Question about Philips GoGear SA5285/37 Digital Media Player
Go gear will not operate in recording mode
My go gear sa52 will not record voice or from the radio without crashing and is usless to me as this was the main reason i purchaced it. can anyone come up with a solution...
  • 8,596 Answers
The Go Gear SA52XX series is only capable of recording FM in Europe - the US versions, even though they have the same manual, will not allow FM Recording. I haven't heard that won't do voice recordings, but it doesn't surprise me - update the firmware - the directions are on Philips website. If it still won't record voice recordings, get a different mp3 player, because this is not the one.
The Philips SA6045, SA5125, and a few others will do FM and voice recordings. Ironically, the newer Philips GoGear's will not.
-Tha Mp3 Doctor
Posted on Mar 18, 2009
How do I turn it on
There is two red lights, one means you are recording and the other is low batt. which one you are talking about?
If it is Low batt light,there is dirty or bad contacts at battery compartemt. clean it with alcohol and a piece of cotton.
The other light is you are recording.
also you are in VOX mode, disconect.
VOX means voice operated without hands.
Sep 22, 2014 | RCA RP5010 Digital Voice Recorder
I did not convert my files into the wav format and my hard drive crashed. Was able to get an expert to recover data, but we cannot find the files for the 43-127 telephone recorder. Does anyone know the...
The RadioShack 43-127 Digital Voice Recorder records in .wav format.. You don't have to convert anything. It records, saves, and transfers what it records as .wav files.
RadioShack Digital Voice Recorder 43 127 Records Telephone Conversations
Unfortunately, when hard drives crash, data stored on them is often lost due to corruption to the magnetic surface of the discs themselves, or to actual physical damage. If no .wav files are able to be seen, they may have simply been lost.
If those files still exist and are able to be retrieved from the disc surface, they will be in the same location within the directory structure that you originally saved them to.
Sep 20, 2017 | Radio Shack TRC300 Voice Recorder
My Olympus digital voice recorder DS-30 recorder says memory full - but I only have about 4 or 5 hours of recording on it. help!
Check your operators manual....amount of recording time is dependent on "quality" mode of recoring.
If you have lost your manual go to
Oct 10, 2010 | Olympus DS-30 Digital Voice Recorder
After transferring recording to computer the voice recorder remained in the pc mode and i have been unable to get it to return t the recording mode the recorder is too good to throw away please help...
If you have tried removing and re-installing batteries and that didnt work you maybe should try reformatting...this will erase all files on handheld tho'...instructions for reformatting are in your operators manual or you can download a manual from
Aug 26, 2010 | Olympus VN-3100PC Digital Voice Recorder
Olympus Voice Recorder says only 6 hours time when it's empty
The recorder should be formatted only by using the internal FORMAT function found in the Menu. Formatting using the computer may corrupt system files needed to run the recorder and may delete the Voice Guide Data and Audible system files, so computer formatting is not recommended. When the recorder is connected to a computer, individual files can be deleted using My Computer without negative effects.after you format the unit this is how needs t
be depends on your selection for Audio quality
STEREO XQ mode: 17 hours 30 minutes
STEREO HQ mode: 35 hours 10 minutes
HQ mode: 70 hours 20 minutes
SP mode: 138 hours 30 minutes
LP mode: 275 hours 20 minutes
if this don't solved your problem you can get one really cheap at just like a back up
Feb 10, 2010 | Olympus DS-50 Digital Voice Recorder
How do you get the voice recorder to work on the go gear vibe? Do I need a little microphone to record messages?
From the manual...
This is how you can record audio/voices with the built-in microphone (see section Overview for location of built-in microphone):
1 From the main menu, select to enter recordings mode.
2 Select [Start voice recording].
• Press to toggle between pause and record.
3 Press to stop.
»» The screen prompts you to save the recording.
4 Press / to select [Yes] / [No].
5 Press to save the recording.
»» Recordings are saved on the player.
(Filename format: VOICEXXX.MP3, where XXX is the recording number that is generated automatically.)
•• You can find your recordings under [Recordings library] > [Voice].
Jan 12, 2010 | Philips Audio Players & Recorders
Sony icd-b7 digital voice recorder
It will turn OFF automatically after some time if non of buttons touched. (goes to standby mode)
It does not have any specific power off button.
Sep 18, 2009 | Sony ICD-B7 Digital Voice Recorder
Limited recording time
WS-100: 64 MB
HQ mode: Approx. 4 hours 20 minutes
SP mode: Approx. 8 hours 40 minutes
LP mode: Approx. 27 hours 20 minutes
You can go to the menu of the device and change the recording mode from HQ to SP to get longer recording time. Page 7 of the instructions explains how to change this.
Mar 19, 2009 | Olympus WS-100 Digital Voice Recorder
All the buttons on the device do not work in the "recording mode"
only possible solution would be to format the recorder to see if anything changes... make sure to download files before formatting the recorder. format is found in the menu
Jan 20, 2009 | Olympus DM-20 Digital Voice Recorder
I need 2 know how 2 uninstall info from my mp-4001 moV.ox centon
Do this procedure for "voice" mode to delete voice recordings:
Delete file (stop submenu) - Delete corresponding files and save files in Music mode, Voice mode or FM mode.
1. In stop interface (FM without stop interface)
2. Short press "MODE" to enter stop submenu
3. Click "NEXT" or "PREV" to choose "single" or "all" files
4. Short press "MODE" to enter the Delete interface
5. Click "NEXT" to change "no" into "yes"
6. Short press MODE to confirm the delete prompt
"Delete all" will delete all related files stored in the selected folder. For example, if in music mode "Delete all" will delete all the music files, while other recorded files (e.g. voice recordings or FM recordings) will not be deleted.
Likewise, if "Delete all" is used when in the "Replay" menu, this will delete all recorded files but leave music files intact.
FM is much simpler – "Delete" or "Delete all" will delete the station(s) saved before.
-Tha Mp3 Doctor
Jan 08, 2008 | Centon Electronics MP4-001 MP3 Player
Philips GoGear SA5285/37  Digital Media Player Logo
136 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
