Question about HP DeskJet F380 All-In-One Printer
My hp 6300 AIO printer is "offline" and will not print
  • 45 Answers
Go to printers icon there you will see HP Officejet 6300 icon right click on it and select use printer online..if you dont get the option of use printer online then unplug the USB cable and turn off the computer..wait for 2mins and then turn on the computer..wait for the computer to get completely reboot..in other words you should not see any hour glass..then connect the USB cable..wait for 5mins and then try to print..that should work
Posted on Mar 09, 2009
Can't print from HP 2540 aio to my Imac PowerPc G5 OS X 10.5.8 The Imac keeps telling that the printer is offline.
A quick look at the HP web site for this printer shows that it only supports Max OS X 10.6 and later. These versions only support the intel processor based macs. Your PowerPC mac is, unfortunately, obsolete as far as Apple and the peripheral manufacturers are concerned and is not supported.
Dec 19, 2013 | HP PhotoSmart 7350 InkJet Printer
How i can print in I pad2 with wireless printer
you can only print from an ipad using the airprint app if you have one of these printers read more about it here http://www.apple.com/ipad/features/airprint.html
    May 02, 2011 | Apple iPad 64 GB 3G Tablet PC
    My HP 6300 printer is off line, How do I put in on line
    Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
    1. Right Click on your printer Icon 2. Click Open or See What's Printing 3. Click the option that says Printer on the upper left corner of the window that pops up. 4. Make sure the only thing that is checked under that menu is Set As Default Printer. 5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
    Try printing again. I hope this helped.
    Feb 06, 2011 | HP DeskJet F380 All-In-One Printer
    My printer shows ''User intervension required'' other than ''Ready''
    The issue may be resolved by clearing the pause printing in the printer driver or by setting up a parallel connection with the computer. Clear pause printing
    1. From the Windows Desktop, select Start , Settings , and Printers .
    2. Right-click the HP LaserJet printer icon that is being used.
    3. Select the Work Offline or Pause Printing option (if enabled) to remove the check.
    4. Print the document again.
    Establish parallel connection
    1. Turn off the printer or remove the printer from the network.
    2. Connect the printer to the PC using a parallel cable.
    3. Power on the printer.
    4. Print the document again. NOTE: If the User Intervention Required message reappears, disable or remove any HP LaserJet software utilities loaded on the system (for example, Status Window, HP Toolbox, etc.). Prove printer functionality and troubleshoot communications; try printing again.
    Uninstall and reinstall the driver After performing a cold reset on a product installed with USB, a higher DOT4_00x port is created, causing the printer to hang while printing. NOTE: This is required with products installed on a USB port only.
    1. Uninstall the USB printer driver.
    2. Remove the HP folder and AIO folder from the hard drive.
    3. Reinstall the USB printer driver.
    CAUSE: This error can occur if when using a network or printing from a laptop. When the print job goes into a pending status, the printer is either in Work Offline or Pause Printing mode. Hope this helps. Please rate my response.
    Thanks.
    Have a good day.
    Mar 15, 2010 | Computers & Internet
    Cant' print from hp deskjet 7210 aio
    Go to control panel and then to printers and see if printer icon is there or not. If itis not there than check the cable that connects printer and computer. If it is there than check for the printer icon, it should on ready status, if it is offline than right click on that than click on "use printer online", then try printing it should print.
    Aug 10, 2009 | Office Equipment & Supplies
    HP C7250 AIO won't print wirelessly from my laptop
    Do Add Port in Printer Properties Ports tab and choose Standard TCP/IP. Enter IP address of the printer and follow steps to finish configuration.
    Hope this helps!
    -michan-
    Jul 20, 2009 | HP Photosmart C7250 All-In-One Thermal...
    My HP 6300 says offline and will not print
    same problem no solutio !
    delete and re-install printer is the only thing that works and only temporarily ... frustrating !!!
    Jun 07, 2009 | HP DeskJet F380 All-In-One Printer
    I have a HP Officejet 6300 and it is showing as Offline
    go to control panel, then printers and faxes, then right click on it and click "use printer online"
    hope this helps!
    Jan 25, 2009 | HP DeskJet F380 All-In-One Printer
    My Hp Officejet 6300 All-In-One printer will not copy
    printer is offline yet cables are connected and printer was working a day or so ago!
    Jan 19, 2009 | HP OfficeJet 6310 All-in-One Printer...
    Kodak Easyshare 5300 Printer
    Make sure that 5300 aio is your default printer w/ "ready status" Your HP printer might still be on "default" that's why you're having this issue
    Oct 18, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
    HP DeskJet F380 All-In-One Printer Logo
    220 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
