Question about Toastmaster TP409 4-Slice Toaster
Tp 409 smells burn when turn it on
Every time I turn the toaster on I smell plastic burn , but it still heat up well.I check all the wires and they are ok . I was thinking if it could be the element (part number 3001805).Thank you !
  • 25 Answers
I would advise checking the elements as well. It is possible that plastic has melted onto the elements. Try to Identify which slot the smell is strongest. If there is a spot where the elements do have some sort of foreign material melted to them, you may need to replace them.
I
Posted on Apr 18, 2009
Why does my dryer smell like burning wire?
the heating coils in these dryers sag over time & if they're touching this could be what you're smelling
get it looked at
Aug 22, 2014 | GE Dryers
Engine died burning smell
If the smell is like burning oil or really hot coolant. you may have killed the motor. If it smells like burning plastic ,look for shorthing wires around the exhaust manifold battery, alternator or place that a wire could be burnt. If a rubber smell check for belt failure.
Jan 19, 2013 | Toyota 4Runner Cars & Trucks
Dualit lite 4 slice not working
It can be repaired. There is a short circuit inside may be of dust gathering on contacts or the contacts are worn out due to prolonged use thus touching the heating coil or body some where inside. Smell coming is definitely burning of wires inside. Open the toaster and you may be able to see the burning spot
Jan 09, 2010 | Dualit Lite 4 Slots 4-Slice Toaster
Chemical smell
Might be Plastic part is Melting due to Heating Element or a Burning Wire might cause Such Smell.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 10, 2009 | Fahrenheat Electric Hydronic Baseboard...
Smell of electrical burning.. no more heat in house!
First of all keep this in mind.
You will need to locate the wires that got hot. If you can't or if your not sure, I suggest that you call a service company. If they ok the unit and it catches on fire after wards, their insurances will cover you unit and or home if god forbid it burns. This is to be on the safe side.
Now, this is where I would look. Your element should be on it's on circuit. There should be a disconnect within reach of the air handler. Some are fused and some are not. The wires that got hot enough for you to smell them should show signs of being hot like the plastic will be melted around the wire. You said that the heater was running. Was this the first time you have used it this year? If so, are you sure it was not the dust burning off the elements? They will smell like something burning when you first turn them on each year. Although if your sure you smelled wires getting hot, please continue looking for just that. Keep in mind that the elements have 220 volts coming to them. It comes into the unit and go to a switch or relay. From there the power goes to the elements and then to a neutral. These are the wires you will need to pay the most attention to. Good luck.
Nov 23, 2009 | Heating & Cooling
I have a Kenmore Elite microwave oven... 69-65e05590-000637. We noticed that it would not heat food or liquids... played with the power level a bit and it started to heat again...then a day or two later we...
Is this oven still under warranty? If so, take advantage. If not, remove the power plug and the case. Short out, with a screwdriver, the large can-shaped capacitor with two terminals sticking out. Check the wiring and circuit board for signs of burning. If everything looks ok, remove the thin sheet metal wave guide that sits above or beside the microwave energy port into the cooking cavity. Under the sheet metal, there is a metal fan-like device called a 'stirrer' that has a plastic bearing. Remove this stirrer and smell the bearing. If it smells like the burning wire smell, replace the stirrer. You can buy it through 'Sears Parts' online.
Sep 14, 2009 | Microwave Ovens
Greetings, Just bought a Kenmore toaster. and this thing stinks to high heaven of chemicals. So I plugged it in and ran it through a cycle and the burnt plastic/chemical Oder was/is enough to gag you. The...
Return it and get a different brand of toaster. That will solve the problem. Hopefully they will let you give a reason why, and someone will care (probably not).
If you do not want to do this, you can plug it in outside and run it through several cycles. This will probably burn out anything that is causing the smell.
Make sure that they didn't have anything packed in the crumb tray.
Apr 21, 2009 | Kitchen Appliances - Others
Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Mar 11, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Odor from toaster
ozone smells like fresh sweet air ( same smell as after a lightning strike )
what you probably have is the smell of melting plastic from wires in the toaster
Apr 06, 2017 | Kenmore KTES4 4-Slice Toaster
Dryer smelled of burning plastic, smoked stopped turning on
check the power cord itself, if you see on the back side of the cord a burnt or blackened spot then the cord is the issue
Apr 12, 2008 | Dryers
Toastmaster TP409 4-Slice Toaster Logo
425 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Henry  Thomas
Henry Thomas
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
