Question about LG Studioworks 563N 15" CRT Monitor
Menu button of my monitor is not working properly
My monitor screen has shrunk and appearing in 3 vertical parts. . horizontal position of the menu button is not working
  • Anonymous Mar 24, 2009
    size button is working only vertically not orizontally. screen icon is shrunk on both sides.
  • decentarsi Mar 27, 2009
    my monitor display extended beyound the screen and horizontal button is not working. Also the display is curved
  • 700 Answers
Try to fix that on display setting under windows display setting set it on lower setting. You can do that alternatively by booting on safe mode. Then readjust your display setting.
Posted on Apr 11, 2009
RESET DELL MONITOR E1709WC
Instructions
    • 1 Push the "Menu" button on the front or side of your Dell monitor. The button's icon resembles a miniature monitor. This will open the main monitor setting menu. Push the button again to exit the main menu and open the OSD menu.
    • 2 Push the "Down Arrow" button on the monitor to scroll through the OSD menu. Stop at "Factory Reset." Push the "Menu" button to open the factory reset menu.
    • 3 Push the "Down Arrow" button to select "Position Settings Only" to reset the monitor's horizontal and vertical screen settings. Press the "Menu" button to activate the setting changes.
    • 4 Push the "Down Arrow" button to select "Color Settings Only" to reset the monitor's red, blue and green color settings. Press the "Menu" button to activate the setting changes.
    • 5 Push the "Down Arrow" button to select "All Settings" to restore the monitor to its original factory settings. Press the "Menu" button to activate the setting changes.
    • 6 Push the "Up Arrow" button to select "Exit" to leave the monitor reset menu. Press the "Menu" button to exit the OSD menu. Push the "Menu" button again to exit the main settings menu.
Aug 02, 2012 | Dell Computers & Internet
My computer's all windows screen has suddenly shrunk today with a black border in right and left side. Now how can I get ride of this problem and make my windows screen normal again?
It's probably the monitor either was adjusted or is having a problem.
Use the buttons on the monitor to adjust the horizontal width on the screen...This should stretch your windows display across the screen if you adjust properly. Most monitors also have an auto adjust option...you can try that too.
I can't tell you exactly what the menu options are, because I don't know the buttons on your monitor. but if you find the menu, you should be able to make the adjustment.
Good Luck
May 26, 2011 | Computers & Internet
Virtical picture cut on the screen about half inch.
Depending on the monitor, you can try looking for an "Auto-Adjust" button. Pressing that should automatically realign the screen to it's proper proportions. If not, the monitor should have a menu where you can locate options to adjust the horizontal and vertical zoom, as well as position.
Mar 29, 2011 | Computers & Internet
Installed AOC 2436vh, top of screen off of physical structure of screen, tried power down, physical reinstall, roll back of driver and reload of cd, how do I uninstall monitor to try again? Or adjust it...
I have the 2436V (no speakers), but I suspect the solution will be similar. My screen was a bit to the left of the monitor's physical display area, and I was able to solve it using the built in menu (If you take too long deciding what menu button to press next, the menu will time out. Just start over if that happens. You will get faster with practice).
1) Press the menu button on the monitor (the menu appears).
2) Press the up button on the monitor 4 times to highlight the icon that looks like a slightly angled screen with yellow cross-hairs in one corner (the toolbar for positioning the screen appears - all 5 icons on the positioning toolbar are blue).
3) Press the menu button on the monitor to "enter" the selected toolbar (one of the toolbar icons turns green to indicate the selected tool on the toolbar).
4) Select the tool you need using the up/down arrow buttons on the monitor (I needed the one that moves the screen horizontally, you need the one that moves the screen vertically).
5) Press the menu button on the monitor to activate the selected tool (the meter above the toolbar icon turns green to indicate the tool is active).
6) Use the up/down buttons on the monitor to position the screen.
7) Press the menu button to exit back out (or, just let the menu time out).
Note: the disk that came with the monitor doesn't seem to have drivers for Windows 7, but allowing Windows to search online while updating the driver found a compatible driver online.
Dec 22, 2010 | AOC Monitor
My screen is off to one side and i cant get it back to normal
Use the Menu Button on the enter into the Monitor menu setting.
Select the horizontal or vertical adjust menu depending on which is the one affected and press the menu to select it.
Adjust till you get the correct position using the +/- button. Press the Menu and scroll to exit to quit the setting menu.
Dec 30, 2009 | Lenovo Thinkvision 19" LCD Monitor
My monotor its all black but u can
This should be an (LCD) screen. They are the ones that usually have this kind of problem. You will need to take it to have it checked if the problem is the VGA signal cable leading to the monitor. They will check if it is properly connected or has gone bad. It is very unlikely that the screen is bad. When this VGA signal cable goes bad it could result in a totally blank screen.
Sep 13, 2009 | Dell Computers & Internet
Black at left and right of monitor
Since this is a CRT monitor, it doesn't have a native resolution like LCD monitors. You need to adjust the veritcal and horizontal sizes to fit the monitor. On the front of the monitor there are some menu buttons. You need to open the on-screen menu, then navigate to the Horizontal Size and Position menu, use the plus and minus buttons to grow and shrink the image. If it's not centered, use the Horizontal Position menu to move it around. Use this same system for the Vertical menu and you can get your image to fit your screen. By the way, you should have your operating system running with a white (or light colored screen) up when you do this so you can see all the edges of your desktop. The buttons are tricky, but they kinda make sense. Good Luck!
May 14, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Display adjustments
Is the H. Position not showing up in the menu? Or is it that you can't seem to get to the Horizontal positioning that is the problem? Usually there are 4 keys: Auto, <, >, and Menu (I'm NOT counting the power button of course) Menu starts off the process while the < and > get your through the menu. When you see the V. Position, hit the "menu" key and the H. Position should pop up.
Mar 26, 2007 | HP P1110 21" CRT Monitor
Screen Adjustment
On your monitor at the bottom there is 3 buttons. The one all the way to the left is the "menu" button. The next one (going right) is the "NEGATIVE" button. The next one (going right) is the "POSITIVE" button.
You can move your screen around. First, start by pressing the menu button.Then, a menu in blue, with a bunch of little white icons will appear. Next, go over two icons by pressing the positive button twice. Then, proceed to push in the "menu" button again. A bar will appear. By pressing your negative button, your screen will move left. Pressing your positive button will make your screen move right. Adjust your screen until the black on both sides are of even proportion. Then, press the menu button to return to the orginal menu you started at. Proceed to press your positive button two more times. Then, press your menu button. Then, once again, use your positive button, and your negative button to adjust your screen to even out the black on the top and bottom.
Dec 24, 2006 | HP Compaq FS 7550 17" CRT Monitor
LG Studioworks 563N 15" CRT Monitor Logo
570 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
