Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Water not draining from the machine
My Bosch Classixx dishwasher is less than two years old and half way through the cycle the"Check water" button lights up and the water has failed to drain from the bottom of the machine. Been through it trying to clear what I thought was a blockage but I don't think it is. Feel it may be a faulty pump - heart sinks as that's what was wrong with the last dishwasher (also Bosch) and then the repairman said it wasn't worth replacing. Any tips?
  • fgd_macdonal Mar 09, 2009
    Ah, sadly not...thank you for the tip which I'll pass on to anyone who has the drain button!!
  • fgd_macdonal Apr 04, 2009
    Thank you JSF1...I shall remember this for next time. In the end I did get someone in to have a look at it and it was exactly that, a small piece of glass. Watched him like a hawk as he removed it and I think I could have a go myself if it happens again. Appreciate your posting.
If it IS the pump, it’s often because some relatively minor item (piece of cocktail stick/bit of nutshell/etc) has found its way past the filters and is blocking the blades of the pump. It is relatively simple to remove the inlet hose to the pump and clear the blockage (a pair of grips to pinch and remove the retaining clip, then the hose will slide off the fitting on the pump). I did this several times on my previous (Hotpoint) machine – and suspect it is no harder on the Bosch (which I now have). If that doesn’t work, you are half-way to replacing the pump, which is not a difficult DIY job and I’m surprised any competent professional repair man wanted to write off a machine where the pump had failed. A new pump should cost around £40-£50 – less than a quarter of the cost of a new machine. DIY fitting would maybe take a couple of hours; a pro ought to do it in less than an hour.
Posted on Apr 02, 2009
We had that happen on our Kitchenaid dishwasher. The way we solved it is that we pushed the cancel/drain button on the front of the machine. Hopefully yours has a cancel/drain button.
Posted on Mar 08, 2009
How do I resolve f17 error message on bosch classixx 7
F17 is a time out fault on drain pump. Check all water hoses and drain pump for either blockage or restriction. Failing that, check your waste pipe is clear.
May 29, 2014 | Bosch 24 in. SGS43C12 Classixx...
My Bosch Classixx (about 10 years old) dishwasher won't fill The problem has only started since I pulled it out and cleaned! The programme sounds are as normal but no water enters the machine. I detected...
Check you dont have a small inline filter inside the inlet water pipe. Either at the "tap" end or can be on the machine itself. They look like a small sieve. Remove it and clean with a toothbrush. Then put back.
Apr 05, 2017 | Bosch SHU9915UC Dishwasher
Bosch washing machine does not do the complete cycle
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 05, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx Dishwasher -check water light keeps coming on
thanks i empied my dish wisher old water then it word again thanks Neil Spink
Apr 14, 2010 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher signals "clean" inside five minutes
I would check tosee if your water meaning hot water temp is hook up correctly. i have seen cold water going to machine and causing the machine to do funny things. 1 the unit drains.2. it fills.3.it washes if the water is cold there is your problem .make sure b4 you start machine the water going in is hot. let me know how you made out maybe we can further check. p.s im a old bosch tech:)
Jan 26, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
I have a bosch dishwasher classixx its less than a year old, the 'check water' light comes on and it doesn't complete the cycle. Water is left in the bottom unable to drain away. I have checked pipes as...
if its less than a year old why dont you contact the manufacturers service team it will still be under guarantee as the bosch guarantee is 24 months
you can dowload a copy of the instruction maual free of charge from the bosch or bsh home appliances web site
Feb 21, 2009 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Water leaking from dishwasher
check the hose in the back to see if it split could be dry rotted
Jan 09, 2009 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx check water light
ok sounds like a drain promblem love your do it your selfness but one thing you must keep in mind its under warrenty and if you mess with it you could void your warrenty if you have a cancel drain option try that if it still doesnt drain call for service
Mar 18, 2008 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Feb 23, 2008 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Mar 17, 2007 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
815 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
prem mathew
bosch5
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
