Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Cuisinart Grind & Brew DGB-600 does not complete brewing
I have decalcified unit with vinegar as recommended but when I turn the unit on, it acts as if it has completed the cycle but produces less than one cup of coffee. I turn it back on and it does this again; it never completly finishes the full 10 cups
  • Cuisinart Master
  • 19,396 Answers
That means that the vinegar had moved cal and debris and now one of the lines is blocked with cal residual . Perform a full cleaning cycle with water a couple of times.
Posted on Mar 08, 2009
  • Ginko
    Ginko Mar 08, 2009
    After cycling with vinegar you need to run at least on cycle with water.
    If the cal in the machine was excessive, the cal residual may have now clogged the water lines, or the reservoir orifice or the valve.
    Try doing a full cleanup as suggested on manual and run a cleaning cycle with water 4 or 5 times, as described on manual: D G B - 6 0 0
    If still no luck use a descaler product do solve the cal left by the less efficient vinegar solution:
    Urnex Cleancaf home coffee equipment cleaner
    UK: HG Hagesan Quick Descaler Coffee machine
    If all that does not work, then contact cuisingart at the number listed on the owner manual (toll-free at 800-726-0190 in US).
    If you have not done anything wrong, and there is really a problem then cuisinart will cover the repair.
2 Suggested Answers
SOURCE: cuisinart 10 cup auto grind and brew
Here is a link for the PDF version of the Instruction Booklet for the DGB-600BCC (from the name you provided I’m assuming this is the correct product).
If it’s not the right product, check out the Cuisinart.ca website, you can select the product you are looking for and download the instruction booklet from the product page.
http://www.cuisinart.ca/en/pdf/ibs/DGB-600BCC_en.pdf
Hope that helps!
Posted on Oct 17, 2008
Need instructions to operate DGB-600BC
Thanks for the reply. Got rid of the coffee maker. Its a dud. No more information required.
Jun 18, 2009 | Cuisinart Thermal DGB-600 Grinder
Coffee grinder on brew and grind won't work
Make sure the slot between the grind basket and filter basket is clean and free of grounds - then inspect the area near the grinder motor - use the brush that came supplied with the Cuisinart to clean that area out. Once thoroughly cleaned, try one more time to Grind. Let me know if it works.
-Tha Mp3 Doctor
Jan 06, 2009 | Cuisinart Thermal DGB-600 Grinder
NEED oWNERS mANUAL FOR gRIND & bREW SO i CAN SET IT
if you go to this address you can download a manual...
http://safemanuals.com/user-guide-instructions-owner-manual/CUISINART/DGB-300BK-_E
if the address doesn't go just go to safemanuals.com and in drop boxes choose cuisinart/dgb-300bk. will take you to thie page.
enjoy your coffee.
Dec 02, 2008 | Cuisinart Grind and Brew DGB-300BK 10-Cup...
Grind and Brew thermal (model CUI DGB 600BC)coffee filter cup hard to open, now won't close. Cup where beans are added, bean cup difficult to open as well. Need to find repair place near zip code 95127.
That problem is endemic to this grind and brew only - find out if you are still in warranty - try and get a DGB-550BK as a replacement - the 600 is the only one with this problem. Replacing it with the same model will likely lead to the same result.
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
Dec 02, 2008 | Cuisinart DCC-1200 Coffee Maker
I cannot remove the grinder from my cuisinart Grind and Brew Coffeemaker. It still makes great coffee, but I want to clean the grinding mechasim and cannot remove it.
Common with the DGB-600 - you can try icing it down for 10 minutes - once removed, clean exterior with vinegar applied to a rag to get oils off - endemic to this unit - replacing it with exact same model will not help.
Oct 13, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart grind & brew coffeemaker DGB-500C
Could be electrical, but I would unplug for 20 minutes or longer and then clean with vinegar/water soltuion (2 cups vinegar, 2 cups water).
-Tha Mp3 Doctor
Jun 16, 2008 | Cuisinart DGB-500 Coffee Maker
DGB 600 Grind & Brew
Had the same problem, I used coffee pot cleaning solution a couple times through and it woks fine. Had to do this a few times now. Cleaning solution is the type bought at local retail store.
Aug 03, 2007 | Cuisinart Thermal DGB-600 Grinder
Cuisinart grind and brew coffee maker
here is the link to the manual; http://www.cuisinart.com/share/man/34_man.pdf ask again if you still haven't figured it out :)
Mar 15, 2007 | Cuisinart Thermal DGB-600 Grinder
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
109 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
