Question about Electronics - Others
My electrics in my caravan which is an elddis breeze 450clt 1993 will not work without using a leisure battery, This should not happen when using the mains hook up in my house. I have no manual for the zig cp3v which is a control panel in the caravn. I don't know how to fix the problem this is my first caravan.
fridgetech
  • 473 Answers
SOURCE: Oven Control Out - Blown Fuse?
If this is a total gas range then it wouldn't hook up to 240. Check to see if top burners are working. The oven control board only controls the bake/broil. If the bake/broil is the only thing not working and all connections to the board are tight then replace the board.
Posted on Oct 05, 2007
bigbiggs
  • 326 Answers
SOURCE: PROGRAMMABLE ROOM THERMOSTAT
I found this on a search:
"I have the full set of instructions, contact me at gjb@eggconnect.net
Not a very reliable system, transmitter keeps resetting to 17:25; locks up. Whole system then requires setting up from scratch. Had a replacement transmitter, no change, and same faults.
GJB"
Perhaps this can help.
Posted on Mar 16, 2008
SOURCE: fuse panel
need layout of fuse panel for 1994 dodge caravan
Posted on Jan 23, 2009
pierre1811
  • 144 Answers
SOURCE: Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Posted on Jan 29, 2009
jmgldsmth
  • 1906 Answers
SOURCE: Kenmore over the range microwave 721.63684300 - nothing works
you must remove the MW take off the cover then look for a large metal can (capacitor) and a white (ceramic) fuse...look and, smell and, you should find the cause
Posted on Apr 22, 2009
Need the wiring diagram for the aux circuit feeding caravan fridge power while the engine is running.
Understanding Caravan and Tow CarUnderstanding Caravan and Tow CarIn the beginning.... The first and oldest electrical system on caravans, that was installed way back when most caravan's were no more than small garden sheds on wheels were the rear lights that replicated the rear lights of the towing vehicle, usually no more than two side lights and two brake lights.
Illumination for inside the caravan was provided by gas lights fed from a small gas cylinder usually clamped to the "A" frame of the caravan. It wasn't long before the lighting system needed to be upgraded, as direction indicators became mandatory on cars, additional wiring was needed to replicate indicators on the rear of the caravan. Skip forward a few years and a rear fog light became mandatory, so a further upgrade was made to the lighting electrical system to allow the rear fog light to be installed. The wiring for these lights was connected through a 7 pin plug to the car that is commonly known as a "12N" connection.Sometime in between the indicators and rear fog light changes, people decided they wanted to replace the gas lights inside the caravan with 12 volt lights that could be run from the car battery. People often used old car spotlights or other 12 volt lights that were found in cars of the time as interior lights and these soon drained the car battery, so an "upgrade" was to install a second battery in the caravan that could be used to provide power for lighting. These were usually old car batteries. It would be another few years before the dedicated "leisure battery" came along. Originally, you would have to take this battery out of the caravan and charge it at home using a standard car battery charger. Again, in a continual developing process, someone came up with the idea of being able to charge the second battery in the caravan from the tow car while driving along the road, or when on site, being able to run the engine of the car and using a long lead be able to plug the caravan into the car to charge the battery for the next nights use of the lights, So a second "supplemental" electrical system was born and the "12S" (S for supplemental as to differentiate it from the 12N or Normal) connection came into being.he 12 Volt systems
The 12 volt systems are split into two. The first, and as we have seen, the oldest is the caravan road lights, that is to say the lights that are required by law to have on all trailers. These lights consist of "tail" or "rear" lights - rear side lights (red), brake lights (red), direction indicator lights (orange), reversing lights (white) and fog lights (red). Due to the size of a caravan front marker lights (white) are required and from 2013 side marker lights (orange) on longer caravans.
12N & 12S Vehicle Wiring
These lights are connected to the car via a 7 pin "12N" type plug or by a more modern "continental" style 13 pin plug. The road lights are usually a complete system with all the supply and earth connections being separate from any other electrical system on the caravan. One of the most common faults with road lights is problems associated with the earth lead, but more of that later.
The only road lights that are not connected via the 12N connection are the caravan's reversing lights. The original 7 pin socket when it was developed was thought to have enough connections for everything anyone could ever want. Unfortunately as the years progressed, the number of "spare" connection on this plug diminished, to the point where there was no spare connection for the reversing lights. However, with the advent of the 12S, this was taken care of.The second 12 volt system is the supplemental system. This is designed so that when towing, you can charge the caravan's leisure battery, power the fridge and in some cases power an electrical brake system. The design of the supplemental system has to take into account a number of things:-
• It must be able to charge the caravan's leisure battery only when the car battery is fully charged and the engine is running.
• It must be able to power the caravan's fridge - but not allow the fridge to flatten the car battery if the engine is not running.
• It must be able to power the internal 12 volt electrical system of the caravan, but turn everything off when the engine is running.
• It must not interfere with the correct operation of the road lights of the caravan or towing vehicle.
OK, so lets look at the first one -
"It must be able to charge the caravan's leisure battery only when the car battery is fully charged and the engine is running"roblems with this type of connection. If the car battery is flat and you try to start the car, a heavy current will be drawn from the caravan's leisure battery and would cause the caravan wiring to over heat and possibly cause a fire. It would also damage the plug and socket connecting the caravan's wiring to the car, as they are not designed to take the high currents involved in starting a car engine. So how can we do this safely?
Sep 29, 2016 | Cars & Trucks
Can somebody please where the switch is on a elddis caravan to change the water heater heating to gas. ThNkyou
Many do not have electric heating elements, but if yours does, it should only work when plugged into "shore" current. Without that hooked up, unit should try to light and run on propane automatically when you turn on switch. If it does not, igniter may be bad. Time for a trip to camping world pro.
Dec 16, 2014 | Cars & Trucks
Elddis avante caravan manual
Download a later version from Explorer group, most appliances will be the same
Nov 11, 2013 | Cars & Trucks
Hello, im after a manual for a 1992 elddis typhoon gtx, and ideas
go to ebaymotors.com and type in the search box your year, make, and model then service repair manual there should be a repair manual on cd, these are great because they have electrical component locators one the program that show blown up illustations of the complete car and component locatiions
Mar 25, 2010 | 1997 Dodge Caravan
I have a 1993 Fleetwood Colchester english import caravan
We have a 91/92 Colchester 1500 and the hot water runs off the mains link. There is a switch under one of the beds, usually the side that the water bottle is connected. Richard
Mar 16, 2010 | Electronics - Others
Motorhome fridge works on gas but not electric
I thik that whoever advised you of an underlying problem is very muich correct. It sounds like you are getting quite a bad short somewere in your system. I would strongly advise not turning things on as you may fry your entire electrical system. I would also get it checked by a qualified electrician. I hope this is helpful.
Nov 04, 2009 | Refrigerators
Battery showing fully charged- battery charger on but ...
You have a bad connection at main panel, causing voltage drop to system. Check all connections in electrical panel and transfer switch.
Sep 13, 2009 | Electronics - Others
Weird electrical problem in 1996 Dodge Caravan
check the supply feed from the battery where it goes into a terminal block .Should be near the battery
May 30, 2009 | 1993 Dodge Caravan
Electronics - Others Logo
600 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
