Question about Coleman Powermate DuraBuilt 1400 PSI Pressure Washer
WATER LEAKS FROM INSIDE THE 1400 PRESSURE WASHER
READY TO GO AND THE FIRST TIME YOU GO TO USE THE 1400 PRESSURE WASHER WATER JUST FLOWS FROM INSIDE THE HANDLE?
Replacing Compasster, where on the terminal block does the black and white wires go?
Posted on Apr 24, 2009
Kenmore washer Top Loading HE Low-water washer 02/28102 4.5o purchased 10/10/14 Does not drain when it gets to the 13 min mark. LF error comes up.
stands for long fill and occurs when the water level does not change for a period of time after the valves are turned on.
All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems:
Slow Fill- low water pressure reduces the speed at which water flows into the machine.
Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine is not supposed to be filling.
Contact the water company to verify the pressure being supplied to the house.
dispenser- Needs a minimum amount of pressure to function. May dispense constantly, at the wrong time, or not at all.
A plumber may need to be consulted if the pressure is found to be too low.
Things you can check
Are the Hot and Cold water faucets turned on
Are the water hoses kinked
Make sure all the hose are straight and able to flow water
Are the screen inside the water valve plugged
Inlet valve should be free of debris and rust.
Turn off water and remove the inlet hoses from washer.
Remove any accumulated film or particles.
Assure rubber washers are in the end of each inlet hose.
Reinstall hoses, turn on water and check for leaks.
Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.
Unplug or turn the circuit breaker off for 30 seconds.
Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
Press the Pause/Cancel/Stop button twice to clear the display.
Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts by Manage My Life September 2nd, 2009
Jul 24, 2017 | Kenmore Washing Machines
No pressure...new pump
Gun could be the problem if you hear the engine pick up speed and you can feel the pressure on the hose.if engine speed doesn't increase than there is a governor issue with the engine.
Oct 03, 2014 | Karcher G 2600 VH 2,600 PSI Gas Pressure...
Their is no water pressure .
Try looking for any pressure leaks or blockages within the unit. if this fails, the motor may be at fault, carefully open the unit and check that the pump motor's blades are in good order, if all of these fail, then it's ready to be recycled and replaced.
Nov 29, 2011 | Karcher K3.68MR Electric Pressure Washer
The washer is flashing display LF
LF Error code: LF stands for long fill and occurs when the water level does not change for a period of time after the valves are turned on.
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine is not supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house.
* dispenser- Needs a minimum amount of pressure to function. May dispense constantly, at the wrong time, or not at all.
o A plumber may need to be consulted if the pressure is found to be too low.
Things you can check :
* Are the Hot and Cold water faucets turned on
* Are the water hoses kinked
o Make sure all the hose are straight and able to flow water
* Are the screen inside the water valve plugged
o Inlet valve should be free of debris and rust.
o Turn off water and remove the inlet hoses from washer.
o Remove any accumulated film or particles.
o Assure rubber washers are in the end of each inlet hose.
o Reinstall hoses, turn on water and check for leaks.
1. Unplug or turn the circuit breaker off for 30 seconds.
2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
3. Press the Pause/Cancel/Stop button twice to clear the display.
4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts
Thanks for using FixYa
Jan 29, 2011 | Washing Machines
The washer as a code LF what can I do to fix it or do I need a repair man to come?
Thanks for using FixYa!!
Jan 29, 2011 | Kenmore Elite 45986 Front Load Washer
The washer will start a load of laundry then about 1/2 way through the cycle shuts off and LF show where the time is shown for the load to be finished, this does not matter what size or type of load is...
Please rate my solution if it was at all helpful.
Thanks, Repairman45.
Dec 17, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Display LF and the washer is not filling with water, I really hope this doesn't mean the Line is Frozen....
Dec 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite top loader washer has LF error message
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 19, 2009 | Kenmore Elite 45986 Front Load Washer
WASHER STOPS AND SAYS LF
Apr 30, 2009 | Washing Machines
Coleman Powermate DuraBuilt 1400 PSI Pressure Washer Logo
487 people viewed this question
Top Coleman Garden Experts
John Trevino
Simon Flummox
Simon Flummox
Are you a Coleman Garden Expert? Answer questions, earn points and help others
