Question about Cub Cadet Street Sign- tractor lawn riding mower parts
What will stop the electric clutch from fully engaging?
What will stop the electric clutch on a Cub Cadet M-60 Tank from fully engaging?
  • Anonymous Apr 26, 2009
    Check the belt to be sure it is actually on the pulley. If I engage mine with the deck all the way up it will throw the belt off the pulley. The belt will wedge itself under the pulley and spin blades but only about half speed.
  • 205 Answers
Electric clutches usually work or they don't. You may simply need a new belt or there may be an idler pulley or blade spindle with a bad bearing causing excessive drag. I have seen idler pulleys go missing altogether causing extra slack in the belt. good luck, Chuck
Posted on Mar 17, 2009
Older cub cadet mower runs fine until blades engaged starts stalling out
Check that the battery is fully charged. If the water is below the top of the plates it needs topped up. If it is old it may not hold enough charge to drive the ignition and the electric clutch. The clutch can draw so much power the ignition falters and so your engine dies. The engine charger may not be able to cope with the draw off when the clutch first comes in.
Sep 28, 2014 | Cub Cadet Garden
After reverse, my cub cadet zero turn mower pto will not re engage the blades. sporadic up to the point of stopping altogether. is it the switch or clutch?
I would guess it is the switch. My Cub Cadet has a safety feature where the blades (PTO) stop when you hit reverse. There is an override where you turn the key back about a quarter turn or so and hit a button right above the key to make the blades run even in reverse. Therefore, I would guess the ignition switch is the problem but I can't be certain. Or it could be the electric switch that engages the PTO.
Aug 10, 2014 | Cub Cadet Garden
Hello, I have a Cub cadet tractor model 2164, and
BEARINGS ARE BAD IN CLUTCH REPLACE THE PTO
Oct 30, 2013 | Cub Cadet Garden
PTO switch shuts down tractor
if the pto bearing is locked up it will stop a motor dead this is a common problem. You will have to get a new clutch assemble. The other thing that it could be is the deck has a locked up spindle.
Aug 19, 2009 | Oregon Scientific Electric PTO Clutch for...
Electric PTO on 1500 series Cub Cadet won't engagewithengine hot
its the electric clutch on the engine that engages the belt to run blades check the centrifical clutch or electric clutch
Jun 21, 2009 | Garden
Engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
Apr 11, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
480 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
