I have a Mitsubishi C21T7L that is attached to our Nintendo Wii. We have to press "tv/av" button on the remote control to access the channel which shows the Wii. The remote is not working, basically falling to bits, with broken buttons etc. Can I access this channel any other way or do I have to get a new remote? Is there any universal remote that has this button? Thanks!
SOURCE: Can't access AV Channel on Sony KV-C27TD
If the TV has no RCA inputs, then there is no "AV channel" option for it on any remote, just channel selection.
The purpose of a RCA to SCART converter (aka RF modulator) is to convert one of your channels to an A/V input. They operate (standard) on either channel 3 or 4 as selected by a switch on the converter.
If your converter is unpowered, it's entirely possible that the signal coming out is not good enough to overpower your antenna signal. In this case, you may need a powered unit (such as this one http://www.bestbuy.com/site/olspage.jsp?skuId=5806345&productCategoryId=abcat0107025&type=product&tab=7&id=1067388827858#productdetail) which can actively "shut off" the antenna input when signal is received from the auxiliary device.
SOURCE: how to access AV channel on Toshiba TV model 2125RA
some sets auto-go av when you plug a rca jackin the set, others have a switch in front or back , others you might set your channel to 00 or 99 or 100 forget and work different , I the owners manual of course would tell you. but I assume u dont have it . try hooking it and letting the dvd run now find it using the remote.
good luck.
SOURCE: problem with channel changing
You must program the tv. Go into the MENU and find AUTO PROGRAM. Then program it and it should work.
SOURCE: My Sanyo TV remote AV button has failed. Is
Why would I tell you how I fixed my problem if I have to pay you to tell me.
SOURCE: My remote for my Orion
Hello
You just buy one [CISCO-6400 ] Universal remote control to which your Orion TV is listed in its codes, and have all the buttons you need. Just go for it. It is a good one I thinks. Codes for Orion are:- 1023_1033_1107.
Keep trace with its manual to alaigh the remote to your TV.
OK.
