Question about SanDisk Sansa Clip MP3 Player
Won't stay on for me to delete songs
When I turn it on it says not enough space for music DB. Please free 30 MB. It will shut off right after that so I can't go in to delete anything.
  • 8,596 Answers
It needs to be reformatted, which I would suggest doing from the Menu itself- directions are in the user's manual: If that type of format fails:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Mar 08, 2009
MP3Player will not stay on
You have used up all your memory, OR you have a faulty SD card. Try reinserting the SD . Also verify how much memory you have.
Mar 06, 2014 | SanDisk Sansa Clip MP3 Player
How do I delete 30mbs from my sansa clip the message is: not enough space for music DB. Please free 30mbs
The player needs free memory to build its database for playlists to playback.
To free memory on your player:
1. Connect to a computer
2. Save a backup of (preferred all) songs to a location on the computer
3. Delete some files off the player to free at least 30 MB memory in the Sansa Clip
Use the manual for how to connect and delete music files.
Clip manual:
http://mp3support.sandisk.com/sansa/UserManual/CLIP/CLIP_UM_English.pdf
Need more help ? Just add a comment in this thread.
May 21, 2010 | SanDisk Sansa Clip MP3 Player
My Sansa Clip won't work. When I turn it on it says: Not enough space for music DB Please free 30 MB. But when i connect it to my computer it doesn't register. PLEASE HELP ME
Because you drag 7 drop songs or files too much into the sansa clip in MSC mode, it causes like that.
Turn it on, it will show " Not enough.....free 30 MB", and then automatically turn off. Plug it into pc, open my computer, it will be under name "Sansa clip..." or "removable disk ". If your pc does not recognize it, unplug again and replug it.
Open Sansa Clip..., or removable disk, and delete some songs.
Good luck
Apr 30, 2010 | SanDisk Sansa Clip MP3 Player
Problem with My SanDisk Sansa m230
try formatting your device then try to put mp3 files on it. check if it works. on your my computer right click you mp3 device ( it is usually a removable storage) then select format.
Feb 21, 2008 | SanDisk Sansa m230 MP3 Player
Sansa m230
The Music DB refers to the Music Database, or the Artist, Album, and Song info.
The error means your device is too full. It needs some free space on the device to create this information.
Connect your device to the PC and manually delete some files from it in My Computer>Device Name (m240)>MUSIC Folder.
It needs 6MB of free space, so you may need to delete several songs.
Disconnect the device from the PC, it should restart and you should be ok. If the message continues, keep deleting files until its gone,
Best of Luck.
Nov 15, 2007 | SanDisk Sansa m240 MP3 Player
Everything is wiped out and so is the radio! Please help !!
The Music DB refers to the information (i.e. - Artist, Album, etc.).
The device need you to free up 6MB so it can create this.
Connect the device to the PC and delete several songs until you have at least 6MB free.
Disconnect it, restart, and youre all set.
Best of Luck.
Nov 03, 2007 | SanDisk Sansa m230 MP3 Player
Error message: Not enough space for music DB. Please free 4MB.
Hi I have just bought a Sandisk Sansa M250, we loaded som music on it and it lasted 2 hours, then it the message came "Not enough space for music DB please free 8 MB". I couldnt even go in to the menu. I contakted Sandisk.com and 24 hours after they came up with an answer. If it's currently frozen, hold down the power button for 20 seconds in order to soft reset it. Let's try to format the player (THIS WILL ERASE ALL FILES FROM THE PLAYER). Plug it into your computer, then open My Computer, right-click the drive associated with the player, and choose Format. It may give you a choice of file system, if so, choose FAT (it may only let you choose FAT32, which is fine). Now click on Start and it should format the player. If not already done, please also update the firmware from this link: http://www.sandisk.com/Retail/Default.aspx?CatID=1368 The 20 seconds on the power button didnt work, but the formation did. Hope this helps. //Cadmann Please bear with my english
Aug 20, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
66 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
