Question about Nintendo Wii Fit for Wii
How do you change the weight settings from kg to lbs
Change weight settings from kg to lbs
  • 1 more comment
  • harleyrebel Mar 16, 2009
    before i sent my wii away for repair it weighed in stones & pounds now it weighs in kilos! does anyone know how to change it back?
  • My reply is May 11, 2010
    Change them on what? or do you mean how do you convert Kk to lbs?
  • Anonymous Mar 20, 2014
    5.3kg to lbs
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 117 Answers
I don't know if you can change the setting but 1 kg is 2.2046 lbs so 100 kg would be 220.46 lbs for example. Multiply kg times 2.2046 to get lbs
Posted on Oct 22, 2009
How do I change from cm/kg to inches/lbs?
No can do. Cm is distance and Kg is weight. Inches are distance and pounds is weight. Thats like "how can I convert an orange into an apple. RJ
Jan 21, 2016 | Schiller Cardiovit At 2 Light Ecg Machine
To convert 15:3 to kg
"15:3" is a ratio, "kg" is a measure of mass (or weight). Your question is like asking how to convert one-half to pounds.
Do you want to convert 15 lbs to kg? That would be about 6.80 kg.
Or do you mean 15 lbs 3 ozs? That would be about 6.89 kg.
Or do you mean 15.3 lbs? That would be about 6.94 kg.
Or, since 15:3 is 5, do you mean 5 lbs? That would be about 2.27 kgs.
Dec 05, 2013 | Office Equipment & Supplies
Treamill 9500hr is reading weight in pounds and not kg
Please go to the Menu, and go to the section go caractheristic and change the Lbs to Kgs.
God bless you
Jan 09, 2013 | Life Fitness 9500HR Next Generation...
On my "Ideaworks" wireless electronic display
After playing with the remote on this scale for about 30 minutes, I finally found out how to change this display from kg to pounds or stones. Since this scale doesn't come with an instruction manual, I know a lot of people are totally lost. OK, first click the user button once, so that the weight and goal weight show. Then hold down the clock/set button. After a few seconds the kg on the screen will start blinking. Then use your arrow buttons to switch to stones, then to pounds. The lb will show at the top of the display above where the kg was. You can also set your goal weight by pressing the set button and scanning through after setting the lbs setting. Hope this helps!
Aug 22, 2011 | Jobar International Ideaworks Remote Read...
What are the dimensions of the bebecar m city?
The details are as follows ;-
1. Chassis folded size - 36.6 in X 20.5 in X 8.7 in
(93cm X52cm X 22cm)
2. Chassis weight - 25 lbs (11.4 Kg)
3. Carrycot weight - 15 lbs (7 Kg)
4. Seat weight - 13 lbs (6 Kg)
5. Seat width - 13.4 in (34 cm)
6. Handle height - 37-42.9 in
7. Wheels - Swivel
8. TSC - Yes
Good Luck!!
Thanks!!
Aug 14, 2010 | Bebecar M City Stroller
Towing capacity for an Isuzu I370 pickup
As listed in the owners manual.
Weight of the Trailer
How heavy can a trailer safely be?
It depends on how you plan to use your rig. For
example, speed, altitude, road grades, outside
temperature and how much your vehicle is used to
pull a trailer are all important. It can also depend
on any special equipment that you have on
your vehicle, and the amount of tongue weight the
vehicle can carry. See “Weight of the Trailer
Tongue” later in this section for more information.
Maximum trailer weight is calculated assuming
only the driver is in the tow vehicle and it has all
the required trailering equipment. The weight
of additional optional equipment, passengers and
cargo in the tow vehicle must be subtracted
from the maximum trailer weight.
The following charts show how much your trailer
can weigh, based upon your vehicle model
and options.
2WD Extended Cab Axle Ratio Maximum Trailer Weight GCWR*
Automatic Transmission,
2.9 L Engine 3.73 3,100 lbs (1 406 kg) 7,000 lbs (3 175 kg)
Manual Transmission,
2.9L Engine 3.73 2,100 lbs (952 kg) 6,000 lbs (2 721 kg)
4WD Crew Cab Axle Ratio Maximum Trailer Weight GCWR*
3.7L Engine 3.73 4,000 lbs (1 814 kg) 9,000 lbs (4 082 kg)
*The Gross Combination Weight Rating (GCWR) is the total allowable weight of the completely loaded
vehicle and trailer including any passengers, cargo, equipment and conversions. The GCWR for your
vehicle should not be exceeded.
Aug 26, 2009 | 2006 Isuzu I 370
Need instructions on how to reset to show weight
how do I change scale from kg to pounds?
Mar 16, 2009 | Health & Beauty
Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Mar 13, 2009 | Tanita 2204 Body Fat Scale
Tanita 2204 Scale weight reading problems
Try the following steps:
1) press both the "set" and the triangle button
2) press the triangle button until you get the desired unit of measurement: a) Kilogram, b) stone lbs or c) lbs; and
3) press the "set" button.
Nov 16, 2008 | Tanita 2204 Body Fat Scale
Nintendo Wii Fit for Wii Logo
960 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
