Question about Acer ASPIRE 3680-2022 Notebook
I have acer aspire3680. it was working well before. after i switch off after 8 hours later i try to turn it on but its not work. i try to plug the ac adapter but its nothing happen. i try to remove the battery and plug it again but it doesn't work. but the ac adapter is working when i try to another pc.. pleas hell..
  • ketut Nadro
    ketut Nadro Mar 09, 2009
    I have acer aspire3680. it was working well before. after i switch off after 8 hours later i try to turn it on but its not work. i try to plug the ac adapter but its nothing happen. i try to remove the battery and plug it again but it doesn't work. but the ac adapter is working when i try to another pc.. last time its before its happened like that but after two days i try to switch on its working,, what exacty happen to my laptop? any body can help?
    thanx alot..
  • 87 Answers
Your power button is bad sounds like.
Posted on Mar 08, 2009
Cara mematikan mode smart pada aspire3680
If this is about hard disk drive SMART (Self Monitoring) warning. Acer Aspire 3680 BIOS does not have an option to turn off this warning. Basically, your hard drive is dying and you need to replace it with a good working hard disk drive because sooner or later your hard disk drive will stop working. You can clone your hard disk drive using an hdd cloning utility such a Farstone Clone Drive.
Mar 05, 2014 | Acer Computers & Internet
My acer aspire 7736G was working fine, it's about 2.5 years old, and is used mainly with the power cord plugged in. When using it the other day the computer just went dead on me. I took the batter
You have reached the end life of the battery pack. The battery must have some minimum charge to have computer function even with the AC power pack connected. So I suggest you replace the battery pack as a solution. Any local Radio Shack store can test this battery I am told free of charge.
Jun 20, 2012 | Computers & Internet
No power from battery to laptop
are you installing it with correct polarity
is one of the battery terminals in the laptop damaged so that it is not making contact
May 22, 2017 | Acer Computers & Internet
Try find switch for wireless network
On the front bezel just to the left of the headphone jack is a Wireless switch/indicator. Slide the switch left or right to toggle - the LED should illuminate when wireless is on. The manual is available at http://support.acer.com/acerpanam/notebook/0000/Acer/Aspire3680/Aspire3680nv.shtml
Jan 08, 2011 | Acer Aspire 3680 Notebook
No power
Try to remove your battery and plug in your AC adapter
If its working:
You need to replace your battery
If its not working:
Try to check if the LED indicator is lit
If the LED indicator is not lighted. Replace your AC adapter
Thanks. Cheers!
Apr 20, 2010 | Acer Aspire One AOD150-1920 Netbook
Acer aspire laptop 3690 display black
Try unplugging the computer from the power supply,,and remove the battery,,,then replace battery and plug into power supply again,,,and try to restart.
Jan 19, 2009 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Stopped working.
It almost sounds like the computer has went into hybernation mode. I would hold the switch down until i heard a click (should take about 20 to 30 seconds). If that doesn't work I would find an authorized repair center for Acer computers.
Dec 01, 2008 | Acer Aspire 3680 Laptop
Acer Aspire3680-2633
Try removing the battery and reboot without the battrey attached using ac charger only,does this improve your situation?
Try reseating the hard drive,remove power before removing hard drive.
Jun 14, 2008 | Acer Aspire 3680 Laptop
Acer will not start up properly; "pulsing" On and Off
Hi Melody, Try removing the battery with the AC unplug for a couple of minutes (an hour preferably). Try with just the AC adapter only with no battery and see if it works; try with the battery only and see if it works, try with both the battery and the AC adapter and see if it works. If none of the above will make it work, then you have probably a hardware issue or BIOS power saving issue. Post back results of the 3 tries and will figure something else. Good luck and kind regards.
Sep 03, 2007 | Acer Aspire 5050-3242 Notebook
Open Questions:
Acer ASPIRE 3680-2022 Notebook Logo
61 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
