I just want to know if I can replace my Toshiba P305 S8906 Intel Core 2 Dou Processor T6400 Centrino 2.0 for a better and faster processor
    Problem Solver:
  • 12 Answers
Should be able to unless it's onboard. If not then yes. Just ensure that the motherboard will support the new CPU that you wish to install.
Posted on Mar 08, 2009
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
Is their a way to change the processing unit on my laptop. i have intel centrino and i was just wondering if you are able to change this
Hello Sir,
It depends whether your laptop has a removable processor or not. I f you have a removable one then you can replace it with a better one. Also if you have a centrino processor than you can only change it with a centrino one, a higher end procesor will not work. according to my knowledge most newer laptops dont come with removable processors these days.
Mar 18, 2010 | Toshiba Satellite Laptop
Which processor can I upgrade to?
Honestly, it is normally not worth it to upgrade the cpu on a laptop. Laptops are build to deal with a certain amount of heat and adding a faster cpu can cause the current cpu cooling fans to not get the job done anymore. You will seem instability in your system and could possibly damage it due to over heating.
With that said you would only be able to upgrade to a very slightly higher speed cpu and your money would be better spent else where. Some good ways to speed up a laptop are max out your memory or install a faster hard drive. For example if your current drive is a stock 5400rpm unit a 7200rpm drive would give you a nice boost. You could also look into a solid state option.
Both these upgrades will give your laptop a better boost without the hassle and risk of a cpu upgrade.
Aug 24, 2009 | Toshiba Satellite A105-S4334 Notebook
Hi I have just purchased a Toshiba Satellite p300 o5y note book,I've noticed that others just have dou core 2 and mine states Centrino Technology ? Is this a sales pitch or have a gained an extra by...
Click on Start > Right click my Computer > propities Then it should tell, Very unlikely to have a misplaced sticker.
also online models have the AMD Turion processor
AMD is cheaper in some cases, they do not advertise a lot like Intel, there fore you can get them at a lower price.
Is there anything else you need to know?
-Tom.
Jul 14, 2009 | Dell Dimension 3100 PC Desktop
Upgrade my Toshiba Satellite m105 s3041 processor (intel centrino
i assume that you've already run a utility to eliminate temporary files, clean the registry, cut down on background applications, and done a deep virus scan to eliminate anything stealing processing cycles. You might monitor your processor usage in the Windows Taks Manager - Performance to make sure the system is using the additional memory.
The only other thing would be to replace your HDD with a 7200 RPM drive for faster data access.
Jul 12, 2009 | Intel Computers & Internet
IBM ThinkPad T41, Upgrade my Intel Centrino Processor
make sure that the socket supports your new max Intel.
Feb 04, 2009 | IBM ThinkPad R40 2722 Notebook
IBM ThinkPad R40 Intel Centrino Upgrade to Intel Core 2 Duo?
According to system specs your system is not compatible with the Core 2 Duo or Centrino Core 2 Duo. To upgrade to those chips you would need to replace the motherboard with one capable of running those chips. If you decided to do that you would almost surely need new RAM as newer boards use newer technology. By the time you did this the upgrade would not be cost effective. Hope this helps & please remember to rate my answer. Thanks.
Feb 03, 2009 | IBM ThinkPad R40 2722 Notebook
E2180 Vs Athlon 64 X2 5000+
depends on what you plan to do with the cpu amd are good but a 3200 may only run @ 1.8 to 3.2 ghz depending while a intel 3200 will run 3.2 ghz.
I believe intel are more stable & run cooler than AMD but AMD benchmarks on Games better but run hotter (so get a good cooling fan & heatsink both pentium / celeron d & intel dou / dual core / core 2 dou and amd x2 have 2 cores (but watch your front side bus and cache the higher the better but the more $ also) then You need a good stable mobo that supports the chip you get (I preffer asus & msi for Gamers and biostar / msi for home users)
Sep 18, 2008 | AMD Athlon 64 X2 4600+, 2.4 GHz...
Difference b/w Core to duo and daul core
Core 2 Duo is a Brand name by intel to identify his class of Dual core CPU
a Dual core CPU is basically two CPU in one package, which dramatically improves performance over previous architectures.
Pentium Dual Core is another brand name by Intel to identify his new entry level CPU offer.Basically Pentium dual-core are similar to Core 2 Duos except they(pentiums) are slower and cheaper.
they both are dual core CPUs.
I would prefer a core 2 Duo having to choose a laptop because of better performance, but the prize is different for the two solutions.
Jun 28, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
