Question about Hotpoint Aquarius WF000 Front Load Washer
Washing machine motor works fine on spin but on wash, very weak w
Hi OK my hotpoint washer as an AEG motor, it wont turn the drum on wash cycle, seems to struggle, but on spin cycle it works fine very `strong` and on 1400 spin it trips the RCD on the mains.
Its not the brushes as they just wouldnt work at all would they, and they would crackle which they dont.
  • dave2812 Mar 10, 2009
    hi yea done all that ages ago, brushes have loads left on them and they are clean and so is the com, all fine i reckon its a board fault
  • 20 Answers
Hi Dave, you got the answer right all on your own mate, it is brushes related, I had a similar problem ages ago and as it turned out it was the brushes breaking down, what you need to do is remove them both and clean the armature with some fine glass paper, inspect the brushes and make sure they slide in and out of their housing easily (no obstructions) then if they do, fit them back in to make sure they can reach the armature.
Posted on Mar 10, 2009
Hotpoint Wt540 1400 wont spin
check the machine washes ok if it does not turn the drum on wash check the motor brushes if drum action is ok on wash check the drain pump for blockages
Mar 06, 2014 | Hotpoint Aquarius WD63 Front Load...
My hotpoint ultima wont spin, its as thought something is preventing it for spinning. When its switched to spin cycle it turns a little to the left, then a little to the right, but cant seem to go any...
Things that couse this are, worn motor brushes, unplug remove the top, the motor should be at the top, if so remove the wire attached to the spade of the grey cartridge then unclip using a very thin screwdriver pushed down the back of the cartridge, and slide out if there is only a small peice of brush showing they must be changed, if ok spin the drum by hand if it moves freely the the drum is ok, the last thing to check is if it moves through the wash, but its just the spin that it wont move, there is a blockage, and the preassure vessel wont allow it to spin.
Jul 10, 2009 | Hotpoint Ultima WD72 Front Load...
Hello i have a hotpoint wma40 the machine will go
Hi, i have a wma40s had it for 7 ears now same thing happended would start a cycle but then stop halfway through make the noise but the drum would not spin etc. i bought some carbon brushes of ebay for 7 quid and it works better than its worked in years bit nosiey for first few washes but after it settles it is as good as new.
Jul 06, 2009 | Hotpoint WMA40 Front Load Washer
Hotpoint motor problem after renewing drum bearings!
Hi dave, Its nothing you have done! It will need the carbon brushes changed in the motor as they have got low. The arcing is caused by the brushes not touching the com properly. Just change them and it will be all good.....
Mar 07, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Washing machine won't spin
Do you hear the motor spinning loud whirring noise,when drum is not,if so drum belt has come off or snapped,if no noise possible brushes on motor need replacing
Jan 18, 2009 | Hotpoint Ultima WD72 Front Load...
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
If the machine pumps water inside but does not start :
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details , see: It doesn't spin
See also a general diagram here: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Jan 06, 2009 | Hotpoint WMA30 Front Load Washer
Hotpoint Ultima WMA61 loud knocking noise in spin cycle
Hello I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. Also another way to check is to move the inner durm up and down to see if there is any play in it..
If you need any further advice then dont hesistate to ask....
Jan 14, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Drum wont turn
check for worn carbon brushs in the motor.good luck!
Dec 01, 2007 | Hotpoint First Edition WMA20 Front Load...
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WF000 Front Load Washer Logo
179 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
