My acer Aspire 5535 makes a bleeping noise when switched on.
When switched on srenn is blank and bleeping is constantly.
Pressing ALT CTRL DEL is the only way to stop it then it powers itself up again.But every you time it swiches on it bleeps again.
  • aaron_singh Mar 08, 2009
    It is before i can log into windows. Its as soon as i switch the laptop on.
  • MikeyTh May 11, 2010
    You're have to clarify, is this before you can log on into Windows, during post/bootstrap sequence, or is this after you log into windows?
My Acer aspire r11 laptop just wouldn't turn on the Acer logo appears on the screen and then the screen goes blank for 3secs and then it repeats?
Pull the battery out and unplug the charger. Turn the laptop over and press the on/off button 3 or 4 times. Turn it over again, re-install battery and power on again while pressing F8. This should take you into safe mode. If It turns on in safe mode, get back with me and I'll lead you through a diagnostics test.
Jun 07, 2017 | Acer Computers & Internet
How do I get it to go into bios when pressing f2 doesn't work?
Per the internet site, it depends upon the model of laptop. Here are some examples:
Laptops - Access Bios Settings Key
Issue
The most common Access Bios key is the "DEL" button or "F2". This depends on the laptop model, however, and can be confusing if you do not know which key to press.
Solution
Here is a list of laptop models and brands with the keyboard commands / key for accessing the BIOS Setup:
Acer: F1, F2, CTRL+ALT+ESC
ARI: CTRL+ALT+ESC, CTRL+ALT+DEL
AST: CTRL+ALT+ESC, CTRL+ALT+DEL
Compaq 8700: F10
CompUSA: DEL
Cybermax: ESC
Dell Laptops:
Dell 400: F3, F1
Dell 4400: F12
Dell Dimension: F2 or DEL
Dell Inspiron: F2
Dell Latitude: Fn+F1 (while booted)
Dell Latitude: F2 (on boot)
Dell Optiplex: DEL
Dell Optiplex: F2
Dell Precision: F2
eMachine: F2
Gateway 2000 1440: F1
Gateway 2000 Solo: F2
HP (Hewlett-Packard): F1, F2 (Laptop, ESC)
IBM: F1
E-pro Laptop: F2
IBM PS/2: CTRL+ALT+INS after CTRL+ALT+DEL
IBM Thinkpad (newer) Windows: Programs-Thinkpad CFG.
Micron: F1, F2, or DEL
Packard Bell: F1, F2, Del
Seanix: DEL
Sony VAIO: F2
Sony VAIO: F3
Tiger: DEL
Toshiba 335 CDS: ESC
Toshiba Protege: ESC
Toshiba Satellite 205 CDS: F1
Toshiba Tecra: ESC then F1 or F2
Toshiba Notebook [Newer models]:
  • Turn on the computer by holding down the power button while pressing the ESC key
    • The machine will beep, then display:
    • Check System, then press [F1] key.
  • Release the ESC key
  • Press the F1 key
Laptops Access Bios Settings Key
Apr 03, 2015 | Computers & Internet
Windows cant open bootmgr is missing, press ctrl+alt+del but not working how to fix it aspire one D257
Have you tried a System Restore/Recovery? Can you boot to safe mode? Try the restore/Recovery procedure: Shut down, unplug, remove battery, plug in, push the on button and When Acer splash is on screen hold Alt and keep pressing F10...
Apr 14, 2013 | Acer Aspire One D257 Netbook
How do I get into safemode on my acer aspire desktop
1 Restart the Acer Aspire netbook by pressing the "power" button on the netbook's keyboard or by pressing the "CTRL," "ALT" and "DEL" keys at the same time. 2 During startup, hold down the "F8" function key immediately when you see the "Acer" splash screen and the option for entering "Setup." 3 Keep pressing the "F8" key until the "Advanced Boot Options" menu appears. If you receive a "keyboard error," restart the Acer Aspire and repeat step 2. 4 Use the arrow keys to navigate to the "Safe Mode" selection on the "Advanced Boot Options" menu. The arrow keys are located on the right-hand side of the Acer Aspire keyboard. 5 Press the "Enter" key to execute the "Safe Mode" selection. The Windows operating system will now start in "Safe Mode" and you can perform a system restore or make needed changes to get your Acer Aspire to boot normally again. Read more: How to Boot Up Acer Aspire in Safe Mode ' eHow.com http://www.ehow.com/how_5802430_boot-acer-aspire-safe-mode.html#ixzz1dtOxfxaD
Nov 16, 2011 | Acer Aspire Computers & Internet
My Acer Aspire 1 will not boot properly. There ia a small white cursur blinking in the upper left corner. I tried Alt f10 but that did not work:-( Do you have any suggestions?
Reboot (by pressing Alt Ctrl Del) press F2 frequently after reboot to go to bios setting. Make sure NO flashdisk/ thumbdrive plugged in to usb port. Choose hardrive as firstboot (in the bios setting under the boot tab) save the changes and exit
good luck
May 19, 2011 | Acer Aspire One Netbook 8.9" Notebook
Is there any site i can download a factory restore disk for acer asire 5535
there is a built in partiton on your hard drive containing the original windows and programs that were installed when you first bought the laptop, this can be accessed by pressing alt & f10 when the laptop is first switched on
Apr 09, 2011 | Acer Aspire 5535-5050 Notebook
Acer aspire 5535 .When swiched off will not start again.When left switched on for indeterminate time(1hr-8hrs), power light active no hard drive or internet lights screen blank, can switch main sw off and...
have exactly the same problem, and same laptop, what operating system do you use, becuse my problems started after i changed to windows 7, had my one for 20 months as well more or less
Sep 19, 2010 | Acer Aspire 5535-5050 Notebook
Solution to forgotten password
IF ITS WORKING ON XP .. THEN ALL THE LOGIN PAGE PRESS CTRL+ALT+DEL TWICE AND IN THE WINDOW THAT APPEARS TYPE ADMINISTRATOR AS USER NAME ... LEAVE THE PASSWORD BLANK TRY LOGGONG IN
Sep 15, 2008 | Acer Aspire 5100 Notebook
NTLDR is missing
You need to reinstall your xp or use the restore cds /dvds that came with the laptop to repair the windows startup problem.
Files missing / corrupt.
May 08, 2008 | Acer Aspire 5100 Notebook
Screen freeze
Try go to safe mode. press f5 during boot (for xp) and f8 for vista.
Feb 17, 2008 | Acer Aspire 3690-2196 Notebook
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
