Question about Toshiba 57H81 57" Rear Projection Television
57H81 projection tv has very wiggly picture.
I have a 57H81 rear projection tv. The entire picture is very 'wiggly' and distorted. The edges of the picture are like a saw tooth and that distortion pattern follows across the entire picture. Once in a while a few white verticle lines will appear on the picture. However, if I use the POP function to bring up the second picture right along side the first picture it will be perfectly fine. Both pictures side by side on the same channel and the first one is distorted and the second one is perfect. Any ideas? I have pretty good experience soldering and feel I confident in my abilities to do the repair, I just have no experience in diagnosing tv issues. Any help will be greatly appreciated. thankyou
    President:
  • Toshiba Master
  • 1,779 Answers
This is the Hyper Module that needs repaired. There are several small sm caps that dry out in this model. It's the module standing up to the right covered by a can as we call it. I really don.t recommend you trying to repair it. One slip and that module is done and you can't by a new or rebuilt one anymore. Please let a repair center look at it and do the work. You won't regret it.
Posted on Mar 10, 2009
I have a RCA Scenium HDLP50W151YX1 that has distorted Color (Bad Picture)
I am parting out my tv it was playing good when I shut it off we got a wall hanger we don't need this tv let me know what part you need I'll sale them cheap 2705898074 call me if you want
Oct 02, 2012 | RCA HDLP50W151 50" Rear Projection HDTV
Got used Toshiba 57H81 and picture is fuzzy like 3D. Touch focus error message shows.
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 27, 2011 | Toshiba 57H81 57" Rear Projection...
Hi, our toshiba rear projection tv will turn on but no picture. whats the problem? thanks
MODEL NUMBER 56H80 TOSHIBA PROJECTOIN TV,PICTURE IS NOT COMING AT ALL
WHATS THE PROBLEM
Feb 04, 2011 | Toshiba 57H81 57" Rear Projection...
Fuzzy/ distorted tv pic
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 22, 2008 | Toshiba 57H81 57" Rear Projection...
Picture is distorted
Is your TV near anything magnetic ? This causes picture issues. If the thing is a tube TV then you can fix this fault with a magnet. Call 0845 20 20 118 for help
Nov 22, 2008 | Sony KP-51WS520 51" Rear Projection...
Samsung HC-P4752W 47" projection TV distortion & yellow?
I think you have a fault on the chroma board and on the picture frame board. If you can trace it yourself try these two locations otherwise call out a competant technician. hope this helps.
Sep 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
DIstorted picture for 480p input only
Many set have two differant convergance settings one for 480 and one for1080 this is because when it changes mode the set runns a differant frequencys, what may have happened is you have a cold solder joint somewhere that takes this fifteen minutes to corect itself, might want to start by resoldering the convergance and high voltage curcuits
Jan 02, 2008 | Toshiba 57H81 57" Rear Projection...
Distorted Picture Upon Startup
You have a bad capacitor in your power supply.
Dec 22, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 57HX81 57 in. Rear Projection
Im guessing the the convergance ic are bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 19, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
156 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
