FixYa.com
Tags:
IBM MEGA RAID I4 IDE RAID
IBM HTTP 2.0 and WebSphere 5.0 - Problem
By Luisa_K - usenet poster
I have a problem on the launch of my IBM HTTP Server 2.0. The server fails
to start because it cannot load a proper module. (Just after the setup of
WAS5). The error is the following:
[Start]
Syntax error on line 819 of D:/IBM HTTP Server 2.0/conf/http.conf:
Cannot load D:/IBM/WebSphere/AppServer/bin/mod_ibm_app_server_http.dll into
server: The specified module could not be found.
[End]
My config file (untouched since the setup of WebSphere 5.0):
[Start httpd.conf]
[l819] LoadModule ibm_app_server_http_module
"D:/IBM/WebSphere/AppServer/bin/mod_ibm_app_server_http.dll"
[l820] WebSpherePluginConfig
"D:/IBM/WebSphere/AppServer/config/cells/plugin-cfg.xml"
[End]
A few informations about the server configuration :
Windows XP SP1 - 392 MB RAM
Sun Java 2 SDK 1.4.1_01
IBM HTTP in: D:\IBM HTTP Server 2.0\
IBM WAS 5 in: D:\IBM\WebSphere\AppServer
Thank you for your help or tips or links,
Godefroy ;-)
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 02, 2007
FixYa! (100)
Ross
Ross - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Appears that your IHS 2.0 webserver is configured to use the 1.3.x plugin.
The Websphere Application Server release notes
contains information on how to configure IHS 2.0 and WebSphere Application
Server. The LoadModule is different between
IHS 1.3.x and IHS 2.0. Snippet of what the IHS httpd.conf should look like:
LoadModule was_ap20_module /full/path/to_module where to_module is
mod_was_ap20_http.dll
Hope this helps.
Al
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Odud
Odud - usenet poster
Rating: 0%, 0 votes
Thank you for that but, I setup IHS 2.0 and nothing appears in the Service
MMC in Windows except the following service :
IBM HTTP Server 2.0.42
Even in http.conf, there's no server configured on port 9090.
And furthermore, nothing in the provided documentation talks about the admin
service it is just mentioned on the web site.
Thanks again,
Godefroy R. ;)
"Chemi" < b5cd9m$
Solution #3
Not Rated (0)
Phoebe
Phoebe - usenet poster
Rating: 0%, 0 votes
IHS has a second service called AdminService.
On Win32 you can start it via Service Control and on Unix via adminctl
start command. Then connect to your URL and port 9090 (by default).
IHs has all the necessary documentation.
Hope this helps,
Chemi.
Solution #4
Not Rated (0)
M0nica L
M0nica L - usenet poster
Rating: 0%, 0 votes
Thank you Al. This was of great help.
On the IBM website (#),
they say that the great advantage of the IBM HTTP Server is to provide an
"Administration Server that helps to administer and configure IHS servers",
I was just wondering where it is (and what it is...) and how I can activate
it eventually. Do you have any advice or information about that ?
Thanks again
Have a nice day :)
Godefroy R. ;-)
"Al Weiner" < b5abvn$
Solution #5
Not Rated (0)
Hart
Hart - usenet poster
Rating: 0%, 0 votes
Infocenter contains the information you are looking for. See
for details.
Al
Solution #6
Not Rated (0)
Chandler
Chandler - usenet poster
Rating: 0%, 0 votes
Thanks a lot Al, the HTTP server is running perfectly now.
By the way, do you know where I can find configuration information about WAS
modules for IHS ?
Thanks again,
Godefroy R. :-)
"Al Weiner" < b4odtd$
Can you Help with these Storage Controllers problems?
Storage Controllers
Why won't my printer turn back...
After refilling the ink jets my... Answer This...
Storage Controllers
usb doesn't work
in the pannel control some usb... Answer This...
Storage Controllers
downloading data/photos
what kind of cd to use? Answer This...
Storage Controllers
Help me to install WinXP in a...
On trying to install WinXP in... Answer This...
Storage Controllers
i don't know
i don't know what sound driver... Answer This...
Repair Service
Find Storage Controller Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
