Question about Apple iMac G5 Desktop
G4 imac CD tray keeps opening
I have an iMac running on 0S 10.3.9
The CD tray keeps opening spontaneously and the mac has got pretty slow. Tried PRAMMING it a few times but no change. Any ideas?\
  • sylvanian Mar 23, 2009
    CD/DVD tray of my iMac G5 keeps opening. Once closed, it opens again.
    Problem Solver:
  • 5 Answers
You may be trying to load a corrupted disk, or your mac may have a faulty mother board. sorry, im not quite sure exactly what your problem is, but good luck anyway...
Posted on Mar 08, 2009
Imac G4 0s 10,4.11 need a flash to watch hulu free tv
You can't watch Hulu on a PowerPC iMac G4. You need an Intel processor based Mac to watch Hulu and Netflix.
Dec 19, 2012 | Apple A1106 Powerbook G4 15", 1.67 Ghz,...
Imac g4 won't start but shuts down when apple logo appears on screen
Are you sure the iMac is really shutting down or just turning off the backlight? The tell-tale sing would be to let the unit fully boot-up (wait 3 minutes) and the press the button the apple keyboard that ejects the CD-ROM. If the CD-ROM door opens, you iMac is running with disabled or broken backlight.
The inverter circuit on the iMac G4 is known to be weak.
There could be another problem, though. The iMac G4 is also known to have weak internal power supplies. Here's how you can tell:
Hold down the CMD OPT "O" and "F" keys at the same time while pressing the power button. This will tell the iMac that you want to boot into the Open Firmware shell, bypassing the Mac OS X startup. If this works, your power supply is good, the inverter is good and you have a problem with your Open Firmware boot string. To fix the boot string, Power on the unit while holding down the keys CMD-OPT-P-R to zap the parameter RAM (PRAM) and reset everything to defaults.
If you were not able to boot into the Open Firmware shell, your problem is either a failed power supply or a failed screen backlight. The last possible culprit is your iMac could suffer from "Bulging Capacitor Syndrome", where a batch of iMac G4s, iMac G5s another electronics were fitted with a bad batch of capacitors. Eventually, the caps will rupture and cause irreparable damage to the logic board. Only way to verify this is to pull the unit apart and visually inspect. If you see little green or blue cylinders that seem to be bulging or oozing a thick oily goo, that's your problem. Only recourse is to shop around on eBay and look for a replacement logic board.
May 30, 2010 | Apple iMac G4 Desktop
IMac G4 Mac Desktop: i have a IMac G4 that when i start it a folder wit...
It can not find the hard drive or the startup folder on the hard drive. Try and fix that by putting in the original boot cd/dvd and repair and choose your hard drive start up folde as boot device. If you can not your hard drive may have died.
May 16, 2010 | Apple iMac G4 Desktop
The container that hold my dvd disk wont come out when I press the open button on my apple computer?
It may be stuck so what you can try are one of these options:
Option# 1
* Shutdown your iMac G4
* Before you turn on your iMac, hold down your mouse button(s).
* Turn your iMac on still holding the mouse button(s) down.
* You will need to keep holding, until your disc ejects as your iMac starts up. That should do it.
Option# 2
If it does not, try using the Terminal utility to attempt to eject the disc.
* Click anywhere on the blank space of your desktop
and then you should see Finder appear near the Apple menu icon located in the upper left corner of your screen.
* Now from the Finder menu, select Go > Utilities.
* Within the Utilities folder. locate the Terminal application and launch it.
* When the screen prompt appears, type:
drutil tray eject
Option# 3
If that does not work, you can also try ejecting the cd using Open Firmware:
* Restart your Mac and hold these keys:
* Hold Command, Option, O and F keys while booting up.
* Now type: eject cd
To exit the open firmware screen type: mac-boot
One of these 3 methods should eject your disc.
If not, you may have a genuinely stuck CD in your drive and may need to take your iMac in to your local Apple retail store Genius bar or local Apple-authorized service center to have it safely and correctly removed.
Honestly, however, I have this same type of iMacG4- you will probably have the cd out by Option # 2 :)
Jan 04, 2010 | Apple iMac G4 Desktop
How to install a ram stick
Looks like it is pretty simple to install ram on the iMac g4. Here are screen shots from the imac manual that describes the process. (see below)
Mar 30, 2009 | Apple iMac G4 Desktop
My G4 1.25ghz with 1 gb ram plays abc video slow.
Hello, sorry you are having trouble,
There are so many variables when it comes to Video play back on a Mac..
Yea, 1.25 Ghz with 1 GB of Ram answers most questions, yea, it should play OK,
  • Is the video on a CD or DVD ? well, these iMacs don't have a very fast optical drive.
  • How much room do you have on your internal hard Drive, if it's too full ( more than 80% full ) then you will suffer read/write performance.
  • Is the video on an external harddrive, is it a USB drive? the USB on the iMac G4 is USB 1.1, 11Mbit/sec, way too slow to play a big video smoothly.
  • Just what is the size of the video, is it like that for all of them or just one, might it be a HD video with high frame rates?
  • What version of the MacOS X do you have installed? If you installed Leopard 10.5 on the iMac G4, nothing will run smoothly,
  • Are you playing this video over a network? forget it it's got to be on the internal or a FireWire external disk otherwise it will stagger...
Well, there you go, I know, it's so easy to say Hey man, just get a new Mac and everything will be fine... But that machine is going on 6 years old now, Video technology has not stood still.....
Mar 24, 2009 | Apple iMac G4 Desktop
Photoshop on G4 imac
There have been some reported issues with PS7 on Mac Os 10.4.. first i would try repairing disk permissions.. if that doesn't work, you may need to do a fresh install, then download all the updates before you run the application for the first time.
Oct 28, 2008 | Apple iMac G4 Desktop
Can't get open office installed in my mac
Open Office has been slow to develop a full version for Mac. Try Neo Office instead as it has a fully Mac-compatible version. The Open Office for mac is expected in a couple of months.
Oct 02, 2008 | Apple iMac G4 Desktop
Imac / illustrator10
According to something I read in another forum:
Use migration assistant (in utilities) to copy over Illustrator 10 via firewire from your G4 to your imac. This is the only thing that might work without upgrading to a newer version of Illustrator.
I'm planning on trying it with both Illustrator 10 and Indesign 2.0 - Photoshop 7 won't go at all no matter what one tries according to what I've read. I'll be upgrading to CS3 for Photoshop. No choice.
Jun 29, 2008 | QuarkXPress Passport 6.0 for Mac
Apple iMac G5 Desktop Logo
326 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
