Question about Nokia N81 Smartphone
My n81 8gb no longer snaps the center button only pertforms the function of the left key select button when u enter an application and press it it will return to menu.i need hlp pls.my fone is dying,its an emergency .....hlp pls
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    actually in the slide mechanism there is a strip for these buttons to work may be it is faulty u can get it replaced it is cheap not expensive may be 10 $ or so
CHANGE CAMA 100%
Posted on Mar 21, 2009
How to reset an adr6350 phone
Preferred Method
  1. From a home screen, select the applications tab (located in the lower left).
  2. Select Settings.
  3. Select SD & phone storage.
  4. Select Factory data reset.
  5. Select Reset phone.
  6. Select Erase Everything.
  7. Perform Initial Activation/Setup.
Alternate Method
  1. Press the Power button for 3 - 5 seconds.
  2. Select Power off.
    linote.gif If the device isn't responding proceed with step 3.
  3. Remove/replace the battery.
  4. Press and hold the Volume down key then press and hold the Power button for 3 to 5 seconds.
  5. When the HBOOT screen appears, release the Volume down key and Power button.
  6. Press the Volume key to select FACTORY RESET then press the Power button.
    linote.gif This boot process takes several moments. If the device hangs or freezes, remove/replace the battery.
Mar 08, 2014 | HTC Incredible 2 II / ADR6350 ADR-6350 Hot...
W580i gprs setting vodafone postpade
Settings - GPRS WAP
Sony Ericsson W580i GPRS WAP Pay & Go settings
Please note all steps must be completed to ensure the settings are correctly configured.
Please ensure that when entering 'O2' into the settings that the letter 'O' is selected not a zero.
The W580i has a central navigation button (Navi key) and two soft keys slightly above this.
1. Press 'Menu' (right softkey).
2. Highlight 'Settings' and press 'Select' (left softkey).
3. Scroll to the 'Connectivity' tab by pressing the Navi key to the right.
4. Scroll to 'Data communication' and press 'Select' (left softkey).
5. Highlight 'Data accounts' and press 'Select' (left softkey).
6. Highlight 'New account' and press 'Add' (left softkey).
7. On the 'Account type' screen, highlight 'PS data' and press 'Select' (left softkey).
8. On the 'Account Name' screen, enter 'O2 WAP GPRS', press 'Continue' (left softkey).
9. On the 'New PS data' screen, highlight 'APN' press 'Edit' (left softkey), enter 'payandgo.o2.co.uk' and press 'OK' (left softkey).
10. Highlight 'Username' press 'Edit' (left softkey), enter 'payandgo' and press 'OK' (left softkey).
11. Highlight 'Password' press 'Edit' (left softkey), enter 'password' and press 'OK' (left softkey).
12. Press 'Save' (right softkey).
13. Press the 'back' arrow key (key directly below left softkey) 2 times.
Activate GPRS settings:
14. Highlight 'Internet settings' and press 'Select' (left softkey).
15. Highlight 'Internet profiles' and press 'Select' (left softkey).
16. Highlight 'New profile' and press 'Add' (left softkey).
17. Highlight 'Name:' press 'Add' (left softkey), enter 'O2 WAP GPRS' and press 'OK' (left softkey).
18. Highlight 'Connect using' press 'Select' (left softkey), highlight 'O2 WAP GPRS' and press 'Select' (left softkey).
19. Press 'Save' (right softkey).
Change GPRS settings:
20. Highlight 'O2 WAP GPRS' and press 'More' (right softkey).
21. Highlight 'Settings' and press 'Select' (left softkey).
22. Ignore 'Connect using'
23. Highlight 'Use proxy:' press 'Select' (left softkey), highlight 'Yes' and 'Select' (left softkey).
24. Highlight 'Proxy address:' press 'Edit' (left softkey), enter '193.113.200.195' (to bring up the number press the number until it appears. Add the dots with the '1' key) and 'OK' (left softkey).
25. Highlight 'Port number:' press 'Edit' (left softkey), enter '8080' and press 'OK' (left softkey).
26. Highlight 'Username' press 'Edit' (left softkey), enter 'payandgo' and press OK (left softkey).
27. Highlight 'Password' press 'Edit' (left softkey), enter 'password' and press OK (left softkey).
28. Press 'Save' (right softkey).
Change Homepage:
29. Highlight 'O2 WAP GPRS' and press 'More' (right softkey).
30. Highlight 'Advanced' and press 'Select' (left softkey).
31. Highlight 'Change homepage' and press 'Select' (left softkey).
32. Highlight 'Name:' and press 'Edit' (left softkey). Hold the 'c' button (to the right of the Navikey) to clear any text in the field. Enter 'O2 ACTIVE' and press 'OK' (left softkey).
33. Highlight 'Address:' and press 'Edit' (left softkey). Hold the 'c' button (to the right of the Navikey) to clear any text in the field. Enter 'http://wap.o2.co.uk' and press 'OK' (left softkey).
34. Press 'Save' (right softkey).
35. Press the backward arrow key (key directly below left hand soft key).
36. Highlight 'O2 WAP GPRS' and press 'Select' (left softkey).
37. Press the 'back' button (to left of Navi key) 3 times to return to the standby screen.
Feb 19, 2013 | AT&T Sony Ericsson W580i Cell Phone -...
Vodafone live postpade gprs setting w580i
8. On the 'Account Name' screen, enter 'giffgaff WAP GPRS', press 'Continue' (left softkey).
9. On the 'New PS data' screen, highlight 'APN' press 'Edit' (left softkey), enter 'giffgaff.com' and press 'OK' (left softkey).
10. Highlight 'Username' press 'Edit' (left softkey), enter 'giffgaff' and press 'OK' (left softkey).
17. Highlight 'Name:' press 'Add' (left softkey), enter 'giffgaff WAP GPRS' and press 'OK' (left softkey).
18. Highlight 'Connect using' press 'Select' (left softkey), highlight 'giffgaff WAP GPRS' and press 'Select' (left softkey).
20. Highlight 'giffgaff WAP GPRS' and press 'More' (right softkey).
Change Homepage:
29. Highlight 'giffgaff WAP GPRS' and press 'More' (right softkey).
32. Highlight 'Name:' and press 'Edit' (left softkey). Hold the 'c' button (to the right of the Navikey) to clear any text in the field. Enter 'giffgaff ACTIVE' and press 'OK' (left softkey).
33. Highlight 'Address:' and press 'Edit' (left softkey). Hold the 'c' button (to the right of the Navikey) to clear any text in the field. Enter 'http://giffgaff.com/mobile' and press 'OK' (left softkey).
36. Highlight 'giffgaff WAP GPRS' and press 'Select' (left softkey).
The GPRS WAP settings are now complete.
Sony Ericsson W580i MMS
You'll need to complete all steps for this to work.
Please also ensure the GPRS WAP settings have been entered prior to entering the MMS settings.
2. Highlight 'Messaging' and press 'Select' (left softkey).
3. Scroll to 'Settings' and press 'Select' (left softkey).
4. Highlight 'Picture message' and press 'Select' (left softkey).
5. Highlight 'Validity period' and press 'Edit' (left softkey), highlight 'Network maximum' and 'Select' (left softkey).
6. Highlight 'Read report' and press 'Edit' (left softkey), highlight 'Off' and 'Select' (left softkey).
7. Highlight 'Delivery report' and press 'Edit' (left softkey), highlight 'Off' and 'Select' (left softkey).
8. Highlight 'Signature' and press 'Edit', highlight 'No signature' and 'Select' (left softkey).
9. Highlight 'Creation mode' and press 'Edit' (left softkey), Highlight 'Unlimited' and 'Select' (left softkey).
10. Highlight 'Picture scaling' and press 'Edit' (left softkey), highlight 'Off' and 'Select' (left softkey).
11. Highlight 'Auto download' and press 'Edit' (left softkey), highlight 'Ask in roaming' and 'Select' (left softkey).
12. Highlight 'Accept messages' and press 'Edit' (left softkey), if not already ticked highlight 'Advertisements' and press the left hand soft key 'Mark'. If already ticked leave. Ignore 'Anonymous' Press 'Save' (right softkey).
13. Highlight 'MMS profile' and press 'Edit' (left softkey).
14. Highlight 'New profile' and press 'Add' (left softkey).
15. Highlight 'MMS profile name:' and press 'Edit' (left softkey), enter 'giffgaff MMS', select 'OK' (left softkey).
16. Highlight 'Message server' and press 'Edit' (left softkey), enter http://mmsc.mediamessaging.co.uk:8002' and press 'OK' (left softkey).
17. Highlight 'Internet profile' and press 'Edit' (left softkey), highlight 'giffgaff WAP GPRS' and press 'Select' (left softkey).
18. Select 'Save' (right softkey).
19. Highlight 'giffgaff MMS' and select (left softkey).
20. Press 'back arrow' (key to left of navi key) 5 times, to return to standby screen.
The MMS settings are now complete.
Feb 19, 2013 | Sony Ericsson w580i Cellular Phone
We have a TI-89 and it is froze on the home page. we tried holding the 2nd button , left arrow , rigth arrow and pressing the on button. it comes up with installation in progress , but when that is done it...
Hello.
Here is a procedure to reset the TI-89 to factory settings (found online):
  • Press the "Snd Mem" key to display the memory screen.
  • Press the "F1" key.
  • Press the navigation key to select the "RAM" icon, then select "1: All RAM" to erase all data and programs from the random access memory and press the "Enter" key, or select "2: Default" and press the "Enter" key to reset all system variables to original factory settings. This preserves any user-defined variables, functions and folders.
  • Press the navigation key to select the "Flash ROM" icon, then select "1: Archive" and press the "Enter" key to erase all data and programs from the read-only memory or select "2: Flash Apps," then press the "Enter" key to erase all applications from the Flash ROM. Select the "All Memory" icon and press the "Enter" key to erase all data, programs and flash applications from the RAM and Flash ROM.
  • Hope this helps.
    Aug 21, 2011 | Texas Instruments TI-89 Calculator
    Htc ozone (xv6175) will not boot stuck on windows6 1 screen . I removed the battery and held the power button down 30 seconds now it has a message that says- The device is unable to boot because either...
    Obviously one of your applications that you installed is the problem. Your best bet is to try to hard reset or reflash your device.
    To do a hard reset:
    1. From the Today screen, press the left soft key to choose Start.
    2. Select System Tools then press the center of the 5-way navigation pad.
    3. Select Clear Storage then press the center of the 5-way navigation pad.
    4. Select Factory Default. Enter 1234 then press the left soft key to choose YES.
    May 01, 2011 | HTC Ozone XV6175 Cell Phone
    How setup internet settings
    The phone has a 4-way directional 'Navi' key and 2 soft keys on either side of this. The Navi key can also be pressed in to select options.
    1. Press the 'i' button (press navi key).
    2. Highlight 'Browser' and press 'Select' (left softkey).
    3. Highlight 'Browser settings' and press 'Select' (left softkey).
    4. Press 'Options' (left softkey) , highlight 'Add new connection' and 'Select' (left softkey).
    5. Highlight 'Profile Name' and enter 'giffgaff GPRS WAP'
    6. Highlight 'Homepage URL' and enter 'http://giffgaff.com/mobile'.
    7. Check that 'Proxy' is ticked (press Navi key to tick/untick).
    8. Highlight 'IP Address' and enter '193.113.200.195'.
    9. Highlight 'Port' and enter '8080'
    10. Ignore 'Linger time' (this is preset at 90).
    11. Check that 'DNS' is unticked (press Navi key to tick/untick).
    12. Highlight 'Bearer' and select 'GPRS' by pressing the Navi key right or left.
    13. Highlight 'Advanced settings' and select using center Navi key.
    14. Highlight 'APN' and enter 'giffgaff.com'.
    15. Highlight 'Login ID' and enter 'giffgaff'.
    16. Highlight 'Password' and enter 'password'.
    17. Press 'Save' twice (left softkey).
    18. Highlight 'giffgaff GPRS WAP' and press 'Options' (left softkey)
    19. Highlight 'Activate' and 'Select' (left softkey).
    20. Press 'Back' (right softkey) 3 times to return to the main screen.
    Dec 21, 2010 | Samsung SGH-J600 Cellular Phone
    My calculator is only graphing one function at a time, how do i graph multiple funtions. i try highlighting both funtions but when i select one then the other one, only one stays highlighted
    Here it is.
    When you enter a function you should press [ENTER] to validate. At the same time, the cursor moves to the next line. Verify that the = sign on the equation already entered is still highlighted.
    If for some reason the = sign of an equation is no longer highlighted, use arrow keys to move cursor on the = sign and press [ENTER].
    If only one = sign remains highlighted and all others are not, then in all probability the application Transfrm has been executed before and is still lingering in RAM. When in RAM, it takes over the graphing capabilities of the native OS. This prevents you from drawing more than one graph.You must unload it from memory.
    1. Press the [APPS] key.
    2. Scroll down to the line that shows Transfrm.
    3. Highlight it and press [ENTER].
    4. In following screen you are invited to Uninstall or continue.
    5. Press the number to the left of Uninstall. Validate if need be.
    6. Return to the Y= editor to type in functions to graph.
    Sep 24, 2010 | Texas Instruments TI-84 Plus Calculator
    Set all 3 alarms and they never go off. Big problem since it is my only alarm clock for work and just recently quit working have used for almost 2 yrs
    You need to make sure the Ringer is enabled. Here are the instructions:
    Alarm Clock
    The Alarm Clock tool allows you to set up to three
    alarms.
    When you set an alarm, the current time is displayed.
    When the alarm goes off, Alarm 1 (or 2 or 3, as
    applicable) will be displayed on the LCD screen and
    the alarm will sound.
    1. From standby mode press the Center Select
    Key c [MENU], then press the Directional Key
    r right twice for SETTINGS & TOOLS, 2
    Tools, 4 Alarm Clock.
    2. Press the Directional Key j up or down to
    highlight an Alarm (1, 2, or 3), then press the
    Center Select Key c [OK].
    3. Enter the alarm information including:
    • On/Off
    • Time
    • Frequency
    • Ringer
    4. Press the Directional Key j up or down to
    highlight the information you want to set, then
    press the Left Soft Key L [Set] to view your
    choices.
    5. Set information and press the Center Select Key
    c [OK].
    6. Press the Center Select Key c [SAVE] after
    setting all of the applicable Alarm Fields.
    Feb 24, 2010 | Casio G'zOne Boulder Cell Phone
    How do you find the zeros of a function on a TInspire
    Turn calculator. Use arrow to highlight the 2:Graph and Geometry application. Enter your function at the bottom of the screen. Use TAB to move focus on command line.
    Press [ENTER] to graph.
    While graph is drawn, press [menu] key. Select [5:Trace][1:Graph Trace] . An X appears on the graph screen. Use arrow to move cursor towards one of the zeros you see. At some point the calculator will pop up the label [zero]
    Press [ENTER]
    Use arrows to move the cursor near a second zero. When [zero] pop up text appears, press [ENTER]
    The value of the secon zero is also displayed.
    You can also the nSolve command
    Use the nSolve( function available in main calculator application. Here some exemples of syntax
    On the second command line, the small vertical segment after the right parenthesis is accessed by the key sequence [CTRL] [infinity, beta, degree] key, the one under [left arrow/clear].
    Hope it helps.
    Oct 26, 2009 | Texas Instruments TI-Nspire Graphic...
    Steps to forward inbox texts to email with white screen problem?
    First open your phone. Press upper right (-) key to get menu. Press joystick up 1 time to get Messaging. Press joystick center select button 1 time, then down 1 time for "Inbox" (or down 3 times for email). Press center select 1 time, joystick down 1time for Inbox, center select for first message. Press upper right (-) key for "More", then joystick down 2 times to get "Forward", press center select. Press upper left (-) key to "Continue", press joystick up 1 time to get "enter email addr." Press joystick center select button, and enter the email address you want to forward the message to. After you have typed in the email address, press upper left (-) key "OK" 2 times to "Send", if you normally enter a password, type it now, press upper left (-) key for "OK" and your message will be sent. Hope this helps. -Mike
    Nov 11, 2008 | Sony Ericsson Z525a Cellular Phone
    Nokia N81 Smartphone Logo
    64 people viewed this question
    Top Nokia Computers & Internet Experts
    Computer Links
    Gopi Venkatesan
    Gopi Venkatesan
    Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
