Question about Kenmore Elite 45986 Front Load Washer
F02 problem Our washer (Elite) is flashing the F02 and beeping. It won't restart. I can't find my manual to know what F02 means. Any help you can offer would be greatly appreciated. Thanks!
    President:
  • 1,294 Answers
This is actually for the Kenmore Elite, but it should help.
You have to check your filter to remove blockage. Lift the machine at front to have access to 3 torx screws under the front panel. Slide downwards out. Have a wet vac ready. You will see the pump filter right in front. Gently unscrew, water will begin to drip, use the wet vac. Remove the cap & pull the filter out to remove all debris & lint, make sure there is nothing in the impeller. Refit carefully.
Your dealer wants to make more $$ so he won't write these details in the user's manual.
Posted on Mar 08, 2009
    Scholar:
  • 87 Answers
I can't think of what that error is off the top of my head and the owners manual would not tell you what that code means. Take off the bottom panel of the washer (3 screws underneath usually 1/4" or #20 torx) and the tech sheet is inside against the right sied or on the back of the panel. It will tell you what that means and some tips on what to look for. If you have any questions let me know.
Kenmore elite he3 washer F02 error during wash cycle
You need to check for a blockage, F02 code indicates -- Drain blocked, kinked, drain filter plugged, or drain pipe exits too far above the washer.
Dec 22, 2012 | Kenmore HE3 Steam 7.2 cu. ft. Super...
We have a Kenmore Elite HE3, model # 110.45872 400. It goes through the cycle and almost at the end, it won't drain and flashes either F02 or F09. What is that and can we fix it? Thanks!
Hello, welcome to FixYa.
Based on your post I understand you have a draining error (looks like a F02 or F09 in the digital display...most likely F02 that is associated with the draining) with a Kenmore washer, the error means an excessive drain time or excessive suds was detected as you may or may not already know.
If you follow the link to my solution to this error designed specifically for "do-it-yourselfers" you should be fixed up in no time. (It's much quicker for me than pasting or retyping the complete solution several hundred times, that's how common this is)
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
Thank you for visiting fixya for your washer inquiry. Please take a moment to rate my assistance both here and on my tip link and leave a brief testimony.
Regards,
Macmarkus :)
Jun 29, 2011 | Washing Machines
Our washer door is locked and we cannot unlock it. we have unplugged the washer to try and reset it, but it does not help. the problem started with a F02 light flashing.
That F-2 means some junk is in the pump filter. Get the front panel off and you will find the tech sheet inside it. The error codes are shown with basic remedy's to try. Unplug the washer. Yall remove that pump filter cup and get the stuff out it. themobilian_1739.jpgthemobilian_1740.jpg
Service manual for Duet HE
Mar 05, 2011 | Kenmore Elite 45986 Front Load Washer
My Kenmore elite he3t is giving me a problem in the spin cycle. Even thought the spin setting is set on high or extra high, the drum turns very slowly and will eventually stop and the washer starts...
The machine will not advance to the high-speed spin cycle unless the water is drained first. The F02 error code manifests this condition as it means draining problem. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working. The display can be cleared by pressing the Pause/Cancel button twice.
Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Dec 20, 2010 | Kenmore Elite 45986 Front Load Washer
F 02 I reset it to drain and spin for the first load. already took the bottom panel off and cleaned out the white container. still not working for the second load, still flashing F02.
f02 means long drain. something is stopping it from draining. takes the pump out and look in at the impeller, something could be caught in it
Feb 06, 2010 | Kenmore Elite 45986 Front Load Washer
Washer stops and flashes F 02. I stop it and
"F02" is a Long Drain error code. This usually means the drain pump or drain lines are clogged, or you have a pump that is malfunctioning. Restarting the washer will not clear this code. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
If you need to replace the drain pump, they can be purchased on line at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. You can use any web source you like, but these, I have found, offer the best service and pricing. Shop all of them for the best price. Just use your model number (located around the door opening) for your search criteria.
Hopefully you won't require any parts. If you have any questions, please let me know. I hope this helps you.
Jul 19, 2009 | Kenmore Elite 45986 Front Load Washer
Our Kenmore Elite HE3 washer will not finish a cycle, flashing an error code of F02. Can you tell me what this is in reference to?
"F02" is a Long Drain error code. The following link explains:
In general, this usually means the drain pump or drain hoses are clogged and need to be cleaned. I have included instructions on how to do this as well.
It does not take much to damage these small pumps. Items begin caught in the pump impeller for extended periods of time can result in a pump that no longer runs, or one that no longer pumps at the correct volume. If cleaning does not solve your problem, the manufacturer recommends replacing the drain pump. Hopefully, a simple cleaning will solve this for you. Let me know if you have any questions, or require addtional assistance.
Jul 05, 2009 | Kenmore Elite 45986 Front Load Washer
Won't finish spin/drain cycle. was beeping and
long drain? remove lower cover on front..3 screws across bottom edge. there is a screw-on cover to a clean out. has a screen in there and may be clogged. prepare for a lot of water..u might lean it back against the wall to limit the mess. clean out is white plastic right up front.
Jun 12, 2009 | Kenmore Elite 45986 Front Load Washer
Error codes
I own a HE3 kenmore elite for 4 years now and the troubleshooting codes are: SUD When excessive suds are detected, a suds routine automatically starts. This causes the cycle to go longer to remove the excess suds. Reduce detergent amounts or use HE detergent. The F02 error I had with mine and it is a drain problem. Book says check the hose for kinks, clogged or is it more than 96 inches above the floor. On mine it was the fan pump on the forward motor that drains the washer. It was worn and not pushing out the water fast enough. You will hear a high pitched whine at the front bottom of the washer if this is bad. To reset the washer from the F02 error, select pause/cancel twice to cancel the cycle. Unplug washer or dissconnect power. good luck
Jul 07, 2007 | Kenmore 46462 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
88 people viewed this question
Sal De
fordexpert
Robert Rankin
