Question about Aquabot Robotic Pool Cleaner
Having problems with my dolphin diagnostic explorer robotic pool
When i put the unit in the pool it shuts off within 30 seconds, what should i do?
    President:
  • Aquabot Master
  • 1,378 Answers
Your motor unit was covered for up to 3 year under warranty. Confirm your warranty status at http://www.maytronicsus.com/en-US/home/homepage/ and perhaps the repairs are still covered.
Posted on Jun 12, 2009
Goes to wall and turns itself over. It is clean.
Maytronics-Dolphin pool cleaner, Dolphin Diagnostic ...
? 3:44
www.youtube.com/watch?v=-x8hwghv8BE
Apr 4, 2012 - Uploaded by Swimming Pool Tips, Reviews & How To -MrDgvb1 Maytronics-Dolphin pool cleaner, Dolphin Diagnostic ... Solar Breeze: The Robotic Solar-Powered Pool Cleaner Review: http://youtu.be/jzWfClbOnIc ... Pentair Kreepy Krauly Legend Review, Troubleshooting & Tips:
Aug 08, 2015 | Dolphin Maytronics Diagnostic Robot...
Tip
Your Dolphin pool cleaner wont start up...
A common problem, especially with 'newer' Maytronics Dolphin brand pool cleaners is that you put the unit in the pool, or even try to turn it on after a cleaning cycle while it is still in the pool, and to that point it has worked fine. You turn the power supply on and nothing happens. You turn it off and back on and still nothing. You leave it, even over night, same thing. What do you do?
While I cannot tell you why it does this (we have a theory but can not confirm it) what usually works is to follow these steps...
1) Unplug everything. Unplug the power supply from the outlet and the Dolphin from the power supply.
2) Let the whole thing sit a couple of minutes (we want to allow any capacitors to discharge).
3) Be sure the Dolphin is out of the water and sitting upside-down on a level surface (Tracks pointing skyward).
4) Reconnect the Dolphin to the power supply and the power supply to the outlet.
5) With the Dolphin still out of the water, perform a self-test. Simply turn on the Dolphin. Within about 15 seconds it should begin to move. The tracks will spin in both directions with and without the impeller motor running at the same time. It is not unusual for the tracks to rotate at different speeds during this test. The test will last for 30 - 45 seconds or so. If it goes on indefinitely, turn it off and contact us for further direction.
6) Assuming the unit has now worked to this point, you should be able to put it back in the water and it will return to normal operation from this point on.
If it still won't run; it runs a few moments and quits the self-test; or runs continuously, contact us thru the Dolphin service form along the bottom of our home page at www.arrowpools.net.
on Dec 16, 2009 | Dolphin Maytronics Diagnostic Robot...
Turn unit on,light stays on for 5 seconds and shuts off,robot doesnt move
If the power supply switch is popping off after a couple of seconds the most likely cause is a failing rectifier. You may want to ship it to a service center to confirm that is the issue and that the switch, which is also the circuit breaker, and the PCB inside are OK. For help finding a service center contact Matronics directly at www.maytronicsus.com or 1-888-DOLPHIN.
John
Jul 23, 2011 | Dolphin Maytronics Diagnostic Robot...
The light goes on and nothing happens. no sound at all. it was working fine two days ago. thanks
Try a self test...flip the unit upside down on your deck and plug everything in a turn it on. Within 15 seconds it should start moving the tracks and the progress thru several track direction changes with and without the impeller motor turning on. After 30-45 seconds of these motions it will shut off and at that point I would put it back in the water and it should work.
If it will not perform the self test or will not operate after the self test it needs service.
For a list of service centers or further troubleshooting assistance please contact Maytronics directly at www.maytronicsus.com or 888-DOLPHIN.
John
May 19, 2011 | Dolphin Maytronics Diagnostic Robot...
Stops running after about 2 minutes
Question the manufacture about a new circuit board.
The Pool Tech
Jul 10, 2010 | Dolphin Maytronics Diagnostic Robot...
Robot not climbing walls, is vinyl pool too slippery?
Yes...a set of climbing rings will probably need to be installed. To have it done under 'warranty' for a newly purchased unit contact Maytronics directly or use our dolphin serice button found at www.arrowpools.net.
May 29, 2010 | Smart Pool Inc Dolphin Diagnostic...
The unit (6 years old) stops after a 30 sec. After rearming I can start again, and again, and again. Because the unit is no longer under guaranty, I disconnected the motor unit. By testing it (beside the...
Running it next to the pool is not very telling as it will shut itself off in that time anyway. Do you have access to another power supply to try with it? It is possible, though unlikely, it is the problem. It is more likely the motor pack and a new one is costly. If you would like parts or a quote on a motor replacement, use the dolphin contact portion of our website at www.arrowpools.net.
Sep 01, 2009 | Dolphin Maytronics Diagnostic Robot...
Stopped working
Try a self test...Flip the unit upside down on the ground, tracks 'up towards the sky' and trun it on. It should run for about 30 seconds during which it will cycle through various track and impeller motions.
If it completes the test, try it in the water again.
If not, contact us at www.arrowmotor.net for service arrangements or parts. You can also try Maytronics direct at www.maytronicsus.com.
Jun 01, 2009 | Dolphin Maytronics Diagnostic Robot...
Transformer turns on but robot in water don't turn on no movemen t or water flow
I had same problem unplug unit wait for 30 seconds and try it again I had to do this 3 times this a.m. I am having problems with it only going 2 or 3 feet.
May 25, 2009 | Smartpool Dolphin Robo - Kleen Above...
Aquabot Robotic Pool Cleaner Logo
195 people viewed this question
Top Aquabot Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you an Aquabot Pool and Spa Expert? Answer questions, earn points and help others
