Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Big black dingemalieries after wasching with the machine
When the washer is finish and the clothes where taken out sometimes there is black things on the clothes i dont know what can cause this
  • 25 Answers
Sounds like something foreign got dropped into the tub with the laundry.try washing some rags.if still there,remove agitator and inner tub.
Posted on Mar 08, 2009
Washer sometimes doesnt finish I go to put clothes in dryer and they are still dripping wet but washer is off
Do you get a error code on the machine? There can be many problems that cause the machine not to go into spin mode. Need more info
Dec 05, 2011 | LG WM-2277HW Front Load Washer
The washer goes through the entire cycle and then just before it should be finished....it signals ND - sounds as if it is stopping then unlocks. Only problem is....there is still water in the basin....it...
ND stands for No Drain. This can be cause by 2 things, first being the rotor on the drain pump is broken or falling off. Second, there could be a piece of clothing partially clogging the pump so it works sometimes but not always.
Dec 01, 2010 | Maytag Neptune MAH5500B Front Load Washer
After completing a load of clothing, the laundry sometimes has a moldy smell. If it doesn't smell right away, it smells after wearing the clothing and sweat a bit. This is not a body smell - this is a...
It sounds like your leaving the clothes in the washer long after the cycle is finished. Once your clothes smell from the washer they will smell moldy dry.
Aug 19, 2010 | Dryers
I have a Kenmore N2. What would make my front load washer fill back up with some water after the drain and spin cycle is complete?? IF I let the washer go until it's done and go downstairs to take out,...
first, run a rinse,drain & spin cycle. after it finishes filling, shut the water supply (taps) off. If water enters the washer after the drain, it has to be sifoning back in from the DRAIN hose. Check to see if the drain hose is not going up above the washer more than a few inches
Dec 03, 2009 | Kenmore Washing Machines
The clothes come out with a musty smell
This is caused by several things. No softener, softener not only softens the clothes, but also the water. Try this and I think you'll find your clothes will smell better. Also before you do your next load do a wash with nothing but a gallon of bleach. Sometimes if there is sometime between loads mildew will build up. Also keep your lid up between loads to let it air out. If you have cat's or kids check before you wash, ha, ha. But seriously. Let me know if I can help with anything else.
JimmyC
Sep 25, 2009 | GE WSXH208A Front Load Washer
LG washing machine has AWFUL mildew smell
Don't know if this is the same as your problem, but I had a Kenmore washer, (made by Whirlpool) that did the same thing. It was a high efficiency model without an agitator. I finally found out that this type of washer never drains completely but always has some water left in it. This water is somewhere internal that cannot be seen unless the machine is taken apart. That water goes bad and stinks. Everything smelled like mildew and for some while my husband thought I was was washing clothes and leaving them in until they dried. I ended up having to just buy a new machine and when the stinky washer was taken away, just tilting it caused all this foul water to come out everywhere. Also I found this on the internet http://www.consumeraffairs.com/homeowners/lg_washing_machine.html
scroll down and see how other people feel about this machine. I decided that instead of buying the newest, latest, greatest, with all the bells and whistles appliances, from now on I will buy the time tested, plain jane models.
Jun 02, 2009 | LG WM-2277HW Front Load Washer
Leaves spots
YOUR BEARINGS ARE GOING THE BLACK SPOTS ARE GREASE FROM THE BALL RACER RING THEY SIT IN, IT WILL ONLY GET WORSE & EVENTUALY YOU WONT BE ABLE TO GET IT OUT OF YOUR CLOTHING & THEN YOU DEVELOPE A PUNGENT SMELL THAT WONT GO UNTIL IT IS FIXED, YOU CAN CHANGE THEM YOURSELF BUT IT IS NOT EASY FOR SOMEONE NOT KNOWING WHAT THEY'RE DOING, SORRY, I HOPE THIS HELPS A BIT...
May 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
At the end of each spin cycle it knocks loudly
A Clothes Washer with the complaint of "excessive noise & sssshaking" can typically be a couple of things;
Un-level Washer (Very Likely) - I would level and adjust your legs on your washer appropriately. Make sure when your slighly "push test" your washer, you have no machine movement, rocking or tilting. When the machine is going into the final rinse/spin cycle, the tub can rotate fast and if the washer legs or even the floor is slightly un-level, this can result in your washer to become noisey, shake, etc and can further cause the unit to break-down and no longer spin.
Un-balanced Load (Likely) - Ensure you are loading the washer and distributing the clothes (weight) evenly as this may cause the tub to spin improperly at final spin cycle.
Broken Drum Support/Springs (Likely) - Can be 5" black supports located at inside - top of tub area. Also, springs can also be located at inside bottom rear of machine holding the tub to the rear panel.
-C
Fremont, CA
Jan 29, 2009 | Kenmore 24032\24036 Top Load Washer
Cloths were soaked !Won't restart, door locks and you hear a buzzind sound ??
Greetings JohnnyWrench,
Information provided by the manufacturer would indicate a few things possibly causing this:
1) Washer was overloaded, remove some of the clothes and continue the cycle.
2) Washer load was too small. Add 1 or 2 similiar items to help balance the load.
3) Load is out of balance, rearrange clothes to allow for more balanced spin.
4) Drain hose might be kinked, straighten drain hose.
You can also find a copy of your owners manual at
http://www.frigidaire.com/products/laundry/washers/front_load/prod_ATF7000FS.asp
I hope some of this helps!
Thank you,
Dorothy
Go Ahead. Use Us.
Apr 30, 2008 | Frigidaire Affinity ATF7000E Front Load...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
