Question about Canon PowerShot A420 Digital Camera
Light appears, but no image
Whenever I power on my A-420 camera, light appears on display screen, but no image!! If I took photo also, it appears to be a dark screen- I mean, nothing is photographed. Reviewed through all settings, nut no use. Can anyone solve my problem?
  • Anonymous Mar 29, 2009
    my camera can shoot pictures but the pcitures are too bright and sometimes are all white but when taking movies pcitures are ok
Just change the setting to outdoor. if you read your manual it will explain how. pg 27
Posted on Apr 26, 2009
Focus circle clear but surrounding area appears hazy
This is often the result of little available light on the focus screen. The more ambient light (and more open the aperture is) the brighter and sharper the image is in the viewfinder. Less light effects the image in the view finder and makes it harder to see and focus.
If your lens only opens to f3.5 or 4.0 and you\'re trying to shoot indoors with available light - your lens may not let enough light into the camera to see the scene as well as you can with the naked eye. An f1.4 aperture lets eight (8!) times as much light as an f4.0 does and is why they\'re so expensive.
Try the same setup in a brightly lit (sunny day) scene to see if it goes away.
Apr 06, 2014 | Nikon FG 35mm SLR Camera
The images apprear purple on the screen, and dark in patches. New photo's taken, come out purple. But existing photo's appear on the screen as, normal.
If the previously captured images are appearing fine in the Camera, then the issue is with the CCD Image Sensor unit only. Check if the display icons are appearing normally on the Camera screen.
Try power resetting and Factory resetting the Camera to check if the issue can be resolved:
Power reset:
Remove the batteries from the Camera.
Press and hold the POWER BUTTON of the Camera for 15 seconds.
Then, reinsert the batteries after 1 minute.
Factory reset;
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.
Home-->Settings-->Main Settings 1-->Initialize-->OK
Aug 06, 2010 | Sony Cyber-shot DSC-T100 Digital Camera
Can't get date/time to not appear on screen or download to comp
Are you sure your canon battery pack is OK?If not ,replace it with a high quality replacement battery pack.
Jul 25, 2010 | Canon PowerShot SD1100 IS Digital Camera
To much light exposure when taking photos
Go to menu and try to setup the factory settings it may be a setting that is doing that.
Hope it helps
Jun 25, 2009 | Olympus Camedia C-770 Digital Camera
Light displays on screen but no image
Can you see images taken earlier from memory in view mode ?
Can you access the menu and see it displayed on the screen ?
If yes to both, then your CCD sensor most likely is defekt.
No DIY recommended.
Mar 08, 2009 | Canon PowerShot A420 Digital Camera
Lines accross the screen when taking photos near electric light
Probably the refresh frequency of the lights conflicting with the shutter speed in use - try raising the ISO for a faster shutter speed
Aug 05, 2017 | Nikon Coolpix S510 Digital Camera
The image is getting blurred
Hi
The camera may have moved when the picture was taken. Try steadily squeezing the button intead of a quick press.
2.Try using a tripod, this could fix the blurred images.
3. faster shutter speed will be needed if you need to hold the camera, and cannot use a tripod.
4. Main reason for the lines could be that the subject is to bright.
A vertical bar of light(red, purple) appears on the LCD monitor/ in the viewfinder This is a normal occurrence in devices containing CCDs (Digital Cameras) and does not mean a malfunction. (This red bar of light will not be recorded when shooting still photos, but it will be recorded when shooting
movies.)
Solution to the last point would be to try and switch of the flash if it is in use. Turn the ISO setting (50, 100, 200) to a lower one as well.
Hope that helps.
May 26, 2008 | Canon PowerShot Pro1 Digital Camera
Poor image displayed on cscreen after shot taken
I have an s60 and it sounds like I had this exact problem. Whenever I took a photo, the entire picture was covered with white horizontal lines. The actual image files were striped the same way.
I found this on the Canon USA site:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2112&fcategoryid=223&modelid=10149
Because it was a hardware issue, they sent me a shipping label, I sent in the camera, they fixed it, and sent it back. All free of charge.
Good luck; I hope your camera is repairable.
Aug 24, 2006 | Canon PowerShot S60 Digital Camera
Canon PowerShot A420 Digital Camera Logo
99 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
