Question about Gateway GT5220 PC Desktop
My gateway usb port does not reconize my ipod
shuffle usb cable. They say my computer is to old.It is 5 years old is there any why I can be able to use
my ipod shuffle with the computer?
  • JDTec
    JDTec May 11, 2010
    It may be that your PC does not meet the specs for the iShuffle to work. What model is the PC?
    Problem Solver:
  • 12 Answers
You might neede to download the lastest version of iTunes from here:
www.apple.com/itunes/download/
That should solve your problem! =)
Posted on Mar 10, 2009
How do you charge an ipod shuffle
Connect the included USB cable to your iPod Shuffle.
Plug the opposite end of the iPod Shuffle cable into an open USB port on your computer, which must be turned on.
Check the light on the iPod Shuffle. If the light has turned on, the iPod Shuffle is properly charging.
Using iPod charger
Plug the iPod charger into a working electrical outlet.
Plug the opposite end of the iPod Shuffle cable into the USB port on the iPod charger.
The iPod Shuffle should begin charging immediately.
hope this helps
Sep 18, 2012 | Audio Players & Recorders
Tip
The iPod USB Charger
<p>The USB cable that came with all iPod has two purposes: to your device to your computer so you can update and add music, and iPod to charge. All iPods have a lithium ion battery stops charging when the battery is full, the total life of your battery is not affected if you leave the iPod is connected to a power source. It usually takes four hours to recharge most iPods. <br /> <p><br /> <p>1. Connect the USB connector into an available high-power USB 2.0 port on your computer. Low-power USB ports, such as those in external keyboards and hubs do not work. <br /> <p><br /> <p>2. Connect the 30-pin connector at the other end of the USB cable 30-pin connector on your iPod. If you charge an iPod shuffle, there is no dock connector port. Instead, use the connector on the other end of USB cable that fits in the headset. Set the iPod down and let it recharge. <br /> <p><br /> <p>3. Unplug the USB cable when the iPod battery indicator is full. If you charge an iPod shuffle, the green light will appear. <br />
on Aug 09, 2011 | Apple iPod touch
NEED INSTRUCTION FOR Apple iPod shuffle 3rd Generation Silver
Connect the iPod shuffle USB cable connector into a high-power USB port on your computer.
Note: To charge an iPod shuffle battery, connect the device to a high-power USB port.
Please be aware that USB keyboards and non-powered USB hubs generally do not have high-power USB ports.
If you connect to a low or non-powered port, iPod shuffle will not charge.
The computer must be turned on and set to not go to sleep.
Plug the other end of the iPod shuffle USB Cable into the headphone port on the iPod shuffle.
Verify the iPod shuffle is connected securely.
Once the iPod shuffle is plugged in, it will take about 2 hours to charge the battery to 80% capacity and about 3 hours to charge it to 100%.
Find out how to check the battery charge here
hope this helps
Sep 18, 2012 | Apple iPod shuffle 3rd Generation MP3...
How do I re charge battery with electrical plug
To charge the battery using your computer:
Connect iPod shuffle to a high-power USB port on your computer using the included iPod shuffle Dock. The computer must be turned on and not in sleep mode (some models of Macintosh can charge iPod shuffle while in sleep mode). When the battery is charging, the status light on iPod shuffle is orange. When the battery is fully charged, the status light turns green.
If you don't see the status light, iPod shuffle might not be connected to a high-power USB port. Try another USB port on your computer.
To charge the battery using an iPod USB Power Adapter If you do not have then you have to buy the same from Apple Store) 1 Connect the AC plug adapter to the power adapter (they might already be connected). 2 Plug the USB connector of the iPod shuffle Dock into the power adapter. 3 Plug the power adapter into a working electrical outlet. 4 Put iPod shuffle in the dock. You can disconnect and use iPod shuffle before it is fully charged.
Apr 05, 2011 | Apple iPod shuffle MP3 Player
How do i download songs to my iPod model no.A1204 EMC no. 2125? and how to charge it?
As with all iPods, you must use Apple's iTunes application to sync your music with your iPod Shuffle.
You'll need to install the latest iTunes by downloading it from Apple click here> and then installing it. You install iTunes like any other downloaded program by double-clicking on the resulting icon after iTunes has successfully downloaded.
Follow the on-screen directions to install iTunes.
Once iTunes is installed, start up iTunes and have it search your computer for music for it to manage for you. While that is going on, plug the white USB cable that came with your iPod into your iPod Shuffle and into one of the USB ports on your computer. This will trigger iTunes to recognize your iPod Shuffle and ask you whether you want to set it up with this computer.
Follow the on-screen prompts to sync your iPod Shuffle with your computer.
To charge your iPod Shuffle, just keep it plugged in to your computer using the supplied white USB cable. Keep the cable connected until the battery indicator on the ipod Shuffle shows that the battery is full.
Thanks for using FixYa and Happy New Year!
Jan 03, 2011 | Apple iPod shuffle MP3 Player
How do i turn on my ipod shuffle?.......and how long do i charge the battery for?... and how do i know my ipod is fully charged?
  • first i will cover turning the unit on. then i will cover how to charge the unit.
    -Move the power switch on the top of the iPod Shuffle to the "Normal" or "Shuffle" position.
  • Press the play button on the iPod Shuffle to begin music playback. If the iPod does not begin to play, follow the rest of the instructions.
  • Plug the iPod USB cable into the bottom of your iPod Shuffle and then connect the other end of the cable to your iPod power adapter.
  • Plug the iPod power adapter into a standard electrical outlet to charge the iPod Shuffle's battery. Try to press the play button again.
  • Connect the iPod Shuffle to your Mac or PC computer using the iPod USB cable. Then, open the iTunes program on the computer and sync your iPod with your music library. If your iPod Shuffle was frozen, it should now turn on.
  • to tell if the ipod shuffle is charging. Eject iPod shuffle in iTunes, but leave it physically connected to the USB port. The front LED should be orange if it's charging (or green if it's fully charged). If it's not charging (such is the case if it's connected to a low-power USB port on a keyboard), you won't see a front LED. If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
    Aug 25, 2010 | Apple iPod shuffle Second Gen. Silver (1...
    How to delete videos from an IPOD NANO
    1. Connect the dock end of the USB cable to your iPod.
    2. Connect the USB end of the USB cable to an available USB port.
    3. Open iTunes.
    4. Click on your iPod in the source pane. iPod.
    5. Click the subcategory Videos.
    6. Delete the video from your iPod.
    a. Right click the video.
    i. Command+Click on single button Apple Mouse.
    7. Select "delete" or "remove".
    8. Confirm the action.
    Oct 28, 2009 | Apple iPod shuffle MP3 Player
    My ipod shuffle 2nd generation won't turn on and I don't know if the charger even works. My computer won't read my ipod shuffle or notice it.
    http://www.apple.com/support/ipod/five_rs/
    If this doesn't fix it, and it's over a year old, and you don't have an AppleCare Protection Plan... Recycle it, because man, it's gone.
    BTW: The unit charges off of a standard USB port. Double check the connection and USB cable for defects and try another computer and USB cable.
    -=/ MLF /=-
    Oct 20, 2009 | Apple iPod shuffle Second Gen. Silver (1...
    Computer not reconizing ipod.
    yes, you may need to get a new port. did you try restarting your iPod by holding in the center and menu button? if that doesnt work then its definatly your port. good luck!
    Dec 26, 2008 | Apple iPod MA446LL/A MP3 Player
    Gateway GT5220 PC Desktop Logo
    178 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
