Question about Nintendo 64 Console
My nintendo 64 wont workon my tv!!
My nintendo 64 turns on but the screen stays the same.....blue,
im tyring to tune my channel frequecy thing but i need help............ANYONE!!???
  • charliewhitb Mar 10, 2009
    Is IS! soeone saiddo a channel frquecncy thing but i dont know what frequency to tune it to
  • charliewhitb Mar 15, 2009
Im tryin to connect a nintendo 64 to an akura t.v but the screen stays blue and dont work!! how do you do it??? plz help
Posted on Jan 15, 2012
  • 31 Answers
First you must be sure that the connection on your tv is securely connected.
Posted on Mar 08, 2009
Luxor TV Nintendo 64 tuning
Could have a bad cable. If its a coaxial cable, it should display over channel 3 or 4. Check you TV settings, might need to change the broadcast option(Digital/Analog). Or get an rca cord(red/white/yellow connectors) if your TV takes composite/component inputs. Good luck.
Mar 28, 2014 | Nintendo 64 Console
How to connect nintendo 64 on a dish network tv
Can I connect my Nintendo to my Cable Box, my DVD, or my VCP (video cassette player)?
Your Nintendo system requires AV inputs to work. These products do not provide inputs. Connecting to them is not possible. Unless you get a blue plug for it to work then with the connection then.
Aug 01, 2012 | Nintendo 64 Console
My nintendo 64 is hooked up to the video/audio input on my tv but the screen wont change! it stays blue. how can i play it?
Usually if a Nintendo 64 won't start up even though it's connected properly, it's because the cartridge contacts are dirty. Try blowing out the cartridge slot with canned air, that usually works for me. If that doesn't work, you may also need to clean your game(s).
May 11, 2012 | Nintendo Video Game Consoles & Games
My nintendo 64 won't work. The red light goes on but nothing happens on the tv screen, it just stays blue. :/ wtf should I do? I've already blew on everything I can think of and wiggled the cartridge...
Well its a power supply failure symptom a blue screen is then. when games or other applications are using the computer steadily, it will turn off or I get a blue screen.
Oct 25, 2010 | Nintendo 64 Console
TV not tuning to Nintendo 64
try with another tv if it dosent work on that too your 64 is passed away
Feb 21, 2010 | RCA Mikomi 5290925 15 in. LCD TV
Im trying to connect a nintendo 64 to a Matsui HDTV but i dont know which 'source' to select or what channel to select when i choose the right source. Ive plugged in a cable which allows me to switch...
If connecting by co axial or aerial type connection then you will have to tune in a channel using either manual or automatic tuner on the TV. It would be better/simpler if you had phono or scart connections from the nintendo
Feb 14, 2010 | Nintendo 64 Console
When we turn on tv the nintendo screen does show up
There are a couple things this could be... check:
Is the tv set to the correct channel or "input"?
Is your game clean? (use rubbing alcohol on a q-tip to wipe the gold bars on the inside of the game)
Do you have a bad AV cord? (I think you can find new ones on ebay or potentially a vintage video games store that sells super nintendo games, they usually are willing to test it in store with a new cord).
Hope this helps!
Jan 16, 2010 | Nintendo Super Mario for 64
TV does't register the Nintendo
Probably so, if the video cables match up color wise then you should be ok there. Try changing the INPUT / SOURCE on the TV. Look for a button on the remote that says that and try different modes and inputs there. If you can't find that button try going to channel 2 on the TV and then going DOWN in channels with the the channel + - button.
Every TV is different in that regard.
Hope this helps
Aug 31, 2009 | Nintendo 64 Console
Can't work nintendo 64 with a antenna connector. help?
Yes you will, you will have to find an un assigned channel and get the tv to fine tune it in.
Jun 01, 2009 | Nintendo 64 Console
Says unusable signal when trying to hookup my Nintendo 64.
Here are a couple of things to try. Go into the menu and make sure that you have the "ANTENNA" selected instead of "CABLE". Also make sure that the channel that you are using (3 or 4) is programmed into the memory of the tv. If not, use "auto program" in the menu to program the channels.
These newer tv's are not the same as older tv's. If none of that works, put a antenna amp on the output of the nintendo and then plug it into the tv. This should fix it.
Nov 17, 2008 | Televison & Video
Nintendo 64 Console Logo
1,102 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
