Question about Dell Microsoft Windows XP Home Edition
When I insert a CD I get the following. Skin bitmap was not found c:program filesmusicmatchmusicmatch jukeboxskinsdell.pegasus prbtnsmp click ok then get.. there was a problem with either the play.dll or mixer.dll runtime error click ok then get program c:programfilesmusicmatchmusicmatch jukeboxmmJB.exe
  • 184 Answers
Try reinstalling your music match. Some files may be either missing or corrupted.
Posted on Jun 09, 2009
How, to install themes on motorola?
Ok you'll need the program at this link http://www.mediafire.com/?wmwix5ei3ym
Themes can be found here http://www.66mobile.com/themes/motorola/index.php
Once you have found and downloaded a skin that you like, extract it to a new folder.
Installing:
1. Connect the phone to the cable and open Skinmanager: It should auto connect and will say reading files as pictured:
2. Once finished it should look like this:
3. Click Install and you will get this pop up: dmooney_eire_3.jpg
4. Navigate to the skin you want and click Open: dmooney_eire_4.jpg
5. The skin will now begin to install as seen in the pic below. Depending on the size of the skin it could take a minute to install.
This program will auto-install the wallpaper as well in the uploading process
6. Your skin is now installed:
7. After everything uploads click Skins, More, Restart phone.
8. Disconnect the phone after restart and enjoy your new skin.
Jan 14, 2011 | Motorola Mobility RAZR V3
Ilo Mp3 player
Remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted. On the iLO, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the iLO will remain off during this time, making the screen appear to be blank. An hourglass should appear on you computer and Windows should say, "Found new Hardware 'SMTP3500". Launch the Rave-MP firmware update program (Start>Programs>Rave-MP> Firmware) Click "Get Firmware". Select "iLO256" and let it download new firmware. Click "OK" when prompted. Click "Update Firmware". It will now search for the iLO. This may take a while depending on how corrupted the firmware is, so be patient. After it has found the iLO, it will say, "A device has been detected in recovery mode and is being initialized. Please wait." The iLO should come back to life and start showing it's glorious "USB Connected" screen. The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start". It can take anywhere from 2 to 4 minutes to re-flash the iLO and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the iLO! Why are you still reading this? Great, did something happen? Well, If the program fails to find the iLO and gives you an error like, "Device Timeout" or something similar, you need to reinstall the iLO drivers. This can be done by inserting the iLO cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again). Plugging it into a new USB port is the fastest and easiest option though. Also check the following link for there FAQ: http://www.uiss.6x.to/ Good Luck
Sep 18, 2007 | iLO MP3 Player
Tip
CD Insert Without pushing a button!
This will not work with a Laptop drive unless it is the slot loading type.
We already have 'Eject' when we right click the CD/DVD drive from (My Computer), which ejects the drive tray. But to insert the tray inside,we have to manually push the insert button on CD/DVD drive.
Another way most PC owners insert that CD tray is by pushing the tray itself. I'm sure nobody mentioned this when you got that PC, but that push to insert feature (Also called the bump feed) is not really safe to use over time. If you happen to say, push too hard because you are in a hurry, the gear which pulls your CD tray in can skip a tooth, making that CD or DVD open and close all by itself, or even worse, making it stay locked tight forever.
Here is a trick that allows you to insert the drive tray without actually touching that button. Simply by putting the 'Insert' sub-context(as shown in above figure) menu on the CD/DVD drives Context menu. For this to happen, we need to use a dll file from our windowssystem32 folder.
First of all, download this file CDEject.zip and extract it. There will be two files CDeject.dll and CDeject.reg. Now follow the step by step procedures.
1. CDeject.dll -> copy this file to X:windowssystem32 folder (here X is your corresponding drive letter, usually it's drive C:)
2. CDeject.reg -> execute it. It shows a warning message, accept that and click OK.
Now try right clicking your CD or DVD drive and click eject, then right click again and choose insert.
Amazingly cool isn't it?
So far I haven't found a way to make the CD hop in the tray all by itself, but I am still hopeful.
And you thought you couldn't program!
Have fun with that!
Please Vote for this Tip if you found it helpful.
Bob S.
on Apr 02, 2010 | Computers & Internet
Printer is not scan but some problem she has. Error in scannor Turn off scannor and follow instructions ni manual. Scannor drive will closed. Code : 61,213,0 I want to new setup Canon PIXMA MP160...
  1. Select 'Program' (for Windows 2000/Me/98), or 'All Programs' (for Windows XP) from the Start menu.
  2. Select the name of the printer model to remove and select 'Uninstall.'
  3. When the MP Drivers Uninstaller window is displayed, click 'Perform.'
  4. When the confirmation window is displayed, click 'Yes.'
  5. When the Uninstallation Complete window is displayed, click 'Complete.'
  6. Reinstall the drivers.
Reinstall the Drivers
Note:
  • The MP drivers can be installed using Easy Install or Custom Install.
    Easy Install automatically installs the software which is in the CD-ROM.
    This method is recommended for first-time users.
    Custom Install allows you to select the software programs from MP Drivers, Application Software, and On-screen Manual.
  • Login as a user with Administrator privileges to install on WindowsXP/2000.
  • Close any antivirus software that may be running prior to installing the drivers.
  1. Turn off the printer and disconnect the cable connecting the computer and the printer.
  2. Insert CD-ROM in the computer. (The CD-ROM will start automatically and the following window will be displayed on the screen.)
    1. If setup does not start automatically, click 'Start' and then 'Run'.
    2. At the Run window, type x:\msetup4.exe (where x is your computer's CD drive) in Open box and then click 'OK'.
  3. At the main installation window, click 'Easy Install' or 'Custom Install'.
    When selecting Easy Install:
    (A) Click 'Easy Install'.
    (B) Click 'Install' in the following window.
    * Display varies according to the printer model.
    When selecting Custom Install:
    (A) Click 'Custom Install'.
    (B) When the following window is displayed, click 'MP Drivers' and the application software to be installed, and then click 'Next'.
  4. When the License Agreement window is displayed, read the content carefully and click 'Yes'.
  5. The installation will start.
    Messages may be displayed during the installation of the application software.
    Follow the instructions on the window and continue the installation.
  6. When the Printer Connection window appears, connect the printer to the computer and power on the printer.
    Note: If the installation cannot proceed even after 2 minutes, stop the installation by following the procedures below and start from the beginning again.
    1) Click 'Cancel' at the Printer Connection window then click 'Start Over' at the Installation Failure window.
    2) At the window to install the driver / applications appears, click 'Back' then click 'Exit'.
    3) Restart the computer.
    4) Install the printer driver again.
  7. For Windows XP, at the Welcome to the Found New Hardware Wizard dialog box, confirm Install the software automatically (Recommended) is selected, then click 'Next'.
    Note: The Welcome to the Found New Hardware Wizard dialog box may be behind the Printer Connection window.
    In this case, click 'Found New Hardware Wizard' button on the task bar to display the window.
  8. After the files are copied automatically and the dialog box Completing Found New Hardware Wizard window appears, click 'Finish'.
  9. If the Welcome to the Found New Hardware Wizard dialog box appears again, click 'Finish' again.
  10. At the Print Head Alignment window, click 'Execute'.
    Note:
    * The Execute button may not appear for all models. In that case, skip to step 13.
    * The Print Head Alignment can also be done after the installation of the printer driver.
  11. When the Start Print Head Alignment window appears, load one sheet of A4 or letter size plain paper in the sheet feeder and click 'Print Head Alignment'.
  12. At the Do not start another operation until current one has finished dialog box, click 'OK'.
  13. When the pattern is printed, click 'Next' at the Print Head Alignment dialog box.
  14. At the Installation Results dialog box, check the content then click 'Next'.
  15. At the Installation completed successfully dialog box, click 'Exit'.
    Note: When the Restart button appears, confirm that Restart the system now (recommended) is checked then click 'Restart'.
Dec 04, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Downloaded drver for my printer. the add new printer wizard can't
Hi ...
If you have the driver CD that you recieved with your printer, follow the below steps to install the saftware:
  1. Turn on your computer.
  2. On your computer quit any open applications, including virus checkers.
  3. Insert the MultiPASS MP730/700 Setup CD-ROM into your CD drive. The [MP Setup] splash screen will appear automatically.
    1. If MP Setup does not start automatically, on the Windows desktop, double-click My Computer (on Windows XP, click Start then click My Computer).
    2. Double-click the CD-ROM icon. If MP Setup does not start, double-click 'Setup.exe' (on Windows XP, 'Setup').
  4. In the MP Setup splash screen, click 'Install MP Drivers'.
    Note: For Windows 2000 users, if Service Pack 1 or later is not installed, MP Setup will display a message and installation will be aborted.
  5. Follow the on-screen instructions, clicking the appropriate button to move from one screen to the next.
  6. MP Setup will install some system files and may prompt you to restart your computer. If you are not prompted to restart, click 'Finish' in the MP Drivers Setup window and then proceed to step 7.
    1. If you are prompted, make sure radio button 'Yes, I want to restart my computer now.' is selected in the MP Drivers Setup window and then click 'Finish'. DO NOT remove the CD-ROM at this stage. MP Setup splash screen will open after Windows has restarted.
    2. If you had to restart your computer and the MP Setup screen is not displayed or you closed it, on the Windows desktop, double-click My Computer (on Windows XP, click Start then click My Computer).
    3. Double-click the CD-ROM icon. If MP Setup does not start, double-click 'Setup.exe' (on Windows XP, 'Setup').
  7. In the MP Setup splash screen, click 'Install MP Toolbox.'
  8. Follow the on-screen instructions, clicking the appropriate button to move from one screen to the next.
  9. At the MP Toolbox Setup dialog box, click 'Finish'.
  10. Confirm the MultiPASS is turned on.
  11. Connect the USB cable to the MP730 and computer USB ports. Windows will detect the printer and proceed to install the driver files.
  12. Your MultiPASS includes additional software applications that you can install now or at a later date. To install the software, click 'Install Utility Software' and then proceed through each installation.
You can also download the drivers by visiting the below link and selecting your operating system.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=9035#DownloadDetailAct
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Canon PIXMA MP190 'not responding'
There are possible causes of this not responding status message you get. you will try out these option i have listed here and see which one resolves the problem. after each one, try to print from a file and from the web.
1. Configure driver to correct printer port
On the 'Ports' tab of 'Printer Properties' window, select the correct port for the printer driver.
From the Windows desktop, open the printer's properties window.
Click the Ports tab.
Below 'Print to the following port(s)' section, select the port to which your printer is connected.
Click 'Apply' to accept the changes.
Click General tab and then click 'Print Test Page' to confirm the changes corrected the issue.
2. Checking USB Connections
You should disconnect and reconnect the USB cable at both ends to ensure there is a secure connection on the device side as well as the computer side. It may also be necessary to try a different USB port on the computer. Additionally, you may need to disconnect other USB devices, temporarily, in order to determine if a conflict exists.
Disconnect one end of the cable and then reseat it ensuring the cable is firmly seated into the USB port. If the USB cable is plugged into a hub instead of directly into the computer, try connecting the USB cable directly into the computer.
Repeat step one to reseat the cable on the other end.
3. If there is still no communication, then it may be necessary to try a different USB cable or a different port on the computer.
when you are through, restart the system.
4. Uninstall and Reinstall the Driver
If the MP Navigator or the MP drivers are no longer required, or if they are not installed correctly, uninstall them.
Caution: Uninstalling means deleting software, such as MP drivers, from the computer. Once the software has been deleted the unit cannot be used through the computer until the software has been reinstalled.
Note: Login as a user with Administrator privileges to uninstall . Turn off any programs running in the background, such as antivirus programs and firewalls before begining.
Select 'Program' (for Windows 2000), or 'All Programs' (for Windows XP / Vista) from the Start menu.
5. Reinstall the Drivers
Note:
This method is recommended if you are a first-time user.
Login as a user with Administrator privileges to install on WindowsXP/Vista/2000.
If the setup program does not start automatically, click 'Start' and go to 'My Computer', then double-click the CD-ROM icon.
If you use Windows Vista, select 'Computer' from the Start menu, then double-click the icon of the CD-ROM.
Note:
The installation of the MP drivers and application has completed. Proceed to the Canon user registration.
If you want to register now, click 'Register'. If not, click 'Next'.
Registration can be done after the MP drivers installation.
Then, Inkjet Extended Survey Program will be launched. If you agree, click 'Agree'. If you do not agree, click 'Do not agree'.
May 22, 2009 | Canon PIXMA MX310 All-In-One Printer
C4400 printer will not install, error 1935 fatal error alert.
Hi Swreardon,
How are you doing?
The issue which you have posted will generally occur if there is a WinTools Easy Installer program on your computer or even it occurs due to corrupted registry.
I can provide you the complete solution but for your clear understanding of the solution and to have a clear view of the solution so that you can easily perform the troubleshooting let me provide you with the weblink which ahs clear instructions:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00292756&cc=us&lc=en&dlc=en
Before using above weblink make sure you perform the steps below :
Step 1: Insert the HP printer software CD in the CD drive and folllow the steps:
If operating system is XP, Start>>run>> type" X:/util/ccc/uninstall_L3.exe and click OK. (where X is the Cd drive ) and follow the onscreen instructions.
If the operating system is Vista: open run window and type: " X:/util/ccc/uninstall_L3.exe" and click OK. (where X is the Cd drive ) and follow the onscreen instructions.
Here are the multiple steps to open run window in vista:
1. Press Windows Key + R to open the Run command window.
1. Open the Start Menu.
2. Click All Programs.
3. Click Accessories.
4. Run shortcut is located here by default.
Step 2: restart the computer and follow the steps given in the weblink above:
Step 3: once everything is completed download nad install the software by clicking on the weblink below:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=3655574 (For XP)
and use this link for Vista: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-57266-3&lc=en&dlc=en&cc=us&os=2093&product=3655574
Do not use the CD.
I am sure the issue will be resolved.
Best of luck.
Oct 25, 2008 | HP Office Equipment & Supplies
My Kodak Picture CD will not auto load
If your computer is operating with WINDOWS 95, WINDOWS 98, or WINDOWS NT 4.0 Systems, this CD contains software that automatically launches when you insert the CD. Getting Started:
Insert your Picture CD disc and wait for the software to load (it could take as long as 5 minutes, depending on your machine configuration, CD drive speed, and the number of images on the Picture CD).
Note: This loading process installs some Picture CD program files onto your hard drive. The KODAK Picture CD installer walks you through the steps. The final step may be to restart your computer. If so, be sure to restart to complete the installation.
After your computer has rebooted:
  1. Eject the Picture CD and re-insert it into the CD drive.
    The program should launch automatically.
  2. Click the magazine cover to turn to the Contents Page.
  3. Follow the links to read and do more with your digital photos.
If nothing happens after waiting for the Auto Play, you may need to manually start the Auto Play program. (Auto Play is a program that starts up the CD installation process the first time you use the CD.)
To manually start Auto Play:
  1. Right-click the My Computer icon.
  2. Select Properties from the pop-up menu.
  3. Click the Device Manager tab.
  4. Click the CD-ROM drive icon; click the "+" to view the CD-ROM drive information.
  5. Double-click the CD-ROM driver icon.
  6. Select Properties from the pop-up menu.
  7. Click Settings.
  8. Check Auto insert notification and click OK.
Note: This enables all CDs to automatically run any Auto Play software.
Sep 12, 2008 | Cameras
Ilo won't turn on.....
Sep 18, 2007 | iLO (2 GB) MP3 Player
Startup
here try this ok?
richard from chicago and let me know if it works for you ?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00273968&cc=us&lc=en&dlc=en&product=311255
Issue After installing the all-in-one and restarting the computer, the following Generic Host Process for Win32 Services error message displays: Windows has shut down a process for Win32 services: Data Execution Prevention - Microsoft Windows To help protect your computer, Windows has closed this program. Solutions The following solutions should be tried in the order they are presented. If the first solution does not correct the issue, proceed to the next solution; if that solution does not correct the issue, proceed to the last solution. Solution one Uninstall and then reinstall the software using the following procedure:
  1. Uninstall the software by inserting the software CD that came with unit into the CD-ROM drive on the computer. NOTE: If the startup screen does not appear, double-click the My Computer icon, then double-click the CD-ROM icon where the all-in-one disc is inserted. Choose the Uninstall option. If the Uninstall option does not display, the software is not completely installed. Proceed to step 2.
  2. Install the software by inserting the software CD that came with unit into the CD-ROM drive on the computer. NOTE: If the startup screen does not appear, double-click the My Computer icon, and then double-click the CD-ROM icon, where the all-in-one disc is inserted. Choose the Install option.
  3. Run the Software Update from the HP Director and apply all patches.
Solution two
  1. Uninstall the all-in-one software using the CD that came with the unit, by following the steps in Solution one above.
  2. After the software is uninstalled, restart the computer.
  3. Install the all-in-one software by following the steps in Solution 1 above. After installation is complete, verify that the unit works correctly.
  4. Change the Windows Image Acquisition (WIA) service from Automatic to Manual by performing the following steps:
    1. Right-click My Computer , then select Manage . The Computer Management window opens.
    2. in the Computer Management window, click the plus ( + ) sign next to Services and Applications .
    3. In the list below Services and Applications , select Services .
    4. In the right-hand side of the window, right-click Windows Image Acquisition .
    5. Select Properties .
    6. Change Startup Type to Manual .
    7. Click OK .
    8. Close the Computer Management window.
  5. Add hpqtra08.exe to the Windows Firewall Exception list by performing the following steps:
    1. Click Start , then Control Panel . (Click Start , Settings , then Control Panel if you are in Classic Start menu mode).
    2. Click Security Center .
    3. Scroll to the bottom of the new window.
    4. Click Windows Firewall .
    5. Click the Exceptions tab.
    6. Click Add Program .
    7. Click Browse .
    8. Select C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe .
    9. Click OK .
    10. Click OK .
    11. Close all open windows.
    12. Restart the computer and verify that the unit works correctly.
Jun 12, 2007 | HP Officejet 5510 All-In-One Thermal...
Computers & Internet Logo
43 people viewed this question
Alun Cox
