Question about Lexmark X3350 All-In-One InkJet Printer
The printer keeps flashing cler the paper jam but there is no paper jam and plenty of paper loaded that it doea not recognize.
  • 21 Answers
Unplug Printer and flip upside down and shake slightly if nothing comes out flip printer back over and open printer on the inside you will see some rollers in the back of the printer if you look in the middle you should see a little switch there ( that switch is the paper sensor which tells the printer if there is a jam) the printer keeps flashing cler the paper jam but - 332cee0.jpgif it is missing the printer is no good and you should contact Lexmark but if it is bent just gently push it back or bend it gently so it won"t cause problems. if you are unsure about doing that just contact Lexmark and explain your problem and if you have a warranty then they should replace it but if not you can get a new one for around $85.
Posted on Mar 20, 2009
How do I load paper into my Canon Pixma MX452 printer?
A lot of times the printer has a small piece of paper jammed in it or has had a jam and will not recognize the new paper. Try this to see if it resolves your issue. http://www.wikihow.com/Clear-a-Paper-Jam
Jun 25, 2014 | Canon Pixma MX452
Epson stylus c48 paper not loaded correctly error
@Linzi_mackie
"c48 not loading..."
Check that paper is not curled at leading edge.
Some printers are finicky about exact straightness.
Otherwise check:
Paper not glossy - roller-gripper may be doing a 'wheelie' on the edge.
Rubber gripper not worn down - the pickup roller usually has one or more rubber 'rings' around the roller to grab & feed paper by friction.
If all else fails, open cover and inspect gearing to roller, broken brackets which can cause misalignment.
Try running 'open' and see what happens.
Regards,
Clive.
Oct 25, 2017 | Epson Stylus C48 InkJet Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Will not recognize loaded paper, keeps saying no
There 's a torn piece of paper blocking the paper level sensor. Re check all areas where the paper feeds. the try re insert the paper, if its clear . turn printer off for 5 mins then turn on and try again
Jul 08, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Will not function on front feed
check all paper paths for little pieces of paper
Apr 23, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Print factory 2 Paper/CD jam fault
My e-mail is jounikontulainen@gmail.com.I could mail You technical document that might help.
Jouni
Apr 05, 2008 | MicroBoards PF-2 InkJet Printer
Hp psc 1219
dear szaszy
as per your information your printer paper jam sensor is having problem.Please get it serviced
Apr 04, 2008 | Office Equipment & Supplies
Brother HL-2040 Flashing Paper LED
Try send one paper manually, then it will pick up paper from the try automatically.
Feb 06, 2008 | Brother HL-2040 Laser Printer
Check paper light flashes, when paper loaded and no jam present
Might be a pending job gone wild. I would turn off the printer, then go to "Control Panel" and click "Printers". Double click the one you're having problem with, delete all printing documents and re-connect the printer.
You can also try a differnt USB cord or port, otherwise - the machine needs a factory reset.
Oct 22, 2007 | HP PSC 1610 All-In-One InkJet Printer
Red Paper light keeps flashing
Try to find thge combination of buttons that reset the printer. there are many possiblities due to the modles - but try pressing any 2 and whilst holding them down switch off and then on again. Also this utility could proce use full. When it is loaded -right click the task bar icon. www.ssclg.com
Oct 02, 2007 | Epson Stylus C86 InkJet Printer
Lexmark X3350 All-In-One InkJet Printer Logo
272 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
