed. You have a few options, call the Dyson help line located on your vacuum via a sticker behind your hose; explain to them the problem with the brush roll not turning sufficiently. There are also replacement belts available for your model at a cost of around $10 depending on your area, but you have to take the clutch assembly apart to install the new belts. Lastly you can buy a new clutch assembly for about $70 but this is a last resort idea. Any reputable service center should be able to replace a clutch in 5 min. and rebuild one in less than 20 min.
Hope this helps.
Posted on Nov 15, 2013
Fault finding
Have you accidentally switched off the beater bar via the dial on the head? Some models have a 'hard floors' and a 'carpets' setting (which disengages/engages the beater bar).
Jul 06, 2014 | Dyson Vacuums
Hello. i only have one arm and am trying to figure out why my beater bar wont turn on my dyson dc14. the belt smells a little too. thanx, trixie
Sounds like the beater bar is frozen in place. This sometimes happens when the ends of the bar become stuck in the holders. The solution is to remove the beater bar and clean the small holders on each end removing any debris that has built up. Spray with a little WD40 and then manually rotate the beater brush around the holders until it is free, then replace. Be sure the belt is installed properly.
Sep 09, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
We have a dyson dc14 and the beater bar stopped turning, we cleaned the bar off and checked the belt and it's not broken, I know I called Dyson a year or two ago and they told me how to reset the beater...
Hi its Darran at Dyson.
Check that the brush control dial is in the centre position when the machine is locked upright. When you release the head and pull the handle back this dial should mopve forward to the on position. Once here, the brush bar should turn.
If this doesnt resolve the problem, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Dyson Customer Service
Mar 31, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
My older Dyson DC14 (the purple one) early model with a clutch on the beater bar belt needs a clutch replacement. The bar has been cleaned and there are no worn or damaged parts so I conclude that the...
Have a look at which has some very useful info on dismantling and repairing Dysons.
Although this site doesnt actually cover the DC14 yet, the DC14 is very similar to the DC07 so as regards dissassembling the machine, and replacing the clutch, my experience is that the DC07 info will enable you to do the job.
Mar 26, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
The beater bar is not rotating.
You need to replace the belt that drives the beater bar
Feb 09, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
The beater bar doesn't work
You need to replace the belts. Here are the belts you need:
Dyson DC14 Belts
Dec 30, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC14 Animal belt clutch slips.
The clutch problem needs to be looked at by a serviceman or professional who can repair Dysons. Slipping belts are often a sign of being overused or with carpet/textures that have caused the beater bar extra tension. I suggest if this model means much to you to get it repaired.
Mar 30, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Beater bar belt broke. how do you replace it?
Remove the glide plate, take out the brush and broken belt.
Refit new belt and roller. re fit glide plate
away you go
Mar 08, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
777 people viewed this question
Top Dyson Vacuums Experts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
