Question about Hardware & Accessories
Lock is becoming loose and cannot tighten - Hardware & Accessories
    Problem Solver:
  • 9 Answers
The knob part in the door use lock tight on screws. The screws in the frame/jam you have to drill out and glue in a dowel pin Then you can rescrew the screws in after the glue drys for at least 30 mintues to 1 hour the longer the better.
Posted on Jun 08, 2009
How to tighten loose handles on the 2 handle Delta Vessona kitchen faucet model #21925LF
usually have a setscrew in them!! mine are allen heads very small
Feb 11, 2015 | Delta Plumbing
2013 f-150 xlt. what causes column to become all loose and sometimes wont allow key into lock position, and how to fix it
You'll need to pull the steering wheel, and tighten the screws securing the tilt mechanism to the column. If it has been loose for a long time, you may also need to replace the bearing at the turn signal switch canceller.
Aug 02, 2014 | Cars & Trucks
My gear shift seams to be real loose . when shifting up gear there's no problem , but when i down shift it's real loose and feel like it's slipping all the way to 1st gear
There are two places at the shift leaver that could be the problem. there is a nut and lock-nut together on the shift rod. you can loosen the lock-nut, adgust the play in the rod and then tighten the lock nut (sometimes this is behind a cover plate). Also, the leaver can become loose where it is attached to the splined shaft comming out of the transmission case. This must be tight. It may have slippped. It must be possitioned in a spot that makes it centered so that when shifting either up or down... it feels right. When you get it just right tighten with locktight compound so it doesn't come loose easily. If this is loose for very long, the teeth on spline or the leaver will strip out. Hope this helps.
Jul 24, 2011 | kawasaki VN 1500 Vulcan Meanstreak...
Lock is loose in the door
You should just have to tighten up the screws, they loosen up from trucks going by. If you don't have trucks, it must be earth quakes or something rattling your house. We have a church on the highway and have to tighten up the locks every month. I didn't believe it either, but it's true.
Feb 22, 2010 | Kwikset Professional Door Lock...
How do I tighten a Delta kitchen faucet that has become loose?
If it is faucet body on sink loose under sink there should be screws and a plate or washers holding it sink. Tighten them up.
Some have a bolt or nut in the middle requiring a socket to tighten.
If the spout is loose remove handle and it has a plastic ring on top to tighten spout up.
Feb 13, 2010 | Delta Faucet Plumbing
Handle has come loose, just spins.
Most likely the screw in the center of the handle has become loose and just needs to be tightened. Pop off the cover with a screwdriver. and tighten the screw.
Jan 20, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Screen loose
Do you mean the screen hinges have become loose? If so they cannot easily be tightened as they need very high torque.
Jan 03, 2010 | Dell Studio 1537 Laptop
One handle is loose-how can I tighten it
shoulb be screws under cap on handle remove and tighten that should do the trick
Aug 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Won't unlock, handle is loose
Tighten all screws on lock to a firm tightness. DO NOT OVER TIGHTEN as to bend the lock casing! Snug only. Use powered graphite to inject into lock and add to key working it back and forth into the lock.
Jul 08, 2009 | Kwikset Brz Sgl Cyl Deadbolt
Emachine monitor lose color.
HI Bernard,
This sounds to me like the video lead is loose. Could you please try the video lead each end and tighten the locking screws if possible.
Regards
Nick
Oct 29, 2008 | E-Machines eMachines Monitor E15T4
Hardware & Accessories Logo
273 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
