Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
Beater bar belt broke. how do you replace it?
  • cj122 Apr 04, 2009
    What are you calling a glide plate and how do you remove it if the belt isn't broken?
  • 134 Answers
Remove the glide plate, take out the brush and broken belt.
Refit new belt and roller. re fit glide plate
away you go
Posted on Mar 08, 2009
Beater bar does not work
Make and model may help you get an answer.
Nov 02, 2017 | Vacuums
The beater bar will not turn. I have cut all the hair and lint off but it still will not trun.
is the belt broke ? also try taking the beater bar off the vacuum and then checking the end roller bearings. clean and lubricate with some light oil. make sure belt is solid.
Dec 17, 2010 | Vacuums
The belt broke on my vacuum, how do i change it. the vacuum is a eureka model number 3041
Remove the base plate. It is held with screws accessible from under the unit.
Inside you will see the beater bar and the belt.
Remove the beater bar. This is self explanatory once you see inside the power head.
Remove the old belt.
Find a replacement from your local dealer or online.
Replacement is the reverse of removal.
This is a simple job you only need a screwdriver.
Good luck, please rate this answer. Thanks.
Mar 27, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
The beater bar on my Dyson won't turn. The vacuum runs and suctions but the bar won't turn and the belt is not broke. The beater bar did get a carpet fiber caught and wrapped around it which stopped the...
The belt doesn't have to be broken to make the vacuum not work correctly. If the belt is stretched the vacuum won't operate the way it is supposed to. You can get replacement Dyson Belts here:
Dyson Replacement Belts
Dec 06, 2009 | Vacuums
Belt replacement
It's a fairly simple job. The belt just loops over the end of the beater bar and motor shaft. Need to take the cover off the beater bar housing to get to it. Most difficult part is stretching the belt while putting the beater bar back in the housing.
Aug 30, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
The brush isn't spinning
the belt is broke. you can buy a new one for around 5-10 dollars at target or walmart, or loews or homedepot.take the screws of the bottom panel to expose belt. you will have to pull out the beater bar to replace the belt. just pull on it after the bottom plate is removed the beater bar just slides out. slide the new belt down the beater bar then pull the belt over the spinning pin. now stretch the beater back to its original position it should slide right in. replace the bottom plate and your back in business
Jul 12, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Smell coming from vacuum when using beater bar
Check to see if the Belt is broke or a build of dirt is were the belt is . Make sure the beater bar is sitting in place .Best of luck Ed.
Jun 18, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Beater bar
on the bottom take out 2 screws they are closer to the back wheels pull off cover there is a plastic cover over the beater bar take off there is a belt if it broke or wore out change the belt that should fix your problem
Jan 07, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
How do i replace a belt?
on the bottom above the beater bar there should be two deep set screws one on the right and the left take them out. =you can use a flat blade screw driver to pop the sides off you should see the gap at the edges the belt if there is one left would be attached to the beater bar replace the belt .should all go back together same way it came apart. hope this helps ya.
Dec 01, 2007 | Vacuums
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
211 people viewed this question
Top Dyson Vacuums Experts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
