Question about Microsoft Windows 2000 for PC
I try to boot my computer from a windows 98 disc, but it won't lo
I try to boot my computer from a windows 98 disc but this thing keeps popping up.
DISC BOOT FAILURE INSERT SYSTEM DISK AND PRESS ENTER
    Problem Solver:
Hi matthewbugbe,
I think what that means is it does not recognize your hard drive. If you are trying to install Windows 98 you should format your drive first.
Posted on Mar 08, 2009
Need to reboot computer,windows98,invalid disk error
You have to go into your BIOS and select booting from Disk not hard drive when i say disk i mean either the cdrom or dvd disk players attached to your motherboard. also you can get a boot disk to try that at the link below.
http://www.allbootdisks.com/download/98.html
Apr 07, 2012 | Computers & Internet
Trying to run my old HPP game in windows 7 but can't get compatability
There is a good chance that you won't be able to run that game on windows 7 with any sort of compatability mode. There is however another more advanced method that can be used to run very old games. You can set up a virtual machine on your windows 7 operating computer, and on this virtual machine install an earlier copy of windows, windows 98 for instance, which will run the game just fine.
To do this you need a copy of windows 98, thats the easy bit.
Then you need to download and install Windows Virtual PC and check your software compatibility. The download link can be found here.
Once you have Windows Virtual PC installed then you will need to set up your first virtual machine.
  • Start up the program
  • A wizard will pop up and help you through the creation of your first VM
  • Select "Create Virtual Machine" and then click Next
  • Select the Name For Your VM then click Next
  • Then from the drop down menu to the left select Windows 98 and click Next
  • Select "Using The Recommended Ram" then click Next
  • Select "A New Virtual Hard Disc" then click Next
  • My Suggestion is to leave these at Default, then click Next
  • Check over the details and click Finish.
That should see your first VM Setup. Now go to the Virtual PC Console, select the VM you just created and click start. You should see a window that pops up showing what appears to be a PC starting up. That is the virtual PC starting up just like your pc would. Starting up for the first time can take quite a while so be patient.
The VM should then display the message "Reboot and Select proper Boot Device or Insert Boot Media in selected Boot device".
It's at this point you need your copy of Windows 98, on you VM window you will see on the menu bar at the top of the window the drop down "CD" click on this and select your disc method, which CD drive the disc is in or if it's an ISO file select that option.
Once you have that selected then:
  • Press the space bar and the screen should change
  • Select boot from CD-ROM, press enter
  • Select Start Windows 98 Seyup from CD-Rom, press enter
  • Press Enter when promted to
  • Select Configure unallocated disc space, press enter
  • Select, "Yes, Enable large Hard Disc Support". press enter
  • Press Enter when promted, the VM will now restart
  • Repeat the first 3 steps
  • Setup should now be formatting your virtual hard drive
  • Press Enter when prompted
  • The Windows setup Wizard should now be running
  • Follow the wizard through and Windows will start installing
  • During this process the VM wil restart several times
  • Once the VM restarts and again promts to start from CD-Rom or Hard Drive, select Hard Drive, then press enter.
  • Once your VM starts up in Windows 98, proceed with the installation of the game and any other software it needs.
Once you've done all this you will have the perfect compatibilty platform set up for any old games you own, as it is Windows 98 not some mode stuck on the side of you version of windows.
This is quite a long and complicated method, but it will work and it will allow you to play just about any pre 2000 game going.
May 03, 2011 | Wanderlust Interactive Pink Panther Hokus...
My widows (compaq)98 have crashed or got deleted.
Corrupt hard drive or boot table. Only solution is to attempt a reinstall with the original 98 disc.
Dec 20, 2009 | Microsoft Windows 98 for PC
How do i erase windows 95 and replace it with windows 98?
you get a copy of windows 98, pop in the disc, click upgrade (or fresh install if you don't wanna keep anything), and let her install. About 45 minutes after it reboots you should check on it because it has a dialog box for you then.
Sep 27, 2009 | R.A.M. Computers Featron FT6750, Pentium...
Cannot boot up from CD-Rom with Win 95 and Win 98
You probably have a version of windows 98 that was not bootable on CD. You would need to boot from a windows 98 floppy bootup disc, then go the the d:\win98 directory and run setup from there.
May 26, 2009 | Intel Computers & Internet
Reminder has stopped working on MS Works calender
your anti virus is blocking the pop up for your reminders .... Try to restart the cmputer in windows safe mode ....
Ti restart in windows safe mode > When you computer restarts keep tapping F8 key till you get advanced boot option using up and down arrow select windows safe mode and hit enter
if it is working in windows safe mode then its your antivirus Soft ware blocking reminder pop up
Let me know if it works
Apr 20, 2009 | Microsoft Windows 98 for PC
Unable to start in Safe Mode with Command Prompt in XP Media Center 2005
Hi there. My name is Alex and I am here to help solve this problem
Depending if the BIOS has legacy USB support for keyboard and mouse enabled, you should be able to run safe mode by pressing F8 before the computer boots into windows. I would not recommend going into the BIOS if you do not have much knowledge to the computer as one wrong configuration could cause some behaviour problems or even damage to the pc's components
I recommend connecting a keyboard and mouse that have cable and the PS/2 connectors (purple and green) which can be found at back of the computer at the top. Then restart your computer, hold down F8 and you will be able to run safe mode. The mouse and keyboard will then work
Keep both the keyboard and mouse plugged in and boot windows. When you get into windows, plug in the USB keyboard and mouse into a USB slot and wait whilst it detects it. After a couple of minutes you should be able to use your USB mouse and keyboard and take out the PS/2 keyboard and mouse
I hope this has helped. Please let me know if you have any questions or need further assistance.
Oct 03, 2008 | Microsoft Windows XP Media Center Edition...
Computer won`t boot
u will have to reformat the hard drive and load win 98 or win xp whichever u want to fix this
you can have more detailed info at
http://www.computerhope.com/issues/ch000474.htm
Jan 31, 2008 | Computers & Internet
Microsoft Windows 2000 for PC Logo
62 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
