Question about Whirlpool Dryers
I have a whirlpool model LER7646DQ0 dryer. I have
I have a whirlpool model LER7646DQ0 dryer. I have had to play with timer knob sometimes to get it to run or to stay running, then yesterday it just stopped working. Would this be the timer itself or could something else cause this to happen. I have cleaned the lint trap and the vent.
catriver
  • 878 Answers
SOURCE: Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
Posted on Jan 01, 2008
ronpar
  • 27 Answers
SOURCE: Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Posted on Jun 29, 2008
  • 77 Answers
SOURCE: lint fell back into lint trap. how can i get it out? already looked in back.
An appliance store can sell you a brush that is attached to a long wire. It is made specifically for removing lint from dryers. I have seen them at walmart and other places but for sure at an appliance store. Good luck.
Posted on Apr 20, 2009
SOURCE: Keep getting error message AF druing drying cycle and I've cleaned the lint trap.
check for clog or kink in dryer vent
Posted on Jun 10, 2009
  • 66 Answers
SOURCE: Whirlpool Duet dryer not drying like it used to
If your duet isn't heating properly and you have taken care of the lint problem then you could have one of two problems. Either you have a bad heating element or you have a bad fuse or temperature sensor.
If your dryer is not heating at all then it is most likely the fuse or temp sensor. If it is heating and just not enough it is probably a bad heating element.
Both problems would require a repairman to come and fix normally, however if you believe it is the heating element that can usually be replaced by the homeowner without too much trouble. Just make sure to ask where it is located from whatever place you but the new element from.
Posted on Dec 12, 2009
My Whirlpool LEB6300PWO will randomly not start, or will start but only run briefly then stop. I know these types of problems are not usually related to the timer, but we have found that by either lightly...
Hello, we are sorry to hear that you are having this problem with the Dryer. We would recommend having a certified technician out to take a look at the Dryer and give a proper diagnosis. If you would like further assistance you can reach out to us with your name, phone number, address, model/serial number and the date on which you purchased the Dryer to Whirlpool_Reviews@Whirlpool.com.
Apr 17, 2017 | Whirlpool LEB6300 Electric Dryer
Whirlpool dryer model #LER8620PWD serial #MS3630316. I need to hold down the start button and rotate the timed cycle knob for dryer to turn on .
Sounds like you have bad contacts in your timer. By holding the start button and rotating the timer you are just finding a good contact point and allowing timer to send power to the motor. The timer part number is 3979618 and will run you about 90 bucks. hope this helps
_MJ_
Dec 14, 2010 | Whirlpool Dryers
I have a broken wash cycle timer knob on my whirlpool LTE5243BN0 thin twin washer/dryer. Ordered a replacement part, looks the same as my old one, threads okay, can't seem to screw it all the way on. The...
you might have broken something else off of the timer go here
https://www.repairclinic.com/PartDetail/Timer/WP3946432/4434024
is the white part still on timer shaft?this is the piece that the indicator knob slides onto so it's not loose and free spinning,i looked up your model and the indicator knob is no longer available
www.searspartsdirect.com/model-number/LTE5243BN0/1198/0152000.html?searchType=modelSearch&q=LTE5243BN0&searchTerm=LTE5243BN0
go here and you can see your machine
Oct 01, 2017 | Whirlpool LTE5243D Top Load Stacked...
Hi my dry had a broken timer knob and the dryer would work if I pushed the knob I got a replacement part but dont know how to rewire it agen and the part looks different the old one had T80 on it but this...
Your timer switch should come with a wiring diagram.
Check with the supply house you got the timer from and let them make sure you have the right part for your model dryer.
Sometimes the new timer will be different, that is where the wiring diagram comes into play.
I hope this helps
Oct 01, 2009 | Fisher and Paykel Dryers
Whirlpool Ultimate Care II Dryer timer knob
The timer cam is not aligning the internal switches. Replacing it is the only fix.
Eric
Sep 17, 2009 | Kenmore 62602 Electric Dryer
Dryer won't run unless I put pressure on the cycle control knob after pressing Start
sounds like you need to replace your timer, or either unplug the machine, an open the head panel an see if any wires are loose in there, changing the timer is an easy job, you should have no problems doing it ......good luck!
May 27, 2009 | Whirlpool LGR8648 Gas Dryer
I HAVE A WHIRLPOOL DRYER. TURN THE TIMER SELECT ON. THEN TURN START KNOB TO ON, THEN PRESS THE SAME KNOB IN TO START CYCLE. YOU CAN HERE THE TIMER AND SOUNDS LIKE THE CONTACT IS WORKING, BUT CYCLE WON'T...
Hello dacarle,
Welcome,
You said, I HAVE A WHIRLPOOL DRYER. TURN THE TIMER SELECT ON. THEN TURN START KNOB TO ON, THEN PRESS THE SAME KNOB IN TO START CYCLE. YOU CAN HERE THE TIMER AND SOUNDS LIKE THE CONTACT IS WORKING, BUT CYCLE WON'T START.
Please send me the model number so i can check out the problem.
Waiting your response
Huuum
Oct 15, 2008 | Whirlpool Dryers
Ler7646dQ0 dryer runs only for 2o mins; won't run or start in other positions
Hopefully it's been already mentioned or looked at but check your vent to the outside. Make sure it's not kinked or blocked up with lint. Don't forget to check the outside too!
Oct 14, 2008 | Whirlpool LER7646E Dryer
Dryer only starts sporadically
your headed in the right direction. there are contacts inside the timer that have gone bad. the timer is in the console ofcourse. its not hard to replace and replacing it will solve your problem
Nov 25, 2007 | Whirlpool LEB6300 Electric Dryer
Dryers Logo
120 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
