We need more information to help you. Read some other solutions that have the same problem and post your symptoms, what you have tried, and what components you have.
You can't post conmments that contain an email address.
This means that your monitor is not receiving a signal from your graphics card.
Here are the things that you can try:
-Disconnect and reconnect your monitor from your computer.
-Try using a different cable to connect your monitor to your computer.
-Try connecting your monitor to another computer, if it works there it means that there's a problem with your graphics card and it may require a replacement. If your monitor is still saying no signal even if it has been connected to another computer that works fine then the problem is with the monitor.
Try to check the monitor cable if it is properly connected to your motherboard. If you will have a video card you need to attach your monitor cable to the video card.
do u have a video card? or your monitor in connected in tou integrated grapics port? (i.e. in *********** board.) maybe your bios is set up in booting up on iether of its two and your monitor is connected to a different. try connecting it from the two, while booting up.
in my opion deep freeze (pige head)is not good progrram .itt creat big problem. we should know well how can be use it. once a time u should reinstale it or formate ur computer,i hae facing many problem from my custmer. -----thanks
May be your in second HDD, you didn't set the jumper up. There are some more settings you will have to configure in the BIOS menu. in the BIOS, you should set the primary HDD as the master and the second(newer HDD) as the secondary. Then it should boot without any problem but if the problem persists I don't know what to do next.
If you look at the monitor there will be an led light on the front that is always orange or yellow when the computer is off but still connected to the monitor. This led will turn green when the computer boots up, sometimes even showing a "no signal" display before boot. If you see the 'command line' text during the boot process (video info, BIOS version, POST text, etc) then the monitor is being recognized by the computer. If that text goes away and the led goes back to orange then it is a driver or operating system problem. Pressing whatever key is prompted at the lower left of the display, if you have a display, like F1, F2, F10, Delete or whatever will get you to the setup program and all is good with the display/computer connection and a green light will stay on. If you never get that green led light then either the video card is bad or not seated properly
Try reseating the memory. If you have more then one stick then do one stick at a time in each slot until you get video back.
