Question about GE WSXH208A Front Load Washer
GE front load washer WSXH208v1ww door latch
The plastic door latch that is fixed to the inside of the front door is broken and it will not keep the door latched once the wash cycle has started. It looks like a fairly simple and small plastic part held on with (2) small screws. I went to a GE website and tried to locate the part from a schematic but can only find the "door latch assembly" for $187.00. Does anyone know how I can find this part?
  • cfairle Mar 27, 2009
    Plastic piece that is held to door with 2 screws and in turn keeps door closed during operations is broken. It appears you can't just buy the $0.25 plastic piece, you have to buy the whole assembly for ~ $160.
    Are there "junk yards" for these machines anywhere?
  • Debby Gustavson Dec 28, 2012
    We found it for $99.00 online at partsdr.com
  • 1,543 Answers
Unfortunately, the "door latch assembly" is what you would need. It comes with a new concrete front tub counter weight which is redesigned to not be able to contact the door latch switch on out of balance spins. It is also a lot of work to replace. (you can not get just the little plastic part) Please don't rate this solution, as anything but a Fix-Ya lowers my score, and I know you don't want to shoot the messenger.
Posted on Mar 08, 2009
  • Shane Apr 27, 2013
    That is actually incorrect information. The latch can be purchased separately. My latch broke and I was able to order directly from GE Appliance Parts. The latch assembly is expense and if the interior of the lock mechanisim is not broken it would be foolish to purchase the full assembly. However, the individual piece was still $45 dollars (overpriced for a small piece of plastic that easily breaks)!
    New Friend:
When we went to push the start button on our front loader, it beeped twice, & would not start. We tried everything every blog told us to do, except the door latch. We thought it was ok, because it did latch.... hired a serviceman for $75.00 to come out & tell us it was the door latch system Part # WH10X10006 a GE Part. online price at partsdr.com for $99.99.. we're going thru searsParts direct..they offer more discounts!!!
Posted on Dec 28, 2012
My latch is not broken it just will not register that the door is locked
Posted on Feb 07, 2010
I don't know how your latch (schematic part # 214) was broken. Mine was broken in 2 places. Picture the latch screwed into the door and the breaks were horizontal through the "base" above and below the top most part of the the 2 protrusions that latch the door. I was able to cut out a piece of thin sheet metal and then "gorilla" glue the 3 pieces to the sheet metal backer and get it to work again. It worked for a couple of weeks and then yesterday one of the pieces came off again and I had to re-glue. I don't think I got a good bond between the galvanized sheet metal and the plastic back. Still looking for a better solution that doesn't involve paying $200.
Posted on Mar 27, 2009
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
Ge front loading washer door won't unlock
Some machines do this when the power is cut, there should be what looks like a screw heat on the front of the handle which will allow you to unlock the door and open it. If there is still water inside you will need to empty the machine first. There is usually a hatch at the bottom of the unit, open this hatch and you will find a cap to unscrew, unscrewing this cap will empty the contents of the machine onto your floor so be prepared!!!!!
May 08, 2011 | GE Washing Machines
The door on my Samsung Washer won't latch. It then displays DS error. Seems the roller in latch is down therefore not allowing door to close all the way.
This means your door interlock has broken & needs to be replaced.There made of plastic this is a very common problem with all brands of front load washer's.
Mar 13, 2011 | Samsung WF218ANW 4.0 cu. ft. High...
My door will not open on front loading machine, flashing F and DL, I UNDERSTAND THIS IS A MALFunction, how do I get it open?, and is the fix something I can do myself?.
U can remove the lower kick panal on the frount of washer/reach up inside the washer to the door latch/ there should be a small round plastic tab coming out of the bottom of the door latch pull down on it that is the manual way of opening the door. Far as the f code it is most likely the door latch u can access it by removing the spring on the bellows at frount of washer. once in there remove door latch screws and wiring and reverse the steps to put back ...any more questions with it just ask ....and good luck....
Jan 31, 2011 | Kenmore Elite 45986 Front Load Washer
Door jammed with a load inside and no power to the
Door lock mechanism is probably broken. Also circuit board in powerhead most likely has blown resister R-11.
To get the door open in an emergency, remove the plastic dish on the top of the washer. It should be held in by four screws. underneath you should find a plastic cord that can be pull to release the latch manually and open the door.
Aug 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
GE Front load washer - cannot unlock door
manual lock release is located inside front panel. remove lower kick panel and reach up on latch side and feel for plastic tab hanging from lock asm. pull down.
Mar 28, 2009 | GE WBVH6240F Front Load Washer
Getting a small plastic piece out of a door
If the piece is jammed (locked) in the door latch assembly, there is a manual release that you can use to open the door latch to see if the piece will come from free. The following link advises:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
This may require two people. One to pull on the manual release, while the other works on retrieving the broken piece from the door latch.
Another method may be to remove the door latch assembly so you can easily manipulate it outside the machine. This link explains how to remove the door latch assembly:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
Now...if the piece is jammed too far inside the door latch assembly, a last resort would be to replace the latch. I hope it does not come to that, but it may be a last resort. The link provided will give you all the necessary steps to complete this repair, if required.
I hope you find this information helpful. Let me know if you require additional assistance.
Nov 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
WSXH208V1WW front load washer won't drain - faulty pump?
remove lower panel behind panel will be pump after removing as much water as possible in tub remove access port on pump and clean also ckd as far into pump as possible ..pump can be removed and taken apart if necessary ..if pump is clean may be issue with pump impeller they will sometimes break or come loose on motor shaft if impeller free wheels replace pump
Oct 25, 2008 | GE WSXH208A Front Load Washer
GE front loader door switch wiring issue
Although there aren't any parts available for them these units ARE repairable. There are places along the sides of the case to unsnap the halves. Just be careful not to unload the spring inside
Dec 11, 2007 | GE WSXH208A Front Load Washer
GE WSXH208A Front Load Washer Logo
1,120 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
