Question about Canon PowerShot A420 Digital Camera
Light displays on screen but no image
Whenever I power on my A-420 camera, light appears on display screen, but no image!! If I took photo also, it appears to be a dark screen- I mean, nothing is photographed. Reviewed through all settings, nut no use. Can anyone solve my problem?
  • 60 Answers
Can you see images taken earlier from memory in view mode ?
Can you access the menu and see it displayed on the screen ?
If yes to both, then your CCD sensor most likely is defekt.
No DIY recommended.
Posted on Mar 08, 2009
The images apprear purple on the screen, and dark in patches. New photo's taken, come out purple. But existing photo's appear on the screen as, normal.
If the previously captured images are appearing fine in the Camera, then the issue is with the CCD Image Sensor unit only. Check if the display icons are appearing normally on the Camera screen.
Try power resetting and Factory resetting the Camera to check if the issue can be resolved:
Power reset:
Remove the batteries from the Camera.
Press and hold the POWER BUTTON of the Camera for 15 seconds.
Then, reinsert the batteries after 1 minute.
Factory reset;
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.
Home-->Settings-->Main Settings 1-->Initialize-->OK
Aug 06, 2010 | Sony Cyber-shot DSC-T100 Digital Camera
Can't get date/time to not appear on screen or download to comp
Are you sure your canon battery pack is OK?If not ,replace it with a high quality replacement battery pack.
Jul 25, 2010 | Canon PowerShot SD1100 IS Digital Camera
I cant see the person im taking a picture of on the LCD, its black.
This is due to the CCD Image Sensor failure in the Camera.
To confirm the issue, please check if the previously captured images are displaying normally. The previously captured images and icons will get displayed normally if the CCD issue is there in the Camera.
If this happens only with the live view, then try resetting the Camera.
The RESET button is located at the lower right side of the control button. To reset the camera, press the RESET button using a sharp-pointed object.
You may also try power resetting the camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally.
If the issue is not resolved after resetting, service may be required.
Jul 24, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
Light appears, but no image
just change the setting to outdoor. if you read your manual it will explain how. pg 27
Mar 08, 2009 | Canon PowerShot A420 Digital Camera
Lines accross the screen when taking photos near electric light
Probably the refresh frequency of the lights conflicting with the shutter speed in use - try raising the ISO for a faster shutter speed
Aug 05, 2017 | Nikon Coolpix S510 Digital Camera
Problem with display being white...but!
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Mar 13, 2008 | Canon PowerShot A60 Digital Camera
Poor image displayed on cscreen after shot taken
I have an s60 and it sounds like I had this exact problem. Whenever I took a photo, the entire picture was covered with white horizontal lines. The actual image files were striped the same way.
I found this on the Canon USA site:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2112&fcategoryid=223&modelid=10149
Because it was a hardware issue, they sent me a shipping label, I sent in the camera, they fixed it, and sent it back. All free of charge.
Good luck; I hope your camera is repairable.
Aug 24, 2006 | Canon PowerShot S60 Digital Camera
Canon PowerShot A420 Digital Camera Logo
153 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
