Question about Panasonic NV-HS1000 S-VHS VCR
NV-HS 1000 turns itself off almost immediately
There is at tape loaded. It can't be ejected or played.
The machine goes into standby mode almost immediately.
Grubhead
  • 4593 Answers
SOURCE: How to time loading arm cogs on VCR?
Most Panasonic VCR use a mechanisms with a letter. For example the NV-HS900 uses a K Deck. What you need to do is type the model number into google and search for which deck it uses. Then with luck you might also find the instructions for setting the deck up correctly. I got the K-Deck one free.
Posted on Jan 28, 2009
  • 52 Answers
SOURCE: Panasonic 7350 VCR Keep ejecting tapes just seconds after loading
This happens when he strings are worn out or broken. It will not hurt to replace the strings of the VCR after some while.
Posted on Feb 09, 2009
Grubhead
  • 4593 Answers
SOURCE: Panasonic NV HD620 Error F06
You appear to have a model that uses the K Deck Chassis.
F06 in that case stands for: "Mechanism locks after unload". The cause being either the loading motor or the carriage alignment.
Posted on Jun 21, 2009
Grubhead
  • 4593 Answers
SOURCE: Panasonic VCR NV-HD642 - F04 Error
You sound like you have a K Deck Model. If this is the case F04 means that the mechanism locks during unloading.
The apparent cause of this is the Load Motor timing.
Posted on Aug 17, 2009
Grubhead
  • 4593 Answers
SOURCE: panasonic NV-SD236B VCR Error code
You appear to have a model that uses the K-Deck Chassis. If you enter "Panasonic K-Deck Chassis" into google you will find loads of service information on it.
However back to your problem F06 means the mechanism is locking up after unloading. The cause of which could be either the Load Motor or a problem with the Carriage (where the tape goes) and it's alignment.
Posted on May 28, 2010
mybradley7
  • 242 Answers
SOURCE: tape keeps ejecting
clean all moving parts.
Posted on Jul 15, 2010
I've a Mitsubishi HS-U770 that has not been used for several years. When I tried to use it today, the tape loaded but would not play, rewind, or fast forward (I hear what sounds like gears slipping). The...
Mine did that, and when I opened it I found that a small drive belt (visible from the bottom with the cover removed) had deteriorated into goo. This unit had been in storage a while and the rubber just deteriorated, I guess. The trouble is that now I cant tell what size it is, or what length. I think this belt drives the mechanism that loads the tape in and out, and the rest of the mechanism is triggered by the tape cassette moving into position. Since it cant get loaded properly, the rest of the machine doesnt work right, either.
Jan 17, 2011 | Mitsubishi HS-U770 S-VHS VCR
A video tape has become stuck in my Mitsubishi VCR
Hi, Suggest call a local tv repair shop. Thanks.
Sep 22, 2009 | VCRs
Vcr will not play tapes,it ejects the tape after a few seconds
This may be caused by the mode switch.
By the way it uses a K-Deck Mechanism.
Sep 11, 2009 | VCRs
Aug 08, 2009 | Panasonic VCRs
Tape would not come out.
Not sure on the removal, but if you replace the mode switch the machine might come back to life.
Jul 31, 2009 | Panasonic PV-7400 VHS VCR
Transport erratic - machine cuts out on PLAY/REW/REC
A machine reset (unplugging- (x1 wk)) temporarily seemed to fix; some probls returned after 24 hrs.
Technician series text suggest probl may be Tape Load reel (gears, worn belts), tape slack sensor,
mode switch, etc. In other words, machine needs overhaul due to lack of maintenance. [ But where to get necess parts???!! ]
Audio & picture still perform well. Suspect snow dropouts due to tape age (at least late 1980s) & oxides.
/K_M
Nov 18, 2008 | GE VG4267 VHS VCR
Panasonic NV-HS1000 VCR problem
Before you try anything too elaborate, change all of the belts. There are a number of safety features built into this unit to prevent the tape from getting damaged. If one of the reel tables is not turning when it should, the unit will shutdown. There are a number of similar checks made continuously as the machine runs. If you have no experience with these units, bing it in for service. The parts should not be more than $5-$25 total. Add in the local labor charge for the total repair bill. Basically this unit should be cleaned and the alignment checked after the belts have been changed.
Dan
May 23, 2008 | Panasonic NV-HS1000 S-VHS VCR
VCR eats tape when rewinding
A couple of possibilities: 1. Braking problems: When VCR goes from FFWD, REW, Play to stop, there are a pair of "brake pads" engaged to stop the reels, and prevent tape spillage out into the machine. These pads, often rubber like, are on levers which contact one side of each reel. If you take the cover off the VCR, and look down where the tape is loaded, you will like see these brake assemblies. If the rubber pad is missing, or lever pivot points gummied up, then this is your issue. 2. Take up reel isn't being engaged to take up the tape on tape eject. When a tape is loaded into the machine, tape is pulled from the cartridge and threaded into play ready position. When eject mode is engaged, the tape must be pulled back into the cartridge, or you will have tape hanging out the front end of the cartridge, and may get caught on the VCR internals, or at least be mangled by the cartridge door. The often issue here is likely the idler assembly pivot point is sticky. This idler pivots, moving from the take-up reel (right reel) to the supply reel reel (left one), depending on what mode is selected. FFWD & play to the right, left for REW. If this idler is gummed up at it's pivot point, movement will be sluggish at best, and might not be engaging the right reel quickly enough to pull tape in before tape eject. This idler is sitting right between the reels down where the tape sits. A little light oil on the pivot point may be enough to loosen it up. Otherwise it might need to be removed and the old grease removed, and a drop or two of light oil applied.
Jul 09, 2007 | Mitsubishi HS-U781 S-VHS VCR
Tape Ejects Immediately
There are normally 2 causes. One is some obstruction in the tape path. Please open the cover of the VCR and shake and see for foriegn objects. Nothing??? Then there is one more possibility - Belts are loose.. Check the Tape Loading motor belt.Is it slack? This can happen over time.Change the belt.
Feb 04, 2007 | Panasonic NV-HD680 VCR
Flashing '2' or '1' or '4' when I try and play a tape
The idler on your machine needs to be changed and also the drum head of your machine needs to be clean.tape head cleaners can be bought from any electronic shop.the idler must be changed by qualified techn
Jan 22, 2007 | Philips VR540 VHS VCR
Panasonic NV-HS1000 S-VHS VCR Logo
116 people viewed this question
Top Panasonic VCRs Experts
Pieter Vleeshouwers
Are you a Panasonic VCR Expert? Answer questions, earn points and help others
