Question about Brother MFC-5440CN All-In-One InkJet Printer
Do not know how to connect printer to computer to get it to print
I just moved from florida to dallas how do i set up my brother printer to my computer to get to print
  • Brother Master
  • 4,338 Answers
How to fix brother printer won't connect to wifi?
I have brother smart wifi printer and it keep disconnecting from wifi. Its connected and ince i gave command for print it won't print. I was very frustated. One of my friend advice me to search answer on http://www.fixotip.com/brother-printer-wont-connect-wifi/
and i fixed my printer by myself.Check out great article for Why Is My Brother Printer Wont Connect To Wifi Fixotip
Jan 02, 2018 | Brother Office Equipment & Supplies
MFC_5840CN Will not print, not showing
Typically, a Brother machine stops printing, because the connection between the computer and the Brother machine is lost. There are multiple reasons for a lost connection.
  1. The Brother print driver is Offline.
  2. The Brother printer driver is not set as the default printer driver.
  3. The computer, not the monitor, connected to the Brother machine is set to go into sleep or standby mode. When the computer goes into sleep or standby mode, the connection between the computer and the Brother machine is lost and needs to be re-established.
Follow the steps below in order to re-establish the connection between the Brother machine and the computer:
  1. Verify that the Brother machine is connected with a USB cable and is not on a network.
  2. Verify the power cord and USB cable are securely connected. If the USB cable is loose on either end, disconnect and reconnect the cable securely. Test the machine by trying to print. If the machine does not print, go to STEP3.
  3. Cycle the power of the Brother machine by unplugging the power cord from power outlet, wait approximately one minute and plug back in. Once the Brother machine displays the date and time after plugging it back in, test the machine by trying to print. If the machine does not print, to Step 4.
  4. Reboot the computer connect to the Brother machine and then try to print again.
Apr 01, 2008 | Office Equipment & Supplies
Text missing when document is printed from Brother MFC-9840CWD
Hello,This issue may becaused by poor connection. Check to see if all interface connection cables arein the printer. If the printer doesn't establish good connection with thecomputer print quality will decrease.Second thing you can check are thesettings on the computer. Are they matching with settings in Brother MFC-9840CWD.This is issue is not caused from the toner cartridge or drum unit.
May 09, 2012 | Brother MFC-9840CDW Laser Printer
I would like to make copies faster and don't know the procedure? Please let me know if this is possible. Thanik you, Nancy Ludlow
You can set the printer to "economy print mode"
For printing:
Also, in your printer propeties on the computer, set it to print "grayscale"
Here is the user guide:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_7420_7820N_EN_1156.PDF
Jun 29, 2011 | Brother MFC-7420 Laser Printer
How to set up j315 brother printer?
On the printer connect the power cable to the mains outlet and the printer cable to the computer.
Then install the printer driver on the computer.
You candownload the Brother printer drivers from their support WEB site. Please clickon this link and select your model printer to download : - http://www.brother.com.au/ProductsSolutions.aspx
Do a test print to see if the printer is working correctly.
The printer is now ready to print
Jun 13, 2011 | Brother DCPJ315W AllInOne Inkjet Printer
How to solve 'error S01'?
1. Verify USB cable is connected directly from USB port of printer and the USB port on back of computer. If not, connect directly to both the printer and computer and try to print. If the printer does not print, go to step 3.
2. VERIFY THAT THE BROTHER PRINTER IS SET AS DEFAULT
This is especially important if you use the print icon to print from within applications. If the Brother printer is set as the default printer, it will have a check mark. If it is not set as default:
To set your Brother machine as the default printer, RIGHT CLICK on the Brother printer and select SET AS DEFAULT (PRINTER).
3. VERIFY THAT THE PRINTER STATUS IS READY AND THE PRINT QUEUE IS EMPTY
A. Click on START, RUN
B. Type: CONTROL PRINTERS and click OK.
C. Locate the Brother printer in the list and hover your mouse over the Brother printer icon. Below is an example of what you may see:
Status: Ready (Could also state: USE PRINTER OFFLINE or PAUSED)
Documents: 0 (Could be any number)
D. If there are any documents waiting in the queue, right-click on the Brother printer and select CANCEL ALL DOCUMENTS, depending on your operating system. This should clear the queue.
E. If the status states: USE PRINTER OFFLINE, right-click on the Brother printer and select USE PRINTER ONLINE depending on your operating system. This should set the printer driver ONLINE.
F. If the status states: PAUSED, right-click on the Brother printer and uncheck PAUSE PRINTING. This should allow the printer to resume printing.
G. If the status is ready and no documents are in the queue, attempt to print the Windows test page. If not successful, verify the selected port. If USB is the selected port follow step 4. If USB is not selected,change the port to USB, then attempt to print the Windows test page. If not successful proceed to step 4.
4. Turn the printer OFF.
5. Close any open programs.
6. Click Start, Run, type: control printers
7. Right click Printer, left click Cancel All Documents (if available). Confirm if necessary (click OK).
8. Right click Printer, left click Delete. Confirm if necessary (click OK).
9. Left click File menu, left click Server Properties, left click Driver tab, left click print model name, left click Remove button, click Confirm.
10. Close the Print Server Properties window to return Printers and Faxes window.
11. Check that the USB cable is properly connected at both ends.
12. Turn the printer ON.
13. Wait until printer has ready light or green status, watch the Printers and Faxes window to see if printer is automatically reinstalled.
14.a. If printer was automatically reinstalled, right click Printer icon, left click Properties, left click Print Test Page button. If the printer is not automatically reinstalled, call Brother Customer Service at 1-877-Brother (1-877-276-8437).
b. If printer was not automatically reinstalled, try a new USB cable. Ifthe printer still is unable to print, call Brother Customer Service at1-877-Brother (1-877-276-8437).
Nov 02, 2010 | Brother HL-5270DN Laser Printer
Can my brothers mfc 240c printer be used to print from more than 1 computer in my house wirelessly? how do I set this up?
The MFC-240C does not have a wireless interface, so you can't connect wirelessly directly to it. What you would have to do is set up a print server, which can be a standalone device or can be one of your computers, and then the other computers would print through that one connected computer.
Jun 26, 2010 | Brother MFC 240C All-In-One InkJet Printer
I moved my printer from one room into another and now it won't print. I checked and doubt checked the connections and every thing seems okay in the respect. Any answers It does print somethings but not...
it is possible that if you have moved it to another room, you have connected it to another computer as well. and that computer has no installed driver/software for that printer. make sure to download the right driver for your printer at the manufacturer's website and install it on that computer before you connect the printer to it.
Nov 06, 2009 | Brother MFC 210C All-In-One InkJet Printer
How to scan on my mfc-235C
You should use Brother's Control Centre.
Dec 23, 2017 | Scan Computers Brother MFC Color Inkjet...
Printer connected but not printing.
If you are not sure of the location of the router, it occurs to me that you could not be certain that the printer is configured therein.
If there is a person who normally manages the router which location you don't know, then they should also configure the printer to incorporate it and the two macs as part of your network, or your printer will never work.
Apr 25, 2009 | Brother MFC-820cw All-In-One InkJet...
Brother MFC-5440CN All-In-One InkJet Printer Logo
89 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
