Question about Frigidaire Refrigerators
No water at door (or ice!)
Hooked up fridge to water source. No water at door! Removed filter (PureSource Ice and Water filter) Still no water @ door. Yes I did turn on the water at the wall! LOL Label inside fridge @ back does state that water can be dispensed w'o filter in place, but it does not dispense. What do I need to do or address next?
    President:
  • Frigidaire Master
  • 2,651 Answers
First off manke sure t hat yo keep the paddle depress fpr a few mins, it will need to fill a resevoir inside the regfrig sect, may take am in beofre the water flows freely
Posted on Mar 08, 2009
  • susanrice1 Dec 05, 2010
    same problem...the new filter fills with water, but is not being pumped into hose for dispenser. what now?
Ice tastes bad
If It were me I would change the filter in the fridge, that always worked on mine.
Dec 03, 2013 | LG LRFD22850 Bottom Freezer Refrigerator...
Maytag fridge(water-ice) ice will not come out
The water source is plugged somewhere either at the ice-make or before it, could be the feed lne to the fridge, may also be the filter if you have one
Aug 22, 2009 | Maytag MSD2542VE Side by Side Refrigerator
I Have a FRS22ZRGD1 Double door fridge freezer combo , the ice does not get any water . I have water to door to fill glass. I replaced water filter a pure souce type. I replaced solinoid valve still no...
For all of you having problem of not getting any water to ice maker the water line running from solinoid valve to ice maker , mine was plugged solid with ice- try blowing through it once you have line removed from solinoid valve. I know they say you can removed the ice with a blow dryer but I tried that the ice was too far down to melt it .I took the line loose from the back of the fridge and un attached retaining screw and pulled plastic insert through cavity of fridge and ran hot water through it. Now it works fine.
Apr 17, 2009 | Frigidaire FRS26ZSG
Water and Ice in Door Tastes Awful!!!
If your water tastes ok without the fridge then you'll need to replace or clean the piping inside the fridge.
If your water has the same smell and taste without the fridge then you'll need a better grade filter on the water going into the fridge.
If it's in your fridge piping try going to a plumbing supply and ask them for a cleaner to run through the fridge!
jack
Mar 08, 2009 | Amana SXD524VW Side by Side Refrigerator
Replacing filter for ice and water!
Have you tries just removing the filter and putting it back in? I have a GE and all I do open and close the filter door. to clear it. Ge has the six month timer but if you pull it up on the display it will give you a percentage of filter life.
Aug 04, 2017 | Kenmore 26.0 cu. ft. Side-By-Side...
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
HOOK UP OF ICE MAKER TO THE WATER LINE
The ice maker is not making any ice, or water or crush ice. The wheel that crushes the ice will not spin. Please help
Apr 22, 2008 | Refrigerators
Side by side refrigerator
The ice maker is not producing ice or not enough ice
production.
OR
The water dispenser will not operate properly
 Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.”
 Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
Supply Requirements.”
 Kink in the home water source line? Straighten the water
source line.
 New installation? Flush and fill the water system.
 Water filter installed on the refrigerator? The filter may be
 Is a reverse osmosis water filtration system connected to
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Jan 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
248 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
