Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Poor suction after many uses with model DC07 despite emptying out cannister and checking for any blockages
  • Philip Gaut May 11, 2010
    Is the suction poor when using the hand tools, or only at the main brushbar part of the machine?
  • 134 Answers
Change or clean the filters
Posted on Mar 08, 2009
No suction on flexible hose model dc07.i have checked all filters ok. no blockages.plenty of suction on brush side
I have made a video showing the likely causes for this problem. If you need parts for your Dyson DC07 I would check out nelson vacuums or vacuumspot.
If the video is helpful to you please take a moment to write a comment or give it a thumbs up.
Vacuum Guru
Feb 25, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Suction problem? The carpet fiber and pet hair
You've probably got a lesser blockage further down the pipework, which is reducing the airflow. Check everywhere possible for blockages, and also make sure the washable filter is clean and dry.
Feb 05, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I just bought a used Dyson DC07. Works good but
Hi its Darran at Dyson.
From your description of the problem, it sounds as though the wand/hose is blocked. To test this, please remove the wand from the machine and switch on, testing the suction from the top of the wand handle. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its strong from the hose itself, the wand is blocked and you will need to clear this.
If there is poor suction from the hose, you can remove this by unclipping it from the base of the machine and can then remove any blockages. It is also worth checking the hose for any splits or holes.
If you need any further help or advice, please visit our website at www.dyson.com and check out our support section.
Kind regards
Darran
Dyson Customer Service
Jan 30, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 bagless - upright mode v poor suction, wand mode ok
From your description of the problem, it sounds as though the bleed valve is activating which only happens when there is a blockage.
We would recommend following the full blockage through as outlined in your user guide or in the Support section on our website at www.dyson.com.
Kind regards
Darran
Jan 11, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson hose looses suction
You have a blockage in the wand. Stand behind the machine and:
1) Remove the u-bend which is located NEXT to the right-hand side wheel, NOT above it. It connects from the bottom of the long gray hose to next to the right-hand side wheel. It is attached to the machine with a rectangular-shaped clip - push the clip and pull the pipe down.
2) Look through the wand if you can (DC07 wand is bent) - if you can't see the ground you have a blockage in either the hose or the wand
3) Remove the hose and separate it from the wand - hold the wand up into the air and look through it - if you can't see light coming through the other end, there is a blockage in the wand. Use a long object like a stick or a metal hanger to remove the blockage.
4) If the wand is clear, stretch the hose out and look for dark spots - those are the blockages. Again use a long object to remove the blockage - be careful not to damage the hose, you don't want to buy a new one.
Jun 29, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Seems to have poor suction
try this take some duct tape place it where the cannister and the seal meets then vacuum. if that not it you my have a clog.
May 08, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No suction, again.
There is a blockage somewhere and its most probably jammed between the main dust channel between the beater bar and the bottom hose inspection. Remove the sole plate to see if anything is still stuck, check the beater bar as well and see if there is anything obstructing at the main hose removal point.
Mar 12, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Loss of suction
There is a blockage . Check the small hose under the sole plate
Feb 01, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Spitting Out Debris
the hose from brush go to the bag need to check for blockage you have to open there hose to clean
Aug 13, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
231 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
