Celestial split system air conditioner
I am unable to turn off the ''timer'' function, no matter what I do that little orange light is still there and so the air con keeps turning itself on and off.
  • mel_o_drama Mar 09, 2009
    Thanks so much! I had tried shutting down the breaker, but I musn't have left it off for long enough.
  • mel_o_drama Mar 15, 2009
    Well - looks like I started the celebrations too soon.
    The advice I was given worked that day, but the same problem arose when I switched the air con back on the next day.
    I tried shutting down the breaker again and this time it made absolutely no difference. I tried shutting it down for 10 minutes, then I tried shutting it down for an hour, I even tried waiting for 24 hours.
    At this point I have left in on all day - the timer button is still flashing, and it turns itself on and off for 30 seconds or 8 minutes, or any other amount of time. There isn't any pattern to when it turns on, how long it stays on or when it shuts off.
  • 74 Answers
TRY TO SHUT DOWN THE BREAK AND TURN IT ON AGAIN 10 MIN LATER
Posted on Mar 09, 2009
I just moved into a new home and the air cons are kelvinator r51k bgce and it won't turn on when i use the remote and the batteries are working?
pull up the front cover the grill looking piece , not the air out louvers , there maybe a little button , push that in if air con starts up , then you remote sensor may be faulty or the remote itself .
Mar 28, 2014 | Heating & Cooling
I have a newlec timer channel plusxl model nlh37 unable to programme it after it was switched off, all heating systems running at same time
1) Power surge such as turning power ON can put out timers.
2) Reset timer, and if functionality is not restored, then replace timer.
3) These timers usually have 1 year limited warranty.
4) Add comment and include photo of timer. And post your .pdf manual on your website, and include link to manual so timer and steps for reset can be ascertained.
Dec 13, 2012 | Hardware & Accessories
Sharp AY-A249J Split System Air Conditioner not working, the timer light flashes 5 times and the power light does not flash at all, the remote has limited function, it turns the indoor unit on and off and...
Thanks for your replies, I had a Sharp authorised tech look at it and im told it's the indoor circuit board. Im told its a $360 repair job all up, that sure beats replacing the entire ac or putting up with the heat...
Dec 07, 2012 | Sharp AF-S120FX Air Conditioner
Onsen split air conditioner showing code E5 what is wrong?
I have an Onsen split system air conditioner but i cant turn it on today for some reason. The timer light is flashing 4 times.Its look like error 4.Any suggestion?
Oct 10, 2011 | Heating & Cooling
We have a 24DMC split air conditioner and it will not start up. The green light on the wall unit flashes 3 times followed by the orange button flashing 3 times. Can u please help?
A repairman just left and the problem is, I think resolved. The solenoid on one of the mini-split units was malfunctioning. It was telling the units that it was open and functioning but was actually not working for one of the two units, and caused the main unit to shut down. Once the problem was isolated and the unit fed by the faulty solenoid was shut down, the other unit functioned perfectly. So we now have half of the cooling for the house, but better than none, until we can get the part and install it.
Jun 28, 2011 | Comfort-Aire DMC24SB Split System Air...
Fijitsu wall mounted split system operation and timer lights are flashing, and the air con is not blowing cold air, only like fan operating even in cool mode.
This the common problem with all a/c holders. Without knowing the function of Timer on and Timer off, if it's pressed the unit will start only at setting time.
Please remove the battery from your remote and reset it. And then with use of your manual, set the timer if you need., otherwise normal function will be activated.
Dec 11, 2010 | Fujitsu Heating & Cooling
Heating & Cooling Logo
311 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
