Question about Apple iPod classic MP3 Player
Ipod only works when plugged in
My ipod is fully charged but it will only play when plugged in the electrical outlet. It doesn't work when unplugged and it doesn't work when plugged in the computer (when plugged in the computer the screen stays black with a faint apple logo in the middle)
Try this link:
The 5 R's
Posted on Mar 08, 2009
Apc hi800sq
follow this steps and fix it. God bless you
Plug the battery backup into a working electrical outlet. If the battery backup turns on when the power button is pressed, then the problem may be that the previous electrical outlet is faulty. Proceed to step three. If the battery backup doesn't turn on, proceed to step two.
  • 2 Reset the circuit breaker on the battery backup. APC battery backups have a labeled circuit breaker button located on the unit near the phone line, fax line, USB, network and coaxial cable inputs. Press the button to reset the circuit breaker. Power on the battery backup by pressing the power button. If the battery backup powers on, proceed to step three. If the battery backup doesn't turn on, proceed to step six.
  • Read more: http://www.ehow.com/how_7266444_troubleshoot-apc-battery-backup.html#ixzz2lwOvPO75
  • 3 Determine if the battery backup is charged and providing battery power. With the battery backup on and plugged into a working electrical outlet, plug a computer monitor into one of the battery backup outlets labeled "battery backup plus surge protection" on the battery backup. (APC power supplies have some outlets that provide only surge protection while the other outlets provide surge protection plus battery backup.) Turn the monitor on. Unplug the battery backup power cord from the wall outlet. If the monitor remains on, the battery is holding a charge, supplying electrical power and the battery backup is working properly. If the monitor goes off, proceed to step four.
  • 4 Charge the battery. Plug the battery backup into an electrical outlet and allow the battery to charge for 16 hours. This will fully charge the battery.
  • 5 Test battery charge. Once the battery is fully charged, repeat step three. If the monitor stays on when power is interrupted to the battery backup, the issue is solved and the problem resulted from an incompletely charged battery. If the monitor turns off when power is interrupted, the battery within the battery backup is faulty and needs to be replaced.
  • 6 Replace the battery backup unit. The unit itself is faulty. If the battery backup is under warranty, contact APC to request a replacement.
  • Nov 28, 2013 | Computers & Internet
    Tip
    How do I charge my iPod touch for the First Time
    <p>Apple iPod touch is a personal audio player with the ability to store and play MP3 files, digital video and downloadable games and applications. The unit is powered by a rechargeable battery. When charging the battery for the first time, ensure that the battery is fully charged. From there you can turn it on or removing the device from the charger, if desired, regardless of battery level. <br /> <p><br /> <p>1. Enter the main connection for the iPod cable to the socket at the bottom of the iPod touch. <br /> <p><br /> <p>2. Insert the small plug into a USB port on your computer. Turn on the computer. Alternatively, an iPod charger, sold separately, you can recharge your iPod touch with a socket. Connect the wall charger into an AC outlet. Insert the plug on the door of the small wall charger. The battery icon located in the upper right corner of the screen, the battery is charging. <br /> <p><br /> <p>3. Let the battery fully charged. When the battery icon to indicate the device is fully charged, remove the iPod from the cable. <br />
    on Aug 09, 2011 | Apple iPod touch
    Tip
    How to convert 220 volts to 110 volts for the iPod Touch
    <p> <p>The battery of an iPod Touch prepared for use in the United States is designed to be reloaded from the current supplied by a 110-volt electrical system. Power is transmitted to the battery charger with an iPod battery, which are connected via a USB cable and then connected to a 110 volt outlet. To use the power of a 220 volt outlet with an iPod Touch, set the current 220 volts to 110 volts. A conversion adapter voltage, also known as "Step Down Transformer," it is necessary and can be obtained from an electronics store, a hardware store and even some drug stores. <br /> <p><br /> <p>1. Place the 220-110 voltage converter card (aka, "Step Down Transformer") next to a 220 volt outlet. Plug the adapter into the outlet. <br /> <p><br /> <p>2. Connect the end of a USB cable to the USB connector USB iPod charger iPod. Connect the other end of USB cable into your iPod's own socket on the bottom of the iPod Touch. <br /> <p><br /> <p>3. Plug the iPod into the 110 volt outlet in the battery adapter for the iPod Touch. <br /> <p><br /> <p>4. Unplug the charger from the iPod adapter and the adapter from the outlet when the battery is charged. Unplug the USB cable from the iPod charger and iPod Touch. <br />
    The UPS in this office is out of order, message that appear on screen is 'UPS V OUT LIMITS' and 'Battery critical'
  • Nov 28, 2013 | MGE NOVA AVR 1100VA Tower UPS 81111 UPS...
    My sp will not charge, I am not sure if it is the battery or something else
    Game Boy Advance SP - Charging Light Won't Display If the orange-colored charge light on your Game Boy Advance SP is no longer coming on when the A/C Adapter is connected to your system, please use the following troubleshooting steps.
      Troubleshooting Steps:
      1. Make Sure the Game Boy Advance SP Isn't Already Fully Charged
        If the battery is already fully charged, the light will not display when the system is plugged into the AC Adapter. Play a game without using the AC Adapter for at least 10-15 minutes, then plug the AC Adapter in, to see if the light comes on. If it does come on, the battery was fully charged. If the light still does not come on, see Step 2.
      2. Make Sure the Outlet You Are Using Works
        Plugging another electrical device into the outlet is a good way to check if the outlet works, or that the outlet you are using is not controlled by a nearby light switch. You may also want to try a different outlet.
      3. Try a Different Licensed AC Adapter
        If the charging light doesn't display, try a different AC Adapter, if possible, to determine if perhaps the problem is with the adapter.
        • If a different AC Adapter works, you will need to get a replacement AC Adapter from our Online Store, or by calling our Consumer Service Department at 1-800-255-3700.
        • If a different AC Adapter doesn't work, or if a replacement AC Adapter is not available and the lights will not display, we recommend having your Game Boy Advance SP repaired. Check out our convenient repair options.
      Note: Please be sure to include both the Game Boy Advance SP and the AC Adapter with any repair
    Sep 02, 2011 | Nintendo Game Boy Advance SP Console
    How do I re charge battery with electrical plug
    To charge the battery using your computer:
    Connect iPod shuffle to a high-power USB port on your computer using the included iPod shuffle Dock. The computer must be turned on and not in sleep mode (some models of Macintosh can charge iPod shuffle while in sleep mode). When the battery is charging, the status light on iPod shuffle is orange. When the battery is fully charged, the status light turns green.
    If you don't see the status light, iPod shuffle might not be connected to a high-power USB port. Try another USB port on your computer.
    To charge the battery using an iPod USB Power Adapter If you do not have then you have to buy the same from Apple Store) 1 Connect the AC plug adapter to the power adapter (they might already be connected). 2 Plug the USB connector of the iPod shuffle Dock into the power adapter. 3 Plug the power adapter into a working electrical outlet. 4 Put iPod shuffle in the dock. You can disconnect and use iPod shuffle before it is fully charged.
    Apr 05, 2011 | Apple iPod shuffle MP3 Player
    My Altec Lansing Inmotion used to charge my Ipod Touch, but since yesterdag (after not using it for 3 weeks) it won't charge my Ipod anymore. The Altec charges itself, but somehow the Ipod doesn't. It is...
    That is a tough one. Is your iPod fully seated -- will it play music in the im600? Have you tried a different iPod in the im600 to see if it charges? Does your iPod recharge normally in other players, in a wall charger and your computer? If not, your iPod could possibly need a new battery.
    Also: since it was unplugged for 3 weeks, you may just need to run the im600 through a full cycle or two (let the FM radio play until the battery is dead, with no iPod in it), then recharge the im600 for 5 or 6 hours, and THEN mount your iPod into it and see if it charges it. Be sure to unplug/plug-in the adapter into the im600 to ensure it is getting full power from the wall outlet. One last thing: the im600 will only charge the iPod when it is plugged into AC power; it won't charge the iPod while it's running on its own battery power. Good luck!
    Jan 16, 2011 | Altec Lansing Inmotion-IM600...
    How do i turn on my ipod shuffle?.......and how long do i charge the battery for?... and how do i know my ipod is fully charged?
  • first i will cover turning the unit on. then i will cover how to charge the unit.
    -Move the power switch on the top of the iPod Shuffle to the "Normal" or "Shuffle" position.
  • Press the play button on the iPod Shuffle to begin music playback. If the iPod does not begin to play, follow the rest of the instructions.
  • Plug the iPod USB cable into the bottom of your iPod Shuffle and then connect the other end of the cable to your iPod power adapter.
  • Plug the iPod power adapter into a standard electrical outlet to charge the iPod Shuffle's battery. Try to press the play button again.
  • Connect the iPod Shuffle to your Mac or PC computer using the iPod USB cable. Then, open the iTunes program on the computer and sync your iPod with your music library. If your iPod Shuffle was frozen, it should now turn on.
  • to tell if the ipod shuffle is charging. Eject iPod shuffle in iTunes, but leave it physically connected to the USB port. The front LED should be orange if it's charging (or green if it's fully charged). If it's not charging (such is the case if it's connected to a low-power USB port on a keyboard), you won't see a front LED. If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
    Aug 25, 2010 | Apple iPod shuffle Second Gen. Silver (1...
    8 GB Ipod Nano went dead and now won't charge
    does it work on the charger? if not, then contact apple or your dealer for more assistance or repairs.
    If it works on the charger, plays music and so on, your battery is probably dead and you need a new one.
    Mar 24, 2008 | Apple iPod nano
    Black 80gb ipod Video
    Try resetting it. Hold down the Menu and middle button at the same time until the screen gets dark.
    If that doesnt work, Restore it. Plug it into the computer and click "restore" when it pops up in itunes. Please note that this will erase all data on the device.
    Nov 14, 2007 | Apple iPod MA446LL/A MP3 Player
    Apple iPod classic MP3 Player Logo
    638 people viewed this question
    Top Apple Audio Players & Recorders Experts
    Nagendra Baliga
    Computer Repairing
    Computer Repairing
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
