Question about Bosch Logixx WFR 2466 Front Load Washer
I have a hotpoint aquarius 1000, model WM62, the drum will not go round at all, it is totally seized up, does this mean the motor has gone.
  • 118 Answers
If the drum wont move even manuly u move it it is stuck the barings at the back of the drum have gone so it looks like you need to get it repaired cus it is a big job fixing a problem like you got.hope this helps
Posted on Sep 02, 2009
Hotpoint aquarius 1000 extra
have you checked belt or brushes in motor
Jan 26, 2012 | Hotpoint Washing Machines
Drum will not go round on cycle
sounds like your motor brushes have gone depending on what make of washing machine you have I cant help you futher it is difficult to solve without make or model
Oct 18, 2011 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Aquarius 1000 WM62 The drum makes a screeching noise when turning ? Any ideas ?
it could be drum bearings or even some thing that has got past the inner drum and is jamed inside hitting the drum when it turns,,,,could also be the motor bearings,,,,open the door and try lifting the inner drum up,,if there is any lift in it then the drum bearings are going,,this will also cause it to screem on spin speed
Dec 01, 2010 | Washing Machines
Hotpoint aquarius 1000 WM62 leaks from the bottom at the front of the machine towards the end of the cycle. How do I fix this?
Carefully exmine the door seal for a hole or split, remove the clamp ring round front and pull seal of front of cabinet and check it carefully, if no sign of leak from seal, then it is going to be leaking from the plastic drum front of washer.
This will entail removing tye front panel.
Hope this helps.
Jan 17, 2010 | Washing Machines
Door won't open
Usual reason for this is not emptied correctly. The filter on this model is in an awkward place so try lowering drain hose into a bowl to check if water still in.
Nov 11, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint wd420
if the drum is tight to turn ,then the main bearings have probably seized, or their could be something fast in the drum. Remove belt, and try to turn the drum by hand , it shuold be free with no resitance.
If it is noisy or feels rough, then the bearings have gone.
Sep 01, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius 1000 WM62 motor problem?
hotpoint aquarius 1000 if motor is connected (plastic plug in socket) RCD earth trip trips in main board when washer is switched on, trips as soon as water starts to fill.
Oct 16, 2007 | Washing Machines
Bosch Logixx WFR 2466 Front Load Washer Logo
271 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
